  • [IPv6] một số bài lab về IPv6
    OSPFv3 Neighbors do not need to be on same subnet
    Check it out:
    R2 F0/0 <-----> F0/0 R3
    Here is R2's config:
    R2#sho run int f0/0
    Current configuration : 153 bytes
    interface FastEthernet0/0
    duplex auto
    speed auto
    ipv6 address 2001:2::2/64
    ipv6 address FE80::2 link-local
    ipv6 ospf 1 area 0
    Here is R3's config:
    R3#sho run int f0/0
    duplex auto
    speed auto
    ipv6 address 2001:3::3/64
    ipv6 address FE80::3 link-local
    ipv6 ospf 1 area 0
    R2's show commands:
    R2#sho ipv6 ospf ne
    Neighbor ID Pri State Dead Time Interface ID Interface
    3.3.3.3 1 FULL/DR 00:00:35 4 FastEthernet0/0
    R2#sho ipv6 route
    IPv6 Routing Table - 5 entries
    Codes: C - Connected, L - Local, S - Static, R - RIP, B - BGP
    U - Per-user Static route
    I1 - ISIS L1, I2 - ISIS L2, IA - ISIS interarea, IS - ISIS summary
    O - OSPF intra, OI - OSPF inter, OE1 - OSPF ext 1, OE2 - OSPF ext 2
    ON1 - OSPF NSSA ext 1, ON2 - OSPF NSSA ext 2
    C 2001:2::/64 [0/0]
    via ::, FastEthernet0/0
    L 2001:2::2/128 [0/0]
    O 2001:3::/64 [110/10]
    L FE80::/10 [0/0]
    via ::, Null0
    L FF00::/8 [0/0]
    via ::, Null0
    R2 can now ping 2001:3::3
    R2#ping 2001:3::3
    Sending 5, 100-byte ICMP Echos to 2001:3::3, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 8/20/56 ms
    R2#
    This is possible because neighbors are known by their router-ids and link-local addresses are used as next hops, not the actual interface addresses.
    Email : gialiem@vnpro.org
    Yahoo : gialiem_vnpro
    Renumbering IPv6 with ease via ipv6 general-prefix
    This is rather neat IPv6 feature that eases renumbering. We define a general prefix globally and then assign interface addresses based on that interface. Should you change providers or ever have to renumber the network, all you have to do is change the general prefix. Here's how it works:
    R5(config)#ipv6 general-prefix TEST 2001:5::/48
    R5(config)#
    R5(config)#int s1/0
    R5(config-if)#ipv6 address TEST 2001:5::/48 eui-64
    R5#sho ipv6 interface s1/0 | inc :
    IPv6 is enabled, link-local address is FE80::E1B8:5FF:FE4C:9CDD
    Global unicast address(es):
    2001:5::, subnet is 2001:5::/48 [GEN]
    2001:5::E1B8:5FF:FE4C:9CDD, subnet is 2001:5::/48 [EUI]
    Joined group address(es):
    FF02::1
    FF02::2
    FF02::1:FF00:0
    FF02::1:FF4C:9CDD
    ND DAD is enabled, number of DAD attempts: 1
    R5#
    We now have an IPv6 address assigned based on the EUI-64 method. The address is 2001:5::E1B8:5FF:FE4C:9CDD. Now suppose we need to change our prefix to 2001:6.
    R5(config)#no ipv6 general-prefix TEST 2001:5::/48
    R5(config)#ipv6 general-prefix TEST 2001:6::/48
    R5(config)#
    R5(config)#^Z
    2001:6::, subnet is 2001:6::/48 [GEN]
    2001:6::E1B8:5FF:FE4C:9CDD, subnet is 2001:6::/48 [EUI]
    FF02::1
    FF02::2
    FF02::1:FF00:0
    FF02::1:FF4C:9CDD
    R5#
    Image if we had more interfaces, this would make things so much easier. Especially considering each interface would have its own subnet. Imagine if we had interfaces on the 2001:5:0:1, 2001:5:0:2 (and so on) networks. We could change all of these to /48 prefix 2001:6:0:x:/64 with a couple commands. When you do change the general prefix, it does not overwrite the already configured one. This way you can have two prefixes during transition and eventually remove the older one as we did above.
      IPv6 NAT-PT
      This is a very simple IPv6 NAT-PT scenario. Here is the topology and addressing:
      R1 is an IPv6 only host and R2 is an IPv4 only host.
      R1 should use address 2001:23::2 to reach R2.
      R2 should use 192.168.13.1 to reach R1.
      R3 will be doing NAT-PT
      Assign addresses per the diagram. The rest of the configuration is on R3.
