  • Help Config ADSL Bridge Mode và Cisco 1841
    Mong thầy và các bạn giúp đỡ. Cấu hình dưới là trên con cisco 1841 của mình. Cấu hình nhận IP rồi mà PC không vào mạng được, trên cisco ping WAN thì OK. Thanks for help.
    PC<----->(Fa0/1)cisco 1841(Fa0/0)<------Router ADSL D-Link DSL-504T<----->VNPT
    - PC :
    192.168.1.2
    255.255.255.0
    192.168.1.1
    - Cisco Fa0/1 :
    192.168.1.1
    255.255.255.0
    - Cisco Fa0/0 : no IP
    - Router ADSL D-Link : Bridge Mode
    Current configuration : 2041 bytes
    version 12.4
    service password-encryption
    hostname test
    boot-start-marker
    boot-end-marker
    logging buffered 51200 warnings
    no aaa new-model
    resource policy
    mmi polling-interval 60
    no mmi auto-configure
    no mmi pvc
    mmi snmp-timeout 180
    ip subnet-zero
    ip cef
    no ip dhcp use vrf connected
    ip domain name yourdomain.com
    ip name-server 203.162.4.190
    username admin privilege 15 secret 5 $1$SA9/$Hk8EmAo6YjhxYhgEBmu2U1
    bridge crb
    interface FastEthernet0/0
    description Connect to Internet
    no ip redirects
    ip route-cache flow
    ip tcp adjust-mss 1344
    duplex auto
    speed auto
    pppoe enable
    interface FastEthernet0/1
    description Connect to LAN
    ip nat inside
    ip tcp adjust-mss 1452
    duplex auto
    speed auto
    interface Serial0/0/0
    shutdown
    clockrate 2000000
    interface Serial0/0/1
    shutdown
    clockrate 2000000
    interface Dialer0
    description Interface for Internet Access
    mtu 1492
    ip address negotiated
    ip nat outside
    encapsulation ppp
    dialer pool 1
    dialer-group 1
    no cdp enable
    ppp authentication pap callin
    ppp pap sent-username user1 password 7 241654654564654T4545
    no ip classless
    ip route 0.0.0.0 0.0.0.0 Dialer0
    ip http server
    ip http timeout-policy idle 60 life 86400 requests 10000
    control-plane
    exec-timeout 0 0
    password 7 131545445135454E545E54
    logging synchronous
    login
    line aux 0
    timeout login response 300
    password 7 212454654R456454554E
    login
    transport input telnet
    #sho ip interface brief
    Interface IP-Address OK? Method Status Prot
    ocol
    FastEthernet0/0 unassigned YES manual up up
    FastEthernet0/1 192.168.1.1 YES manual up up
    Serial0/0/0 unassigned YES manual administratively down down
    Serial0/0/1 unassigned YES manual administratively down down
    Serial0/0/1.1 unassigned YES unset deleted down
    NVI0 unassigned YES unset up up
    Virtual-Access1 unassigned YES unset up up
    Dialer0 123.28.92.156 YES IPCP up up
    #show interfaces dialer 0
    Dialer0 is up, line protocol is up (spoofing)
    Hardware is Unknown
    Description: Interface for Internet Access
    Internet address is 123.28.92.156/32
    MTU 1492 bytes, BW 56 Kbit, DLY 20000 usec,
    Encapsulation PPP, loopback not set
    Keepalive set (10 sec)
    DTR is pulsed for 1 seconds on reset
    Interface is bound to Vi1
    Last input never, output never, output hang never
    Last clearing of "show interface" counters 02:24:18
    Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
    Queueing strategy: weighted fair
    Output queue: 0/1000/64/0 (size/max total/threshold/drops)
    Conversations 0/0/16 (active/max active/max total)
    Reserved Conversations 0/0 (allocated/max allocated)
    Available Bandwidth 42 kilobits/sec
    752 packets input, 22720 bytes
    1108 packets output, 53545 bytes
    Chào bạn
    Từ router ping WAN ok. PC ping WAN ko được vậy vấn đề chỉ nằm ở chỗ bạn NAT thôi. Đọc tới lui hoài không thấy cấu hình nat ở đâu nên bạn xem cấu hình bên dưới :
    Router(config)#access-list 101 permit ip <ip của LAN> any
    //tạo bộ access-list để chuẩn bị cho việc port forwarding ( PAT ) các packet trong LAN thành packet WAN hợp lệ
    Router(config)#ip nat inside source list 101 interface dialer 0 overload
    //Apply việc PAT các gói tin từ LAN ra ngoài WAN
    Vậy nhé
      Thanks bạn nhiều.
