  • Bài viết về CCNP PPP callback
    Bài viết CCNP PPP callback
    Trong bài lab này, hai router có tên là dung và chau sẽ thực hiện ppp callback.
    dung#sh run
    Current configuration:
    version 12.0
    service timestamps log uptime
    hostname dung
    username chau password 0 cisco
    ip subnet-zero
    no ip domain-lookup
    chat-script DUNG ABORT ERROR ABORT BUSY "" "ATZ" OK "ATDT \T" TIMEOUT 30 CONNECT \c
    interface Loopback0
    ip address 1.1.1.1 255.255.255.0
    no ip directed-broadcast
    interface Async1
    ip address 192.168.8.3 255.255.255.0
    encapsulation ppp
    dialer in-band
    dialer callback-secure
    dialer idle-timeout 300
    dialer enable-timeout 10
    dialer wait-for-carrier-time 60
    dialer map ip 192.168.8.1 name chau class dialback modem-script DUNG broadcast 204
    dialer hold-queue 50
    dialer-group 1
    async mode dedicated
    no cdp enable
    ppp callback accept
    ppp authentication chap
    ip classless
    ip route 0.0.0.0 0.0.0.0 192.168.8.1
    no ip http server
    map-class dialer dialback
    dialer callback-server username
    transport input none
    line aux 0
    modem InOut
    modem autoconfigure discovery
    transport input all
    stopbits 1
    speed 38400
    flowcontrol hardware
    password cisco
    login
    dung#sh ver
    IOS (tm) 2500 Software (C2500-I-L), Version 12.0(5)T, RELEASE SOFTWARE (fc1)
    Copyright (c) 1986-1999 by cisco Systems, Inc.
    Compiled Fri 23-Jul-99 03:14 by kpma
    Image text-base: 0x03039754, data-base: 0x00001000
    ROM: System Bootstrap, Version 5.2(5), RELEASE SOFTWARE
    BOOTFLASH: 3000 Bootstrap Software (IGS-RXBOOT), Version 10.2(5), RELEASE SOFTWARE (fc1)
    dung uptime is 2 hours, 7 minutes
    System returned to ROM by reload
    System image file is "flash:c2500-i-mz_120-5_T.bin"
    cisco 2500 (68030) processor (revision D) with 16384K/2048K bytes of memory.
    Processor board ID 02095691, with hardware revision 00000000
    Bridging software.
    X.25 software, Version 3.0.0.
    1 Ethernet/IEEE 802.3 interface(s)
    2 Serial network interface(s)
    32K bytes of non-volatile configuration memory.
    8192K bytes of processor board System flash (Read ONLY)
    Configuration register is 0x2102
    Đây là cấu hình router chau:
    show run
    version 12.0
    service udp-small-servers
    service tcp-small-servers
    hostname chau
    username dung password 7 060506324F41
    ip subnet-zero
    chat-script chau ABORT ERROR ABORT BUSY "" "ATZ" OK "ATDT \T" TIMEOUT 30 CONNECT \c
    process-max-time 200
    interface Loopback0
    no ip route-cache
    no ip mroute-cache
    interface Loopback1
    ip address 192.168.216.1 255.255.255.0
    no ip route-cache
    no ip mroute-cache
    interface Ethernet0
    ip address 10.0.0.2 255.255.255.0
    no ip route-cache
    no ip mroute-cache
    interface Async1
    ip address 192.168.8.1 255.255.255.0
    encapsulation ppp
    no ip route-cache
    no ip mroute-cache
    dialer in-band
    dialer map ip 192.168.8.3 name dung modem-script chau broadcast 203
    dialer-group 1
    ppp callback request
    ip classless
    no ip http server
    line aux 0
    modem InOut
    transport input all
    stopbits 1
    speed 38400
    login
    chau#show ver
    ROM: System Bootstrap, Version 11.0(10c), SOFTWARE
    BOOTFLASH: 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c), RELEASE SOFTWARE (fc1)
    chau uptime is 19 minutes
    cisco 2500 (68030) processor (revision L) with 14336K/2048K bytes of memory.
    Processor board ID 08370517, with hardware revision 00000000
    Bridging software.
    2 Ethernet/IEEE 802.3 interface(s)
    chau#
    Tác giả: Đặng Quang Minh