      R3(config)#int e0/0
      R3(config-if)#ipv6 nat
      R3(config-if)#int e0/1
      R3(config)#ipv6 nat v4v6 source 192.168.23.2 2001:23::2
      R3(config)#ipv6 nat v6v4 source 2001:13::1 192.168.13.1
      R3(config)#ipv6 nat prefix 2001:23::/96
      Remember to assing default gateways on R1 and R2:
      R1(config)#ipv6 route 0::/0 2001:13::3
      R2(config)#ip route 0.0.0.0 0.0.0.0 192.168.23.3
      Let's ping from R1 while debugging on R3:
      R3#debug ipv6 nat
      IPv6 NAT-PT debugging is on
      R1#ping 2001:23::2 re 1
      Sending 1, 100-byte ICMP Echos to 2001:23::2, timeout is 2 seconds:
      Success rate is 100 percent (1/1), round-trip min/avg/max = 4/4/4 ms
      R1#
      R3#
      *Mar 1 13:51:12.323: IPv6 NAT: icmp src (2001:13::1) -> (192.168.13.1),dst (2001:23::2) -> (192.168.23.2)
      *Mar 1 13:51:12.327: IPv6 NAT: src (192.168.23.2) -> (2001:23::2), dst (192.168.13.1) -> (2001:13::1)
      R3#
      Now let's try the other way:
      R2#ping 192.168.13.1 re 1
      Sending 1, 100-byte ICMP Echos to 192.168.13.1, timeout is 2 seconds:
      Success rate is 100 percent (1/1), round-trip min/avg/max = 8/8/8 ms
      R2#
      R3#
      *Mar 1 13:53:00.991: IPv6 NAT: src (192.168.23.2) -> (2001:23::2), dst(192.168.13.1) -> (2001:13::1)
      *Mar 1 13:53:00.995: IPv6 NAT: icmp src (2001:13::1) -> (192.168.13.1),dst (2001:23::2) -> (192.168.23.2)
      R3#
      You can view the translations on R3:
      R3#sho ipv6 nat translations
      Prot IPv4 source IPv6 source
      IPv4 destination IPv6 destination
      --- 192.168.13.1 2001:13::1
      That's it!
        Making a VLAN IPv6 only
        Here is the simple topology for this lab. R1 and R2 are on VLAN 12. VLAN12 needs to be IPv6 only. We test this my assigning IPv4 and IPv6 addresses to both routers and then pinging.
        R1---SW1---SW2---R2
        R1:
        IPv4: 192.168.12.1/24
        IPv6: 2001::1/64
        R2:
        IPv4: 192.168.12.2/24
        IPv6: 2001::2/64
        Making a vlan IPv6 only requires more configuration than I previously thought. This was my first attempt. On all switches:
        mac access-list extended IPv6
        permit any any 0x86DD 0x0
        vlan access-map IPv6only 10
        action forward
        match mac address IPv6
        vlan filter IPv6only vlan-list 12
        So R1 pings R2:
        R1#ping 192.168.12.2
        Sending 5, 100-byte ICMP Echos to 192.168.12.2, timeout is 2 seconds:
        But wait, let's remove the filter, ping, add the filter back, and ping again.
        SW1(config)#no vlan filter IPv6only vlan-list 12
        Success rate is 100 percent (5/5), round-trip min/avg/max = 1/3/4 ms
        SW1(config)#vlan filter IPv6only vlan-list 12
        Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
        R1 can still ping. What happened? Well the original filter wasn't blocking IP, it was only blocking ARP packets. Remember MAC access-lists do not have an implicit deny for the IP ethertype but they do have an implicit deny for all the other ethertypes. So once we removed the filter and allowed ARP through, R1 was able to ping R2 when the filtered was applied.
        To make the vlan IPv6 only I had to specify a drop action in an empty access-map statement:
        SW1(config)#vlan access-map IPv6only 20
        SW1(config-access-map)# action drop
        R1#
        But wait, let's check out spanning-tree:
        SW1#sho spanning-tree vlan 12 | inc root
        This bridge is the root
        SW2#show spanning-tree vlan 12 | inc root
        This is bad because both switches forward out all ports when they think they are root. If we had multiple links between these switches, we would have a loop. You may start seeing these messages:
        SW2#
        01:28:49: %SW_MATM-4-MACFLAP_NOTIF: Host 00b0.6410.3901 in vlan 12 is flapping between port Fa0/13 and port Fa0/14
        01:28:49: %SW_MATM-4-MACFLAP_NOTIF: Host 0007.eb14.4f81 in vlan 12 is flapping between port Fa0/13 and port Fa0/14
        We need to allow STP bpdu's in our original MAC access-list. Do this now:
        SW1(config)#mac access-list extended IPv6
        SW1(config-ext-macl)#permit any any lsap 0xAAAA 0x0
        Now we see SW2 blocking on the port f0/14 (for VLANs 1 and 12):
        SW2#sho span | inc BLK
        Fa0/14 Altn BLK 19 128.16 P2p
        Verify R1 can ping R2 via IPv6 and not IPv4:
        R1#ping 2001::2
        Sending 5, 100-byte ICMP Echos to 2001::2, timeout is 2 seconds:
        Success rate is 100 percent (5/5), round-trip min/avg/max = 0/1/4 ms
        R1#
        I used 0xAAAA because this what lsap type PVST uses. I don't know where I got this but I think I saw it on GS somehwere. I have also seen 0x4242 used but I think this is for normal STP (802.1d). In any case, only the 0xAAAA worked for me.
