  • Giới thiệu và triển khai mô hình VoIP thực tế (phần 2)
    4. Cấu hình cuộc gọi giữa điện thoại IP Phone và Analog
    CME_1#show running-config
    Building configuration…
    Current configuration : 1289 bytes
    version 12.3
    hostname CME_1
    boot-start-marker
    boot-end-marker
    no aaa new-model
    ip subnet-zero
    ip cef
    ip audit po max-events 100
    controller T1 0/0
    framing sf
    linecode ami
    controller T1 0/1
    framing sf
    linecode ami
    interface Ethernet0/0
    half-duplex
    interface Ethernet0/0.12
    encapsulation dot1Q 12
    ip address 10.0.12.1 255.255.255.0
    interface Ethernet0/0.13
    encapsulation dot1Q 13
    ip address 10.0.13.1 255.255.255.0
    ip http server
    no ip http secure-server
    ip classless
    voice-port 1/0/0
    station-id name 1001
    station-id number 1001
    voice-port 1/0/1
    station-id name 1002
    station-id number 1002
    dial-peer voice 1001 pots
    destination-pattern 1001
    port 1/0/0
    dial-peer voice 1002 pots
    destination-pattern 1002
    port 1/0/1
    dial-peer voice 2000 voip
    destination-pattern 2…
    session target ipv4:10.0.12.2
    dial-peer voice 3000 voip
    destination-pattern 3…
    session target ipv4:10.0.13.3
    dial-peer voice 4000 voip
    destination-pattern 4…
    logging synchronous
    line aux 0
    privilege level 15
    no login
    CME_2#show running-config
    Current configuration : 1346 bytes
    version 12.3
    hostname CME_2
    boot-start-marker
    boot-end-marker
    no aaa new-model
    ip subnet-zero
    ip cef
    half-duplex
    ip address 10.0.12.2 255.255.255.0
    interface Ethernet0/0.23
    encapsulation dot1Q 23
    ip address 10.0.23.2 255.255.255.0
    ip http server
    ip classless
    voice-port 1/0/0
    station-id name Hai
    station-id number 2001
    voice-port 1/0/1
    station-id name Phuong
    station-id number 2002
    dial-peer voice 2001 pots
    destination-pattern 2001
    port 1/0/0
    dial-peer voice 2002 pots
    destination-pattern 2002
    port 1/0/1
    dial-peer voice 1000 voip
    destination-pattern 1…
    session target ipv4:10.0.12.1
    session target ipv4:10.0.23.3
    logging synchronous
    line aux 0
    privilege level 15
    no login
    CME_3#show running-config
    Current configuration : 2191 bytes
    version 12.4
    hostname CME_3
    boot-start-marker
    boot-end-marker
    no aaa new-model
    dot11 syslog
    ip cef
    no ip dhcp use vrf connected
    ip dhcp excluded-address 10.0.30.1 10.0.30.10
    ip dhcp pool LAN
    network 10.0.30.0 255.255.255.0
    default-router 10.0.30.1
    option 150 ip 10.0.30.1
    ip auth-proxy max-nodata-conns 3
    ip admission max-nodata-conns 3
    multilink bundle-name authenticated
    voice-card 0
    no dspfarm
    archive
    log config
    hidekeys
    interface FastEthernet0/0
    duplex auto
    speed auto
    interface FastEthernet0/0.13
    ip address 10.0.13.3 255.255.255.0
    interface FastEthernet0/0.23
    ip address 10.0.23.3 255.255.255.0
    interface FastEthernet0/0.30
    encapsulation dot1Q 30
    ip address 10.0.30.1 255.255.255.0
    interface FastEthernet0/1
    shutdown
    duplex auto
    speed auto
    interface Serial0/0/0
    shutdown
    no fair-queue
    clock rate 2000000
    ip forward-protocol nd
    ip http server
    control-plane
    session target ipv4:10.0.23.2
    session target ipv4:10.0.13.1
    telephony-service
    max-ephones 10
    max-dn 20
    ip source-address 10.0.30.1 port 2000
    system message CME Voice
    keepalive 15
    max-conferences 8 gain -6
    transfer-system full-consult
    create cnf-files version-stamp Jan 01 2002 00:00:00
    ephone-dn 1
    number 3001
    ephone-dn 2
    number 3002
    name Truong AN
    ephone-dn 3
    number 3003
    name Nghia
    ephone-dn 4
    number 4001
    name Duc
    ephone 1
    device-security-mode none
    mac-address 0026.1839.D23B
    button 1:1
    ephone 2
    mac-address F0DE.F19B.B189
    button 1:2
    ephone 4
    mac-address 0013.A929.83ED
    button 1:4
    logging synchronous
    line aux 0
    privilege level 15
    no login
    scheduler allocate 20000 1000
    5. Cấu hình cuộc gọi giữa điện thoại IP Phone thông qua softphone
    version 12.4
    hostname CME_3
    boot-start-marker
    boot-end-marker
    no aaa new-model
    dot11 syslog
    ip cef
    ip dhcp pool LAN//cấp phát IP động cho VLAN 30
    voice-card 0
    no dspfarm
    archive
    log config
    hidekeys
    duplex auto
    speed auto
    shutdown
    duplex auto
    speed auto
    shutdown
    no fair-queue
    clock rate 2000000
    ip http server
    control-plane
    telephony-service
    max-ephones 10
    max-dn 20
    keepalive 15
    ephone-dn 1
    number 3001
    ephone-dn 2
    number 3002
    name Truong AN
    ephone-dn 3
    number 3003
    name Nghia
    ephone-dn 4
    number 4001
    name Duc
    ephone 1
    button 1:1
    ephone 2
    button 1:2
    ephone 4
    button 1:4
    logging synchronous
    line aux 0
    privilege level 15
    no login
    Nguyễn Đình Hải & Nguyễn Trọng Nghĩa – VnPro
    Xem phần 1 tại đây.
    Phạm Thanh Đông Khê
    Email: dongkhe@vnpro.org
    Forum: http://www.vnpro.org
    FB: http://facebook.com/VnPro
