  • Giúp đỡ cấu hình router cisco 891F
    Em có con router Cisco 891F. ISP VNPT modem, cấu hình bridge. Rồi cắm vào WAN GE8 cisco để quay PPoE.
    Em cấu hình như thế này, client nhận IP nhưng không ra net được. Sư phụ xem giúp em xem lỗi ở chỗ nào ạ ?
    hostname Router891F
    boot-start-marker
    boot-end-marker
    aqm-register-fnf
    enable password AAAaaaAAA
    no aaa new-model
    ip dhcp excluded-address 192.168.1.1 192.168.1.19
    ip dhcp excluded-address 192.168.1.201 192.168.1.254
    ip dhcp pool ippool
    network 192.168.1.0 255.255.255.0
    default-router 192.168.1.1
    dns-server 8.8.8.8 8.8.4.4
    no ip domain lookup
    ip cef
    no ipv6 cef
    multilink bundle-name authenticated
    interface BRI0
    encapsulation hdlc
    shutdown
    isdn termination multidrop
    interface FastEthernet0
    shutdown
    duplex auto
    speed auto
    interface GigabitEthernet0
    no shut
    spanning-tree portfast
    interface GigabitEthernet1
    no shut
    interface GigabitEthernet2
    no shut
    interface GigabitEthernet3
    no shut
    interface GigabitEthernet4
    no shut
    interface GigabitEthernet5
    no shut
    interface GigabitEthernet6
    no shut
    interface GigabitEthernet7
    no shut
    interface GigabitEthernet8
    no shut
    ip nat outside
    ip virtual-reassembly in
    duplex auto
    speed auto
    pppoe enable
    interface Vlan1
    ip nat inside
    interface Async3
    encapsulation slip
    interface Dialer1
    ip address negotiated
    ip mtu 1492
    encapsulation ppp
    dialer pool 1
    dialer-group 1
    ppp authentication pap callin
    ppp pap sent-username AAAaaaAAA password 0 1234567890
    ppp ipcp dns request
    ip forward-protocol nd
    ip http server
    ip http secure-server
    ip route 0.0.0.0 0.0.0.0 dhcp
    ip nat inside source list 1 interface GigabitEthernet8 overload
    ip nat inside source static tcp 192.168.1.250 8899 int Gi8 8899
    ip nat inside source static tcp 192.168.1.250 8181 int Gi8 8181
    ip nat inside source static upd 192.168.1.250 8899 int Gi8 8899
    ip nat inside source static upd 192.168.1.250 8181 int Gi8 8181
    no cdp run
    access-list 1 permit 192.168.1.0 0.0.0.255
    control-plane
    mgcp behavior rsip-range tgcp-only
    mgcp behavior comedia-role none
    mgcp behavior comedia-check-media-src disable
    mgcp behavior comedia-sdp-force disable
    mgcp profile default
    no modem enable
    line aux 0
    line 3
    modem InOut
    speed 115200
    flowcontrol hardware
    password 123abc456
    login
    transport input all
    scheduler allocate 20000 1000
    ANh chưa xem qua cấu hình chi tiết. Nhưng nếu con router của em đã nhận được IP từ ISP thì đó là dấu hiệu tốt - xác thực đã thành công. Việc tiếp theo là em kiểm tra xem em có cấu hình routing hay cấu hình NAT chính xác chưa?
      Dạ. Anh xem sơ qua chỗ NAT và routing xem có gì không ổn không ạ ?
      Em hơi lấn cấn ở chỗ NAT qua Dialer1 hay GigabitEthernet8.