          IPv6 Tunneling - ISATAP
          R2, R5 and R6 connected via an IPv4 frame-relay network.
          There is no PVC in use between R5 and R6.
          Each device has a loopback 192.168.x.x where x is router number.
          The goal here is to allow the remote IPv6 networks to communicate over the IPv4 cloud.
          Below are the configs.
          Loopback 100 = tunnel endpoint
          Loopback 101 = "remote" network
          R6:
          interface Loopback100
          ip address 192.168.6.6 255.255.255.255
          interface Loopback101
          ipv6 address 2001:600::6/64
          interface Tunnel1
          ipv6 address 2001:200::/64 eui-64
          tunnel source Loopback100
          tunnel mode ipv6ip isatap
          R5:
          ip address 192.168.5.5 255.255.255.255
          ipv6 address 2001:500::5/64
          interface Tunnel1
          Static routes on R5 and R6:
          R5(config)#ipv6 route 2001:600::/64 tunnel 1 fe80::5efe:c0a8:0606
          R6(config)#ipv6 route 2001:500::/64 tunnel 1 fe80::5efe:c0a8:0505
          Where did I get these next hops? Well when you create an ISATAP tunnel they are created in a modified eui-64 format. Take a look
          at R5:
          R5#show ipv6 interface brief tun 1
          Tunnel1 [up/up]
          FE80::5EFE:C0A8:505
          2001:200::5EFE:C0A8:505
          When the router decides to route a packet out of that tunnel interface, it calculates the Ipv4 next hop address from the last 32 bits of the modified eui-64 address. In this case C0A8:505 converts to 192.168.5.5. R6 sends all packets destined for 2001:500::/64 to 192.168.5.5.
          Key things to remember:
          -The tunnel source address must be reachable by remote routers
          -There is no manually specified tunnel destination
          -You must specify the tunnel interface and link layer address in static routes
            IPv6 - Stateless autoconfig
            Logical Topology:
            R6------SW2
            R6 is in vlan 6.
            SW2 get its address for SVI 6 via stateless autoconfiguration.
            R6 will be advertising the prefix for SW2 to use to build it's address.
            R6 already has an IPv6 address configured: 2001:cc1e:1:6::6/64
            Also, a good command to run here is "debug ipv6 nd".
            Rack1R6#debug ipv6 nd
            ICMP Neighbor Discovery events debugging is on
            Rack1SW2#debug ipv6 nd
            Before we do anything let's see what debugging gives us on R6:
            Rack1R6#
            *Mar 1 00:42:14.219: ICMPv6-ND: Sending RA to FF02::1 on Ethernet0/1
            *Mar 1 00:42:14.219: ICMPv6-ND: MTU = 1500
            *Mar 1 00:42:14.219: ICMPv6-ND: prefix = 2001:CC1E:1:6::/64 onlink autoconfig
            *Mar 1 00:42:14.219: ICMPv6-ND: 2592000/604800 (valid/preferred)
            Rack1R6#
            We can see that R6 is already advertising it's prefix for hosts on this segment to use. Look at the output of the debug. We have
            1) All nodes multicast address FF02::1, this is the destination of the RA advertisement
            2) MTU of 1500
            3) Prefix advertised by R6 2001:CC1E:1:6::/64
            4) Valid and Preferred Lifetime 2592000/604800
            All we need to do on SW2 is configure the SVI for autoconfiguration:
            SW2#conf t
            SW2(config)#int vlan 6
            SW2(config-if)#ipv6 address ?
            WORD General prefix name
            X:X:X:X::X IPv6 link-local address
            X:X:X:X::X/<0-128> IPv6 prefix
            autoconfig Obtain address using autoconfiguration
            SW2(config-if)#ipv6 address autoconfig
            Notice that SW2 immediately sends an RS message asking for information about this segment:
            00:19:39: ICMPv6-ND: Sending RS on Vlan6
            00:19:39: ICMPv6-ND: Received RA from FE80::205:32FF:FE22:E442 on Vlan6
            00:19:39: ICMPv6-ND: Sending NS for 2001:CC1E:1:6:21D:45FF:FEC0:F443 on Vlan6
            00:19:39: ICMPv6-ND: Autoconfiguring 2001:CC1E:1:6:21D:45FF:FEC0:F443 on Vlan6
            00:19:40: ICMPv6-ND: DAD: 2001:CC1E:1:6:21D:45FF:FEC0:F443 is unique.
