R1(config)#do sh run
Current configuration : 1142 bytes
version 12.3
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
ip audit po max-events 100
interface Loopback0
no keepalive
interface Tunnel0
ip mtu 1400
ip ospf mtu-ignore
tunnel source 192.168.3.1
tunnel destination 192.168.3.2
tunnel path-mtu-discovery
interface Serial1/0
serial restart-delay 0
interface Serial1/1
shutdown
interface Serial1/2
shutdown
interface Serial1/3
shutdown
router ospf 1
log-adjacency-changes
network 172.16.1.0 0.0.0.255 area 0
network 192.168.3.0 0.0.0.255 area 0
ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
exec-timeout 0 0
logging synchronous
line aux 0
login
R3#sh run
Current configuration : 1105 bytes
version 12.3
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
interface Loopback0
ip address 172.16.2.1 255.255.255.0
no keepalive
interface Tunnel0
ip address 192.168.3.2 255.255.255.0
ip mtu 1400
ip ospf mtu-ignore
tunnel source 192.168.3.2
tunnel destination 192.168.3.1
interface Serial1/0
interface Serial1/1
shutdown
interface Serial1/2
shutdown
interface Serial1/3
shutdown
router ospf 1
network 172.16.2.0 0.0.0.255 area 0
ip http server
ip classless
exec-timeout 0 0
logging synchronous
line aux 0
login
lỗi thông báo là:
R1(config)#
*Mar 1 00:02:48.519: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel0, changed state to up
R1(config)#
*Mar 1 00:02:57.519: %TUN-5-RECURDOWN: Tunnel0 temporarily disabled due to recursive routing
*Mar 1 00:02:58.519: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel0, changed state to down
lỗi này tương tự trên R3
version 12.3
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
interface Loopback0
no keepalive
interface Tunnel0
ip mtu 1400
ip ospf mtu-ignore
interface Serial1/0
interface Serial1/1
shutdown
interface Serial1/2
shutdown
interface Serial1/3
shutdown
router ospf 1
ip http server
ip classless
exec-timeout 0 0
logging synchronous
line aux 0
login
R3#sh run
version 12.3
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
interface Loopback0
no keepalive
interface Tunnel0
ip mtu 1400
ip ospf mtu-ignore
interface Serial1/0
interface Serial1/1
shutdown
interface Serial1/2
shutdown
interface Serial1/3
shutdown
router ospf 1
ip http server
ip classless
exec-timeout 0 0
logging synchronous
line aux 0
login
lỗi thông báo là:
R1(config)#
R1(config)#