        Cho mình hỏi thêm về Remote Desktop từ ngoài vào. Mình sẽ NAT port 3389 ở trên Firewall hay trên Cisco, hay cả 2. Xin giúp đỡ. Truy cập Net bình thường. Thanks...
        PC<----->(Eth1)Firewall(Eth2)<--->(Fa0/1)cisco 1841(Fa0/0)<------>Router ADSL D-Link DSL-504T<----->VNPT
        PC :
        172.22.6.12
        255.255.255.0
        172.22.6.1
        - Firewall Eth1 :
        172.22.6.1
        - Firewall Eth2 :
        192.168.1.2
        Cisco Fa0/1 :
        192.168.1.1
        255.255.255.0
        Cisco Fa0/0 : no IP
        version 12.4
        hostname test
        boot-start-marker
        boot-end-marker
        no aaa new-model
        resource policy
        no mmi pvc
        ip subnet-zero
        ip cef
        bridge crb
        no ip redirects
        ip route-cache flow
        duplex auto
        speed auto
        pppoe enable
        ip nat inside
        duplex auto
        speed auto
        shutdown
        clockrate 2000000
        shutdown
        clockrate 2000000
        interface Dialer0
        mtu 1492
        ip nat outside
        encapsulation ppp
        dialer pool 1
        dialer-group 1
        no cdp enable
        no ip classless
        ip http server
        control-plane
        exec-timeout 0 0
        logging synchronous
        login
        line aux 0
        login
          Hi
          Bạn có thể làm như sau:
          Vì mô hình bạn đưa ra có firewall nên bạn phải xác định rõ PC trong LAN khi qua firewall bạn để ở chế độ route hay nat.
          -Nếu là route bình thường thì chỉ cần mở port 3389 cho hướng từ outside -> inside.
          -Nếu là nat thì đương nhiên lúc này traffic từ ngoài vào bạn phải Nat 2 lần qua router cisco và firewall rồi
          Bạn dùng Nat dest trên int ngoài (fa0/0) của con cisco trỏ về ip của PC nếu firewall ở chế độ route.
          Còn nếu ở chế độ nat thì bạn phải trỏ ip nat dest về ip cổng eth2 của firewall, tiếp theo từ firewall bạn lại nat dest 1 lần nữa và trỏ về ip của PC.
          Đương nhiên lúc này bạn đã enable rdp trên windows rồi. Nếu dùng ip động thì bạn đăng ký account no-ip hoặc dyndns để dùng tạm.
          Bạn nên cho biết rõ firewall bạn dùng của hãng nào thì mới hỗ trợ tốt được, vì mỗi hãng có đặc thù riêng.
          Thân
            Cám ơn bạn đã hướng dẫn tận tình. Bên mình đang dùng con Firewall Juniper Netscreen-50.
            - Firewall Eth1 : NAT
            - Firewall Eth2 : Route
            Lúc trước với mô hình : PC<----->(Eth1)Firewall(Eth2)<------>Router ADSL D-Link DSL-504T<----->VNPT
            thì mình remote OK. Nhưng khi thêm con Cisco vào thì không remote được. Trên con Firewall mình đã mở port 3389 và cho nó NAT vào máy PC rồi. Trên cisco mình cấu hình thêm ip nat inside source static tcp 123.28.92.156 3389 192.168.1.2 3389 extendable, mình dùng ip nat inside này ok ko. Thanks
