  • Xử lý khi EIGRP quảng bá các tuyến đường với một Unexpected Metric
    Cấu hình như sau:
    Router A# interface ethernet 0
    interface serial 0
    ip address 172.16.2.1 255.255.255.0
    interface serial 1
    ip address 172.16.3.1 255.255.255.0
    router eigrp 1
    network 172.16.0.0
    Router B# interface ethernet 0
    ip address 172.16.6.1 255.255.255.0
    interface serial 0
    ip address 172.16.2.2 255.255.255.0
    interface serial 1
    ip address 172.16.4.1 255.255.255.0
    router eigrp 1
    network 172.16.0.0
    Router C# interface ethernet 0
    ip address 172.16.5.1 255.255.255.0
    interface serial 0
    ip address 172.16.4.2 255.255.255.0
    interface serial 1
    ip address 172.16.3.2 255.255.255.0
    router eigrp 1
    network 172.16.0.0
    offset-list 1 out 600000 serial 1
    access-list 1 permit 172.16.0.0 0.0.255.255
    Router_A#show ip route 172.16.5.0
    Routing entry for 172.16.5.0/24
    Known via "eigrp 1", distance 90, metric 2707456, type internal
    Redistributing via eigrp 1
    Last update from 172.16.2.2 on Serial0, 01:08:13 ago
    Routing Descriptor Blocks:
    *172.16.2.2, from 172.16.2.2, 01:08:13 ago, via Serial0
    Route metric is 2707456, traffic share count is 1
    Total delay is 41000 microseconds, minimum bandwidth is 1544 Kbit
    Reliability 255/255, minimum MTU 1500 bytes
    Loading 1/255, Hops 2
    Router A# show ip eigrp topology 172.16.5.0 255.255.255.0IP-EIGRP topology
    State is Passive, Query origin flag is 1, 1 Successor(s), FD is 2707456
    Routing Descriptor Blocks: 172 .16.2.2 (Serial0), fr om 172. 16.2.2, Send flag is 0x0
    Composite metric is (2707456/2195456), Route is Internal
    Vector metric:
    Minimum bandwidth is 1544 Kbit
    Reliability is 255/255
    Load is 1/255
    Minimum MTU is 1500
    Hop count is 2
    172.16.3.2 (Serial1), from 172.16.3.2, Send flag is 0x0
    Composite metric is (2795456/281600), Route is Internal
    Vector metric:
    Total delay is 44437 microseconds
    Load is 1/255
    Minimum MTU is 1500
    Hop count is 1
    Cho thấy Router A chọn Router B là next hop để đi đến Router C vì Router B có metric lớn hơn so với Router C. Nhìn vào topology cho thấy đường dẫn đến Router C có chậm trễ hơn so với các đường dẫn đến Router B, nhưng tất cả các liên kết là liên kết T1. các cổng cấu hình trong Router C không cho thấy bất kỳ giá trị chậm trễ cấu hình bằng tay.
    Offset-list trong Router C add thêm một metric 600.000 đến tuyến đường đi trong Serial1. Đây là nguyên nhân của vấn đề. Các giá trị offset thêm tăng giá trị delay khi Router C gửi các tuyến đường đến Router A.
    Giải pháp: Giải pháp là để loại bỏ các offset-list được cấu hình trên Router C. Để loại bỏ các offset-list, cấu hình Router C như sau:
    Router C# config term
    Router_C(config)#router eigrp 1
    Router_C(config-router)#no offset-list 1 out 600000 serial 1
    Nguyễn Minh Hải – VnPro
    Phan Trung Tín
    Email: phantrungtin@vnpro.org
    Fax: (028) 35124314
    Forum: http://www.vnpro.org