            00:19:40: ICMPv6-ND: Sending NA for 2001:CC1E:1:6:21D:45FF:FEC0:F443 on Vlan6
            00:19:40: ICMPv6-ND: Address 2001:CC1E:1:6:21D:45FF:FEC0:F443/64 is up on Vlan6
            It also receives the prefix, calcualtes its global unicast address and performs DAD. Now let's check the interface on SW2:
            SW2#show ipv6 interface
            Vlan6 is up, line protocol is up
            IPv6 is enabled, link-local address is FE80::21D:45FF:FEC0:F443
            2001:CC1E:1:6:21D:45FF:FEC0:F443, subnet is 2001:CC1E:1:6::/64 [PRE]
            valid lifetime 2591864 preferred lifetime 604664
            FF02::1
            FF02::2
            FF02::1:FFC0:F443
            MTU is 1500 bytes
            ICMP error messages limited to one every 100 milliseconds
            ICMP redirects are enabled
            ND reachable time is 30000 milliseconds
            ND advertised reachable time is 0 milliseconds
            ND advertised retransmit interval is 0 milliseconds
            ND router advertisements are sent every 200 seconds
            ND router advertisements live for 1800 seconds
            ND advertised default router preference is Medium
            Hosts use stateless autoconfig for addresses.
            Rack1SW2#
            There are several adjustments we can make on the timers. Let's look at R6:
            R6(config-if)#ipv6 nd ?
            advertisement-interval Send an advertisement interval option in RA's
            dad Duplicate Address Detection
            managed-config-flag Hosts should use DHCP for address config
            ns-interval Set advertised NS retransmission interval
            other-config-flag Hosts should use DHCP for non-address config
            prefix Configure IPv6 Routing Prefix Advertisement
            ra-interval Set IPv6 Router Advertisement Interval
            ra-lifetime Set IPv6 Router Advertisement Lifetime
            reachable-time Set advertised reachability time
            suppress-ra Suppress IPv6 Router Advertisements
            Here we can set various parameters such as the advertisement interval (200 seconds default) and the RA lifetime.
              IPv6: RIPng, traffic filters and split horizon
              R5, R6 and R7 all sit on the same LAN. R6 is also connected to R9. R5 must see this network between R6 and R9 with a next hop of R7, not R6. How can we do it?
              Well first we need to disable split horizon on R7. For IPv6 RIP, this is done under the routing process:
              IPeR7(config)#ipv6 router rip RIP6
              IPeR7(config-rtr)#no split-horizon
              Next we need to filter routing updates from R6. What do these RIPng packets look like? We can see through "debug ipv6 rip."
              IPeR5#debug ipv6 rip
              RIP Routing Protocol debugging is on
              IPeR5#
              *Nov 3 00:45:44.453: RIPng: response received from FE80::6 on FastEthernet0/0 for RIP6
              *Nov 3 00:45:44.453: src=FE80::6 (FastEthernet0/0)
              *Nov 3 00:45:44.453: dst=FF02::9
              *Nov 3 00:45:44.453: sport=521, dport=521, length=52
              *Nov 3 00:45:44.453: command=2, version=1, mbz=0, #rte=2
              *Nov 3 00:45:44.453: tag=0, metric=1, prefix=2001:200::/64
              *Nov 3 00:45:44.453: tag=0, metric=1, prefix=2001:96::/64
              Now we know the source and destination, we can create our filter:
              IPeR5(config)#ipv6 access-list RIP-FILTER
              IPeR5(config-ipv6-acl)#deny ipv6 FE80::6/128 FF02::9/128
              IPeR5(config-ipv6-acl)#permit ipv6 any any
              IPeR5(config-ipv6-acl)#int f0/0
              IPeR5(config-if)#ipv6 access-group RIP-FILTER in
              % Invalid input detected at '^' marker.
              Whoa! what gives!? This stupid things doesn't let me apply my ACL.
              IPeR5(config-if)#ipv6 acc?
              % Unrecognized command
              Well that's because traffic filtering in IPv6 uses a whole different syntax:
              IPeR5(config-if)#ipv6 traffic-filter RIP-FILTER in
              IPeR5(config-if)#
              BAM!
              Let's clear the route table then check our next hop:
              IPeR5#show ipv6 route rip | sec exclude Codes:
              IPv6 Routing Table - 7 entries
              R 2001:96::/64 [120/3]
              via FE80::7, FastEthernet0/0
              IPeR5#
                IPv6: Summarizing OSPFv3 addresses
                This is from IPexpert volume 1 section 22. We have to summarize the following routes:
                2020:100:100:2222::/64
                2020:100:100:2666::/64
                This is how I do it:
                1) Identify the hextet ( I don't know if this is a word, I derived it from octet) where we will summarize. This is the 4th hextet. So we know our subnet will be somewhere between /48 and /64.
                2) Break it down in binary:
                2222 = 0010 0010 0010 0010
                2666 = 0010 0110 0110 0110
                Converting hex to binary is easy because we just treat each digit in the IPv6 address as a 4 bit binary number by itself. Notice how all the 2's broke down to 0010.
                3) Find the common bits. I highlighted them in red below. We have 5 of them. We will use to get our mask.
