em chỉ trả lời dc mấy câu chỗ bôi đen, còn lại pro nao chỉ jup em fat'
3.You type ipconfig /all at a command prompt at Jim's machine. You get the following displayed on his screen:
Physical Address : 00-10-4B-65-12-6C
DHCP Enabled No
IP Address 192.67.35.18
Subnet Mask 255.255.255.240
Default Gateway 192.67.35.1
What is not right in this output?
a)The number of subnet bits should be more.
b)DHCP should be enabled.
c)The physical address is not valid.
d)The default gateway is incorrect.
4. If a client has a valid IP address and a valid subnet mask but has incorrect default gateway, what symptoms could result?
a)The client can connect to some but not all host on a different subnet
b)The client can connect to hosts on the local subnet but not to hosts on the different subnet
c)The client can ping all host by IP address, but not by domain name
d)The client cannot ping a host on different subnet but that host can ping the client
5. You have users that connect their Win 95/98/NT laptop computers to different subnets in your company. You don’t want to manually reconfigure their IP address and default gateway each time they connect to the different subnet. Which of the following might be a solution?
a)DNS
b)RARP
c)DHCP
d)ARP
e)IPX
6. From your computer’s browser, you can connect to all web sites by IP address but you cannot connect to them by domain name? Which of the following would be an effective troubleshooting step?
a)Check your IP address setting
b)Check your WINS server setting
c)Check your DNS server setting
d)Check your Computer name setting
e)Check your Workgroup setting
7.Your company use a class C address 192.168.100.0 and the first 200 IP address has been used. Your computer IP address is 192.168.100.131 and have no default-gateway configured. You can ping 192.168.100.133 and 192.168.100.138 but can not ping 192.168.100.157. What could be your subnetmask?
a)255.255.224.0
b)255.255.255.240
c)255.255.255.192
d)255.255.255.248
e)255.255.255.224
8.Which of the following TCP/IP protocol is primarily used for error reporting and controlling message?
a)IP
b)RIP
c)TCP
d)UDP
e)ICMP
9 A new network is being designed for your company using a Class C IP network. Company has 5 department, each department has 12, 13, 7, 14, 12 staffs. Which subnet mask will provide one useable subnet per department while allowing enough usable host addresses for each department specified in the graphic? (choose two) i.255.255.255.0
ii.255.255.255.192
iii.255.255.255.224
iv.255.255.240.0
v.255.255.255.252
vi.255.255.255.240
DHCP Enabled No
a)DNS
b)RARP
c)DHCP
d)ARP
e)IPX
a)255.255.224.0
b)255.255.255.240
c)255.255.255.192
d)255.255.255.248
e)255.255.255.224
a)IP
b)RIP
c)TCP
d)UDP
e)ICMP
ii.255.255.255.192
iii.255.255.255.224
iv.255.255.240.0
v.255.255.255.252
vi.255.255.255.240
