  • [Try cadidate CCIE] Một câu hỏi nhỏ về STP
    Imagine a simple topology made of 3 switches:
    All switches are running STP for VLAN123 with SW3 being the root. Your task is to configure the network in such a way so that SW1 port fa0/13 is the root port and SW1 port fa0/16 is the alternate port for VLAN 123. Sound easy? Here are the requirements:
    1) Do not change any STP link cost
    2) SW3 must remain the root for VLAN 123
    3) The port types must be access
    4) Do not use the switchport backup interface command
    5) Do not try to use SPAN or RSPAN
    6) Do not disable STP
    Trần Mỹ Phúc
    tranmyphuc@hotmail.com
    Juniper Certs :
    JNCIP-ENT & JNCIP-SEC
    [version 4.0] Ôn tập CCNA
    Có phải là dùng Dot1q tunnel for SPT trên SW2 không, tuy nhiên vẫn chưa test thử nhưng về mặc theory thì ok ? Không tìm thấy cách nào khác ????
    > Ping CCNA
    Sending to CISCO.....Please wait.....
    Cho thuê CCIE LAB RS & SEC online giá rẻ đây (250k/6h for RS & 350k/6h for SEC)
    RS: R2611, R1841, SW3550/3560
    SEC: R2611, R2811, ASA5510 (Sec plus), IPS4235, SW3560
    Timeslots (GMT+7) - Vietnam (8h00 - 7h50+1)
    TS1.VN : 08h00 - 13h50
    TS2.VN : 14h00 - 19h50
    TS3.VN : 20h00 - 01h50
    TS4.VN : 02h00 -07h50
    Mọi chi tiết xin liên hệ vulevy (at) yahoo (dot) fr
      ko ai có bài trả lời à. anh admin giải đáp đi :D
        i think this is the answer:
        change bandwidth value on F0/16(SW1) to 10000 (10Mbps)
          Hi,
          Correct Solution :
          1) Configure SW2 to tunnel STP BPDUs between SW1 and SW3. This will make SW1 thinking that that SW3 is directly connected with cost 19. STP is still active on SW2, but SW2 considers itself the root.
          SW2:
          interface FastEthernet 0/13
          l2protocol-tunnel stp
          interface FastEthernet 0/16
          2) Configure SW3 port Fa0/16 with lower STP priority than SW3 Fa 0/13. This will make SW1 select its connection to SW2 as the root port and the other uplink is alternate: both uplinks have equal costs, the upstream port priority is the tiebreaker.
          SW3:
          spanning-tree port-priority 64
          Theories for it :
          Attach files
          Thanks for reading my topic
          Trần Mỹ Phúc
          Juniper Certs :
            bai viet rat hay. cam on admin