                4) Set the rest if the bits to 0 and calculate the summary, convert to hex.
                summary = 0010 0000 0000 0000 = 2000
                5) Calculate subnet mask by adding the common bits to the lower of our subnet range. This means we add 5 to /48 which makes /53.
                So our summary address is 2020:100:100:2000::/53
                In OSPFv3 we would enter:
                R2(config)#ipv6 router ospf 1
                R2(config-rtr)#area 1 range 2020:100:100:2000::/53
                Check our other routers for the summary:
                R4#show ipv6 route | inc 53
                OI 2020:100:100:2000::/53 [110/129]
                  IPexpert Volume 1 Section 21 - IPv6, RIPng
                  This is not an extremely difficult lab but it did bring up some good troubleshooting. In it we have two RIPng processes running over each other, cisco12 and cisco275 are their names.
                  Here is the basic topology:
                  R1----R2====R5----R7
                  R2 and R5 have two connections, one via frame-relay, and another over an ipv6ip tunnel. RIPng process cisco275 runs from R7 to R5, and R5 to R2 over frame link. RIPng process cisco12 runs over the tunnel and R1 to R2.
                  After redistributing between the two processes on R5, R7 still cannot ping R1 even though it has a route. Both routes below belong to R1's loopbacks.
                  R7#show ipv6 route rip
                  R 2000:1:1:1100::/64 [120/5]
                  via FE80::21B:D5FF:FE0F:F358, FastEthernet0/0
                  R 2000:1:1:1111::/64 [120/5]
                  When we ping from R7 here is the debug on R1:
                  R1#debug ipv6 packet
                  IPv6 unicast packet debugging is on
                  R1#
                  *Sep 23 01:22:44.255: IPV6: source 2000:1:1:75::7 (FastEthernet0/0)
                  *Sep 23 01:22:44.255: dest 2000:1:1:1111::1
                  *Sep 23 01:22:44.259: traffic class 0, flow 0x0, len 100+14, prot 58, hops 62, forward to ulp
                  *Sep 23 01:22:44.259: IPV6: source 2000:1:1:1111::1 (local)
                  *Sep 23 01:22:44.259: dest 2000:1:1:75::7
                  *Sep 23 01:22:44.259: traffic class 0, flow 0x0, len 100+14, prot 58, hops 64, Route not found
                  Whats the ulp!? don't know right now...Let's check R2 since it is upstream from R1:
                  R2#show ipv6 route 2000:1:1:75::
                  R 2000:1:1:75::/64 [120/2]
                  via FE80::5, Serial0/1/0.1
                  R2 is learning the route but why isn't it sending it to R1? If we debug ipv6 rip on R2 we will see why:
                  *Oct 4 20:18:45.243: RIPng: response received from FE80::9664:1905 on Tunnel0 for cisco12
                  *Oct 4 20:18:45.243: src=FE80::9664:1905 (Tunnel0)
                  *Oct 4 20:18:45.243: dst=FF02::9
                  *Oct 4 20:18:45.243: sport=521, dport=521, length=132
                  *Oct 4 20:18:45.243: command=2, version=1, mbz=0, #rte=6
                  *Oct 4 20:18:45.243: tag=0, metric=4, prefix=FEC0:0:0:6419::/64
                  *Oct 4 20:18:45.243: tag=0, metric=4, prefix=2000:1:1:5500::/64
                  *Oct 4 20:18:45.243: tag=0, metric=4, prefix=2000:1:1:75::/64
                  *Oct 4 20:18:45.243: tag=0, metric=1, prefix=2000:1:1:25::/64
                  *Oct 4 20:18:45.243: tag=0, metric=4, prefix=2002:2:2:2::/64
                  *Oct 4 20:18:45.243: tag=0, metric=4, prefix=2000:1:1:7700::/64
                  *Oct 4 20:18:55.915: RIPng: response received from FE80::5 on Serial0/1/0.1 for cisco275
                  *Oct 4 20:18:55.915: src=FE80::5 (Serial0/1/0.1)
                  *Oct 4 20:18:55.915: dst=FF02::9
                  *Oct 4 20:18:55.915: sport=521, dport=521, length=192
                  *Oct 4 20:18:55.915: command=2, version=1, mbz=0, #rte=9
                  *Oct 4 20:18:55.915: tag=0, metric=1, prefix=FEC0:0:0:6419::/64
                  *Oct 4 20:18:55.915: tag=0, metric=1, prefix=2000:1:1:5500::/64
                  *Oct 4 20:18:55.915: tag=0, metric=1, prefix=2000:1:1:75::/64
                  *Oct 4 20:18:55.915: tag=0, metric=4, prefix=2000:1:1:25::/64
                  *Oct 4 20:18:55.919: tag=0, metric=2, prefix=2000:1:1:7700::/64
                  *Oct 4 20:18:55.919: tag=0, metric=4, prefix=2000:1:1:2222::/64
                  *Oct 4 20:18:55.919: tag=0, metric=4, prefix=2000:1:1:2200::/64
                  *Oct 4 20:18:55.919: tag=0, metric=4, prefix=2000:1:1:1100::/64
                  R2 is hearing two advertisements for 2000:1:1:75::/64, one is coming through the tunnel process cisco12 and the other is coming through the frame-relay cloud process cisco275.
