PPPoE và PPPoA
  • PPPoE và PPPoA
    Mấy cao thủ cho tớ hỏi,PPPoA và PPPoE chẳng qua chỉ là 2 cách đóng gói qua mạng ATM thôi hay nó còn có nguyên nhân khác để người ta sử dụng 2 kiểu đóng gói này?
    Vì tớ thấy,nếu CPE được cấu hình là PPPoA client thì ko có thêm mấy cái vụ discovery server (Aggregation router) làm j cho mệt(discovery stage).Vậy sao ko config hết là PPPoA đi,đẻ thêm cái thằng PPPoE làm chi?
    Hoặc là cũng có thể là do router ko phải lúc nào cũng sẵn cổng ATM,nhưng thấy vậy cũng ko có vẻ ok lắm.
    Ai giải thích hộ tớ chút
    sống trên đời cần có một tấm lòng.....để làm j em biết không?.....để gió cuốn đi.......
    Welcome to my blog.....www.360.yahoo.com/longphi11
    PPPOA or PPPoA, Point-to-Point Protocol (PPP) over ATM, is a network protocol for encapsulating PPP frames in ATM AAL5. It is used mainly with cable modem, DSL and ADSL services.
    It offers standard PPP features such as authentication, encryption, and compression. If it is used as the connection encapsulation method on an ATM based network it can reduce overhead slightly (around 0.58%) in comparison to PPPoE. It also avoids the issues that PPPoE suffers from, related to having a MTU lower than that of standard Ethernet transmission protocols. It also supports (as does PPPoE) the encapsulation types: VC-MUX and LLC based.
    PPPoA is specified in RFC 2364.
    PPPoE, Point-to-Point Protocol over Ethernet, is a network protocol for encapsulating PPP frames inside Ethernet frames. It is used mainly with ADSL services where individual users connect to the ADSL transceiver (modem) over ethernet. It was developed by UUNET, Redback Networks, and RouterWare and has been standardized in RFC 2516.
    Ethernet networks are packet-based and have no concept of a connection or circuit. But using PPPoE, users can virtually "dial" from one machine to another over an ethernet network, establish a point to point connection between them and then transport data packets over the connection.
    Trịnh Anh Luân
    - Search my site
    - Search VNPRO.ORG
    • Phát hành sách chuyên môn
      hello Long Phi ở Hanoi*** !
      ***PPPoA:
      Khi máy tính đầu cuối của người dùng trang bị card giao tiếp theo giao tiếp ATm (ATM NIC) kết nối trực tiếp vào thiết bị của nhà cung cấp dịch vụ.Ưu điểm của PPPoA là sử dụng băng thông tối ưu trong kết nối end-to-end.
      Trong PPPoA thì BRAS (Broadband Remote Access Server)cho phép kết nối đến các ISP khác nhau thông qua các thông tin địa chỉ IP,domain,v,v... PPP sẽ xác thực để thực hiện kết nối cho người dùng đến ISP cần thiết.
      ****PPPoE
      Cũng giống như PPPoA nhưng thiết bị đầu cuối của người dùng sẽ kết nối với thiết bị mạng của ISP bằng giao tiếp mạng Ethernet thông qua DSL modem.Trong PPPoE thì chỉ cho phép user chỉ kết nối được đến 1 ISP ( khác với PPPoA thì có thể chọn ISP )
      >>>>Như vậy thông thường thì ngày nay đa số điều chọn PPPoE vì khả năng DSLAM có thể kết nối với nhiều user hơn trên với PPP.
