Các cao thủ làm ơn chỉ mình cách khắc phục lỗi này với : Không hiểu sao mình chỉ vào được đến đây là dừng !
Reading cookie from flash parameter block...done.
Base ethernet MAC Address: 00:18:19:bd:ae:c2
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
button pressed for 7 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
Loading "flash:/c1200-k9w7-mx.123-8.JEB"...######################################### ################################################## ################################################## ################################################## ################################################## ################################################## ################################################## ###################
File "flash:/c1200-k9w7-mx.123-8.JEB" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C1200 Software (C1200-K9W7-M), Version 12.3(8)JEB, RELEASE SOFTWARE (fc2)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 27-Apr-07 00:59 by hqluong
Image text-base: 0x00003000, data-base: 0x00698FC0
Initializing flashfs...
flashfs[1]: 4 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 7741440
flashfs[1]: Bytes used: 4198400
flashfs[1]: Bytes available: 3543040
flashfs[1]: flashfs fsck took 2 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
If you require further assistance please contact us by sending email to
export@cisco.com.
cisco AIR-AP1231G-A-K9 (PowerPC405GP) processor (revision A0) with 15138K/1236K bytes of memory.
Processor board ID FOC10254E07
PowerPC405GP CPU at 196Mhz, revision number 0x0145
Last reset from power-on
1 FastEthernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:18:19:BD:AE:C2
Part Number : 73-8704-12
PCA Assembly Number : 800-23211-13
PCA Revision Number : A0
PCB Serial Number : FOC10254E07
Top Assembly Part Number : 800-23304-11
Top Assembly Serial Number : FTX1027E0ZJ
Top Revision Number : A0
Product/Model Number : AIR-AP1231G-A-K9
Press RETURN to get started!
*Mar 1 00:00:03.946: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar 1 00:00:04.281: %DOT11-2-NO_FIRMWARE: Interface Dot11Radio0, no radio firmware file (flash:/5101.img) was found
*Mar 1 00:00:04.283: %DOT11-2-RESET_RADIO: Interface Dot11Radio0, Radio firmware file not found, Trying hardware reset on radio
*Mar 1 00:00:11.262: %DOT11-2-NO_FIRMWARE: Interface Dot11Radio0, no radio firmware file (flash:/5101.img) was found
*Mar 1 00:00:11.264: %DOT11-2-NO_FIRMWARE: Interface Dot11Radio0, no radio firmware file (flash:/5101.img) was found
*Mar 1 00:00:11.563: %DOT11-3-POWERS_INVALID: Interface Dot11Radio0, no valid power levels available
*Mar 1 00:00:11.564: %DOT11-3-POWERS_INVALID: Interface Dot11Radio0, no valid power levels available
*Mar 1 00:00:11.564: %DOT11-2-RADIO_FAILED: Interface Dot11Radio0, failed - firmware file not found
-Traceback= 18F68 41DAE8 416124 41F5A0 129D78 129E20 116F0 11904 1359F0
*Mar 1 00:00:13.646: %SYS-6-LOGGERSTART: Logger process started
*Mar 1 00:00:13.648: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar 1 00:00:14.648: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar 1 00:00:22.656: AUTOINSTALL: FastEthernet0 is assigned 192.168.0.26
*Mar 1 00:00:32.738: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Mar 1 00:00:33.738: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar 1 00:00:36.882: %SYS-5-RESTART: System restarted --
*Mar 1 00:00:36.883: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar 1 00:00:36.899: Writing radio coredump to 'flash:/r0.rcore'
*Mar 1 00:00:37.832: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:00:49.966: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 192.168.0.26, mask 255.255.255.0, hostname ap
*Mar 1 00:00:50.116: Writing radio coredump to 'flash:/r0.rcore'
*Mar 1 00:00:53.386: %DOT11-2-NO_FIRMWARE: Interface Dot11Radio0, no radio firmware file (flash:/5101.img) was found
*Mar 1 00:00:53.387: %DOT11-2-NO_FIRMWARE: Interface Dot11Radio0, no radio firmware file (flash:/5101.img) was found
*Mar 1 00:00:53.389: %DOT11-2-RESET_RADIO: Interface Dot11Radio0, Radio firmware file not found, Trying hardware reset on radio
*Mar 1 00:00:55.382: %SYS-3-CPUHOG: Task is running for (1997)msecs, more than (2000)msecs (0/0),process = Dot11 driver.
-Traceback= 23FCE0 23FCB8 40C8DC 67FDE8 682B28 416100 41D438 1359F0
*Mar 1 00:00:57.381: %SYS-3-CPUHOG: Task is running for (3996)msecs, more than (2000)msecs (0/0),process = Dot11 driver.
-Traceback= 23FCE0 23FCB8 40C8F8 67FDE8 682B28 416100 41D438 1359F0
*Mar 1 00:00:59.380: %SYS-3-CPUHOG: Task is running for (5995)msecs, more than (2000)msecs (0/0),process = Dot11 driver.
*Mar 1 00:01:00.371: %DOT11-2-NO_FIRMWARE: Interface Dot11Radio0, no radio firmware file (flash:/5101.img) was found
*Mar 1 00:01:00.372: %DOT11-2-NO_FIRMWARE: Interface Dot11Radio0, no radio firmware file (flash:/5101.img) was found
*Mar 1 00:01:00.673: %DOT11-3-POWERS_INVALID: Interface Dot11Radio0, no valid power levels available
Reset done!
executing...
cisco Systems, Inc.
export@cisco.com.
1 802.11 Radio(s)