                  R2 is installing the one from cisco275 because it has a lower metric and thus not advertising it to R1 because that's where process cisco12 is running.
                  We resolve this by redistributing between cisco12 and cisco275 on R2.
                  R2(config)#ipv6 router rip cisco12
                  R2(config-rtr)#redistribute rip cisco275 include-connected metric 3
                  R2(config-rtr)#ipv6 router rip cisco275
                  R2(config-rtr)#redistribute rip cisco12 include-connected metric 3
                  Now we have reachability:
                  R7#ping 2000:1:1:1111::1
                  Sending 5, 100-byte ICMP Echos to 2000:1:1:1111::1, timeout is 2 seconds:
                  Success rate is 100 percent (5/5), round-trip min/avg/max = 20/20/20 ms
                  R7#
                    IPV6 - OSPFv3, default route, RIPng, redistribution
                    This is the third of three ipv6 posts today. The others are below. Here we configure OSPFv3 over an nbma cloud, adevrtise a default route, and redistribute with RIPng.
                    Here is the topology:
                    |---RIPng---|-------OSPFv3 area 0---------|
                    [BB2]------[R5]---[FRAME]---[R1]---VLAN1001
                    Addressing:
                    R5-BB2 : 2001:192:10:1::/64
                    R1-R5 : 2001:CC1E:1:1515::/64
                    VLAN1001: FEC0:CC1E:1:1::/64
                    BB2 and R5 are doing RIPng (config not shown, it's easy enough!)
                    R5,R1 are doing OSPFv3, area 0 everywhere else.
                    Here is how I configured the neighbors over the FR cloud:
                    R1#show run int s1/0
                    interface Serial1/0
                    encapsulation frame-relay
                    ipv6 address 2001:CC1E:1:1515::1/64
                    ipv6 ospf neighbor FE80::CE01:9FF:FEE8:0
                    ipv6 ospf 1 area 0
                    frame-relay map ipv6 FE80::CE01:9FF:FEE8:0 105 broadcast
                    frame-relay map ipv6 2001:CC1E:1:1515::5 105 broadcast
                    R5#show run int s1/0
                    interface Serial1/0
                    ipv6 address 2001:CC1E:1:1515::5/64
                    ipv6 ospf neighbor FE80::CE00:9FF:FEE8:0
                    ipv6 ospf 1 area 0
                    frame-relay map ipv6 2001:CC1E:1:1515::1 501 broadcast
                    frame-relay map ipv6 FE80::CE00:9FF:FEE8:0 501 broadcast
                    Notice that I use the link-local address as the neighbor address.
                    R1#show ipv6 ospf neighbor
                    150.1.5.5 1 FULL/DR 00:01:44 5 Serial1/0
                    R1#
                    R5 is learning VLAN 1001:
                    R5#show ipv6 route ospf
                    O FEC0:CC1E:1:1::/64 [110/65]
                    via FE80::CE00:9FF:FEE8:0, Serial1/0
                    R5 is also learning some loopback networks from BB2 via RIP:
                    R 2001:205:90:31::/64 [120/2]
                    via FE80::CE02:9FF:FEE8:0, FastEthernet0/0
                    R 2001:220:20:3::/64 [120/2]
                    R 2001:222:22:2::/64 [120/2]
                    Task is to advertise default route to R1 via OSPFv3 without "default-information originate always" command. R5 should drop traffic unless it has a longer match. Sounds like a summary route, eh?! WRONG! we can't summarize intra-area, but we are allowed on static route...hmmm....We can point it to null and redistribute!
                    R5(config)#ipv6 route 0::/0 null0
                    R5(config-rtr)#redistribute static
                    Let's check R1:
                    R1#show ipv6 route ospf
                    R1#
                    Nothing!...well. The task says not to use the "default-information originate always" command. What if we leave off the always!
                    R5(config-rtr)#no redistribute static
                    R5(config-rtr)#default-information originate
                    OE2 ::/0 [110/1], tag 1
                    via FE80::CE01:9FF:FEE8:0, Serial1/0
                    There we go and we didn't need to redistribute static either. If you delete that default route to NULL, then the LSA disappears too!
