  • CCIE R/S Lab Sample Open-Ended Exam Questions
    Here are some facts regarding this portion of the exam:
    • You must complete this portion of the exam before you start the traditional configuration portion.
    • You have a total of 30 minutes to complete this section, you may finish early if you like.
    • You will receive 4 to 5 questions via the computer and you must provide short answers using the computer interface. The questions are not oral in nature.
    • You will not receive a score when you complete this section, but you must pass this portion to pass the CCIE. You will receive your score in the open-ended section if you fail the exam.
    • Most students finish the 4 to 5 questions in approximately 12 minutes.
    • The configuration portion of the exam has been reduced to accommodate this initial 30 minutes.
    • You still have a total of 8 hours that makeup the open-ended questions and the configuration portion.
    • You may not access the DOC-CD to answer these questions.
    Here are some samples for the many, many different open-ended questions Cisco could ask for the R/S track. Please notice there is no need for panic if you are using one of our recommended study approaches.
    Bridging and Switching
    • What is the size of the 802.1Q tag?
    • Examine the diagram shown, describe the flow of traffic in VLAN 12 from Switch A to Switch D.
    IP IGP Routing
    • What are the five possible metric components for EIGRP and which two are used by default?
    • Given the network diagram shown, what is the path traffic will take from Router A to Router B?
    BGP
    • What issues can the use of a peer group solve in BGP?
    • What are the default administrative distances for BGP?
    IP and IOS Features
    • How can a Cisco router assist a client PC to obtain a DHCP address from a DHCP server located on a remote subnet?
    IP Multicast
    • Which multicast PIM method uses a push and pull approach?
    • Which option for RP assignment is an open standard?
    QoS
    • What happens to traffic in the priority queue of the LLQ method that exceeds the specified rate?
    • Which bits of the ToS byte are used for DSCP markings?
    • Between AF21 and AF31, which has the higher drop probability?
    Security
    • Given the access list and assignment shown in the diagram, what happens to Telnet traffic?
    Refe: [CCIE R&S LAB] Ngày 1-2-2009, thay đổi hình thức thi
    Trần Mỹ Phúc
    tranmyphuc@hotmail.com
    Juniper Certs :
    JNCIP-ENT & JNCIP-SEC
    [version 4.0] Ôn tập CCNA
