  • Sự cố gì đây với Switch 2950?
    File "flash:/c2950-i6q4l2-mz.121-22.EA4.bin" uncompressed and installed, entry point: 0x80010000
    executing...
    Restricted Rights Legend
    Use, duplication, or disclosure by the Government is
    subject to restrictions as set forth in subparagraph
    (c) of the Commercial Computer Software - Restricted
    Rights clause at FAR sec. 52.227-19 and subparagraph
    (c) (1) (ii) of the Rights in Technical Data and Computer
    Software clause at DFARS sec. 252.227-7013.
    cisco Systems, Inc.
    170 West Tasman Drive
    San Jose, California 95134-1706
    IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA4, RELEASE SOFTWARE (fc1)
    Copyright (c) 1986-2005 by cisco Systems, Inc.
    Compiled Wed 23-Mar-05 15:33 by yenanh
    Image text-base: 0x80010000, data-base: 0x80562000
    Initializing flashfs...
    flashfs[1]: 4 files, 2 directories
    flashfs[1]: 0 orphaned files, 0 orphaned directories
    flashfs[1]: Total bytes: 7741440
    flashfs[1]: Bytes used: 3102720
    flashfs[1]: Bytes available: 4638720
    flashfs[1]: flashfs fsck took 6 seconds.
    flashfs[1]: Initialization complete.
    Done initializing flashfs.
    POST: System Board Test : Passed
    POST: Ethernet Controller Test : Passed
    ASIC Initialization Passed
    POST: FRONT-END LOOPBACK TEST : Passed
    cisco WS-C2950-24 (RC32300) processor (revision J0) with 21039K bytes of memory.
    Processor board ID FOC0717Y0BY
    Last reset from system-reset
    Running Standard Image
    24 FastEthernet/IEEE 802.3 interface(s)
    32K bytes of flash-simulated non-volatile configuration memory.
    Base ethernet MAC Address: 00:0C:CE:9C:00:80
    Motherboard assembly number: 73-5781-11
    Power supply part number: 34-0965-01
    Motherboard serial number: FOC071715M4
    Power supply serial number: DAB07164J50
    Model revision number: J0
    Motherboard revision number: A0
    Model number: WS-C2950-24
    System serial number: FOC0717Y0BY
    Press RETURN to get started!
    00:00:14: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
    00:00:16: %SYS-5-CONFIG_I: Configured from memory by console
    00:00:16: %SYS-5-RESTART: System restarted --
    00:00:16: %SNMP-5-COLDSTART: SNMP agent on host SW_1 is undergoing a cold start
    00:00:18: %LINK-5-CHANGED: Interface Vlan2, changed state to administratively down
    00:00:19: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan2, changed state to down
    Trên đây là output mình capture được khi access vô console port của switch 2950 catalyst.
    Chạy tới đây thì đứng cứng ngắt? Không cấu hình được nữa. Xin hướng dẫn cách khắc phục! Thanks.
    Cách tốt nhất là giữ nút reset sau đó cắm nguồn lại, xóa toàn bộ cấu hình,load lại cấu hình từ flash, thế là xong.
    Vì nhiều khi có những nguyên nhân do người cấu hình trước của bạn cấu hình một lệnh nào đó bị sai.
    Huy Bắc
    The Mumble Fund
    Vui long vao:
    De cung ket noi.
    Yahoo: huybac_nguyen
    Mail: huybac.nguyen@gmail.com
    Techcombank: 13320037822012
    Vietcombank: 0611001454910