                    So now R1 has a default route but BB2 still has no route back to VLAN1001. So we can redistribute into RIPng on R5:
                    R5(config)#ipv6 router rip RIPNG
                    R5(config-rtr)#redistribute ospf 1 metric 1
                    Ping from R1:
                    R1#ping 2001:205:90:31::1 source FEC0:CC1E:1:1::1
                    Sending 5, 100-byte ICMP Echos to 2001:205:90:31::1, timeo
                    Packet sent with a source address of FEC0:CC1E:1:1::1
                      IPv6 - Policy-based routing
                      Same topology as before but without the offset:
                      Three loopbacks on BB2 advertised through RIPng to R3:
                      2001:205:90:31::1
                      2001:220:20:3::1
                      2001:222:22:2::1
                      Here is a traceroute from VLAN38:
                      R3#trace
                      Protocol [ip]: ipv6
                      Target IPv6 address: 2001:205:90:31::1
                      Source address: FEC0:CC1E:1:38::3
                      Insert source routing header? [no]: no
                      Numeric display? [no]:
                      Timeout in seconds [3]:
                      Probe count [3]:
                      Minimum Time to Live [1]:
                      Maximum Time to Live [30]:
                      Priority [0]:
                      Port Number [33434]:
                      Tracing the route to 2001:205:90:31::1
                      1 FEC0:CC1E:1:35::5 28 msec 32 msec 32 msec
                      2 FEC0:CC1E:1:54::4 12 msec
                      FEC0:CC1E:1:45::4 60 msec
                      FEC0:CC1E:1:54::4 28 msec
                      3 2001:205:90:31::1 52 msec 72 msec 24 msec
                      R3#
                      Notice at step 2 of the trace we flip-flop between the two hops from R5. Let's use policy based routing to force traffic from VLAN38 to use the serial link to R4. On R5:
                      ipv6 access-list PBRv6
                      permit ipv6 FEC0:CC1E:1:38::/64 2001:205:90:31::/64
                      permit ipv6 FEC0:CC1E:1:38::/64 2001:220:20:3::/64
                      permit ipv6 FEC0:CC1E:1:38::/64 2001:222:22:2::/64
                      route-map PBRv6 permit 10
                      match ipv6 address PBRv6
                      set ipv6 default next-hop FEC0:CC1E:1:45::4
                      int s1/0.35
                      ipv6 policy route-map PBRv6
                      Do the trace again:
                      R3#trace
                      Protocol [ip]: ipv6
                      Probe count [3]:
                      Priority [0]:
                      1 FEC0:CC1E:1:35::5 20 msec 36 msec 24 msec
                      2 FEC0:CC1E:1:45::4 4 msec 80 msec 24 msec
                      3 2001:205:90:31::1 16 msec 40 msec 36 msec
                      R3#
                      Sweet. What if the link between R4 and R5 fails?
                      R5(config-subif)#int s1/1
                      R5(config-if)#shut
                      Now back to R3:
                      Protocol [ip]: ipv6
                      Probe count [3]:
                      Priority [0]:
                      1 FEC0:CC1E:1:35::5 48 msec 28 msec 44 msec
                      2 FEC0:CC1E:1:54::4 24 msec 88 msec 20 msec
                      3 2001:205:90:31::1 8 msec 64 msec 44 msec
                      R3#
                      Now we are using the frame relay link.
                        IPv6 - RIPng metric offset
                        Here is the topology, use whatever DLCI's and interfaces you want:
                        R4 is learning these routes from BB2:
                        via FE80::CE03:8FF:FE9C:0, FastEthernet2/0
                        The task is to force R5 to use the serial link instead of the frame-relay link to reach these networks. Let's look at R5 right now:
                        R5#show ipv6 route
                        R 2001:205:90:31::/64 [120/3]
                        via FE80::CE01:8FF:FE9C:0, Serial1/1
                        via FE80::CE01:8FF:FE9C:0, Serial1/0.54
                        R 2001:220:20:3::/64 [120/3]
                        R 2001:222:22:2::/64 [120/3]
                        As you can see it's currently load sharing between the two 3-hop routes. How can we make the serial link more preferred? We can use an offset. It's not like the offset in rip for ipv4, but it works similar:
                        R5(config)#int s1/0.54
                        R5(config-subif)#ipv6 rip RIPNG metric-offset 2
                        Now let's take a look at our routes:
                        R5#show ipv6 route
                        Trace from R3:
                        R3#trace 2001:205:90:31::1
                        1 FEC0:CC1E:1:35::5 24 msec 32 msec 32 msec
                        2 FEC0:CC1E:1:45::4 8 msec 44 msec 16 msec
                        3 2001:205:90:31::1 56 msec 16 msec 60 msec
                        R3#
                        Easy!
                        I first started out thinking offset-list but I ran into a couple issues. First you can't make ipv6 standard ACLs, at least I couldn't find a way. Then before attempting to use ipv6 prefix lists I thought I would check out what commands were available under an interface for RIPng:
                        R5(config-subif)#ipv6 rip RIPNG ?
                        default-information Configure handling of default route
                        enable Enable/disable RIP routing
                        metric-offset Adjust default metric increment
                        summary-address Configure address summarization
                        This is where I noticed the metric-offset. In addition there is no offset list under router config mode:
                        R5(config-subif)#ipv6 router rip RIPNG
                        R5(config-rtr)#?
                        default Set a command to its defaults
                        distance Administrative distance
                        distribute-list Filter networks in routing updates
                        exit Exit from IPv6 routing protocol configuration mode
                        maximum-paths Forward packets over multiple paths
                        no Negate a command or set its defaults
                        poison-reverse Poison reverse updates
                        port Port and multicast address
                        redistribute Redistribute IPv6 prefixes from another routing protocol
                        split-horizon Split horizon updates
                        timers Adjust routing timers
                          some IPv6 notes: frame relay, RIPng, default routes
                          I was doing an IPv6 lab today. Here are some issues I came across:
                          Issue #1:
                          Hub and spoke environment, hubs could ping spoke, spokes couldn't ping hub. Turns out I didn't have "ipv6 unicast-routing" on the hub or the other routers.
                          Issue #2:
                          IPv6 router wasn't get routes from the backbone. I didn't have IPv6 rip enabled on the loopbacks.
                          Issue #3:
                          Spoke wasn't getting routes from other spoke. I needed to turn of split horizon on the hub. This is turned off under the process as follows:
                          no split-horizon
                          Issue #4:
                          Default route wasn't getting propogated to downstream router. I need to have a metric for this route. Like this:
                          interface Serial1/0
                          ipv6 rip RIP6 default-information only metric 2
                            IPv6 - link local address, MAC to EUI-64 conversion
                            The fastest way to get a link local address is to configure an interface with the ipv6 enable command. For example:
                            R1(config)#int f0/0
                            R1(config-if)#ipv6 enable
                            What will the link local address be? Before we take a look, let's figure it out ourselves. First do a show interface:
                            R1#show int f0/0 | in add
                            Hardware is Gt96k FE, address is c200.0854.0000 (bia c200.0854.0000)
                            R1#
                            To convert this MAC address to a link-local using eui-64 format do the following:
                            1. MAC Address: c200.0854.0000
                            2. Insert FFFE in the middle: c200:08FF:FE54:0000
                            3 Flip the U/L bit: 7th bit from the left: c000:08FF:FE54:0000
                            4. Append the prefix FE80: FE80::c000:08FF:FE54:0000
                            5. Remove extra 0's: FE80::C000:8FF:FE54:0
                            Let's take a look:
                            R1#show ipv6 interface f0/0 | in link
                            IPv6 is enabled, link-local address is FE80::C000:8FF:FE54:0
                              IPv6 tunneling - gre ip
                              This example is going to use the same topology as IPv6 tunneling - IPv6IP. In this mode, the passenger protocol is IPv6, the carrier protocol is GRE and IPv4 is used as the transport.
                              Here is the network:
                              [R1]---[R2]---[R3]---[R4]
                              R1-R2: IPv6 network 2002:1:0:12::/64
                              R2-R3: IPv4 network 172.12.23.0/24
                              R3-R4: IPv6 network 2002:1:0:34::/64
                              Make sure you enable ipv6 unicast routing on R2 and R3:
                              R2(config)#ipv6 unicast-routing
                              R3(config)#ipv6 unicast-routing
                              Configuration is pretty much the same as ipv6ip except the mode is different. In fact, we don't even need to specify a mode as gre ip is the default. I will show it here just for clarity but note that it will probably not show up in the running-config:
                              R2(config)#int tunnel 1
                              R2(config-if)#description gre ip tunnel
                              R2(config-if)#ipv6 address 2002:2:0:23::2/64
                              R2(config-if)#tunnel source 172.12.23.2
                              R2(config-if)#tunnel destination 172.12.23.3
                              R2(config-if)#tunnel mode gre ip
                              R3(config)#int tunnel 1
                              R3(config-if)#description gre ip tunnel
                              R3(config-if)#ipv6 address 2002:2:0:23::3/64
                              R3(config-if)#tunnel source 172.12.23.3
                              R3(config-if)#tunnel destination 172.12.23.2
                              R3(config-if)#tunnel mode gre ip
                              Let's add the static routes:
                              R2(config)#ipv6 route 2002:1:0:34::/64 Tunnel1
                              R3(config)#ipv6 route 2002:1:0:12::/64 Tunnel1
                              Verify:
                              R1#ping 2002:1:0:34::4
                              Sending 5, 100-byte ICMP Echos to 2002:1:0:34::4, timeout is 2 seconds:
                              Success rate is 100 percent (5/5), round-trip min/avg/max = 44/70/88 ms
                              R2#debug tunnel
                              Tunnel Interface debugging is on
                              R2#
                              *Mar 1 01:09:12.999: Tunnel1: GRE/IP encapsulated 172.12.23.2->172.12.23.3 (linktype=79, len=124)
                              *Mar 1 01:09:13.095: Tunnel1: GRE/IP to classify 172.12.23.3->172.12.23.2 (len=124 type=0x86DD ttl=254 tos=0x0)
                              Some of the benefits of this mode are that GRE tunnels can carry more than just IPv6. At work, we sometimes use them for multicast and some other non-IP traffic, we even use them to route normal IP packets to default destinations across VPN clouds.
