  • Anh em cùng tham khảo LAB cấu hình DMVPN nào!!!
    MÔ HÌNH:
    Hình3.3: Mô hình Lab DMVPN
    Các bước thực hiện cho cấu hình:
    Bước 1: Cấu hình cho các Router thấy nhau
    Spoke1:
    spoke1(config)# interface f0/0
    spoke1(config-if)# ip address 172.30.1.1 255.255.255.0
    spoke1(config-if)# no shutdown
    spoke1(config)# interface f0/1
    spoke1(config-if)# ip address 192.168.1.1 255.255.255.0
    spoke1(config-if)# exit
    spoke1(config)# ip route 0.0.0.0 0.0.0.0 172.30.1.2
    Spoke2:
    Spoke2(config)# interface f0/0
    Spoke2(config-if)# ip address 172.30.3.1 255.255.255.0
    Spoke2(config-if)# no shutdown
    Spoke2(config)# interface f0/1
    Spoke2(config-if)# ip address 192.168.2.1 255.255.255.0
    Spoke2(config-if)# exit
    Spoke2(config)# ip route 0.0.0.0 0.0.0.0 172.30.3.2
    Hub
    hub(config)# interface f0/0
    hub(config-if)# ip address 172.30.2.1 255.255.255.0
    hub(config-if)# no shutdown
    hub(config)# interface loop back 0
    hub(config-if)# ip address 192.168.0.1 255.255.255.0
    hub(config-if)# exit
    hub(config)# ip route 0.0.0.0 0.0.0.0 172.30.2.2
    Thực hiện cấu hình đối với spoke1
    Bước 2: Cấu hình phase 1 cho spoke1
    Spoke1(config)# crypto isakmp enable
    Spoke1(config)# crypto isakmp policy 1
    Spoke1(config-isakmp)# authentication pre-share
    Spoke1(config-isakmp)# hash md5
    Spoke1(config-isakmp)#encryption des
    Spoke1(config-isakmp)# exit
    Spoke1(config)# crypto isakmp key cisco47 address 172.30.2.1
    Bước 3: Cấu hình DMVPN cho spoke1
    Spoke1(config)# interface tunnel 0
    Spoke1(config-if)# ip address 10.0.0.2 255.255.255.0
    Spoke1(config-if)# ip mtu 1400
    Spoke1(config-if)# ip hold-time eigrp 1 35
    Spoke1(config-if)# no ip next-hope-self eigrp 1
    Spoke1(config-if)#ip nhrp authentication cisco47
    Spoke1(config-if)# ip nhrp map 10.0.0.1 172.30.2.1
    Spoke1(config-if)# ip map multicast 172.30.2.1
    Spoke1(config-if)# ip nhrp nhs 10.0.0.1
    Spoke1(config-if)# ip nhrp network-id 100
    Spoke1(config-if)# no ip split-horizon eigrp 1
    Spoke1(config-if)# tunnel source f0/0
    Spoke1(config-if)# tunnel key 1000
    Spoke1(config-if)# tunnel mode gre multipoint
    Spoke1(config-if)# tunnel protection ipsec profile dmvpn
    Bước 4: Cấu hình phase 2 cho spoke1
    spoke1(config)# crypto ipsec transform-set myset esp-des
    spoke1(config)# crypto ipsec profile dmvpn
    spoke1(config)# crypto map dmvpn local-address f0/0
    spoke1(config)# crypto map dmvpn 10 ipsec-isakmp
    spoke1(config-crypto-map)# set peer 172.30.2.1
    spoke1(config-crypto-map)# set security-association level per-host
    spoke1(config-crypto-map)# set transform-set myset
    spoke1(config-crypto-map)# match address 101
    spoke1(config-crypto-map)#exit
    spoke1(config)# access-list 101 permit gre 172.30.1.0 0.0.0.255 host 172.30.2.1
    Bước 5: Định tuyến dùng giao thức EIGRP
    spoke1(config)# router eigrp 1
    spoke1(config-router)# network 10.0.0.0 0.0.0.255
    spoke1(config-router)# network 192.168.1.0 0.0.0.255
    spoke1(config-router)# no auto-summary
    Thực hiện cấu hình đối với spoke2
    Bước 2: Cấu hình phase 1 cho spoke2
    Spoke2(config)# crypto isakmp enable
    Spoke2(config)# crypto isakmp policy 1
    Spoke2(config-isakmp)# authentication pre-share
    Spoke2(config-isakmp)# hash md5
    Spoke2(config-isakmp)# exit
    Spoke2(config)# crypto isakmp key cisco47 address 172.30.2.1
    Bước 3: Cấu hình DMVPN cho spoke2
    Spoke2(config)# interface tunnel 0
    Spoke2(config-if)# ip address 10.0.0.3 255.255.255.0
    Spoke2(config-if)# ip mtu 1400
    Spoke2(config-if)#ip nhrp authentication cisco47
    Spoke2(config-if)# ip nhrp map 10.0.0.1 172.30.2.1
    Spoke2(config-if)# ip nhrp hold-time 600
    Spoke2(config-if)# ip nhrp nhs 10.0.0.1
    Spoke2(config-if)# no ip next-hope-self eigrp 1
    Spoke2(config-if)# ip map multicast 172.30.2.1
    Spoke2(config-if)# ip nhrp network-id 100
    Spoke2(config-if)# tunnel source f0/0
    Spoke2(config-if)# tunnel key 1000
    Spoke2(config-if)# tunnel mode gre multipoint
    Spoke2(config-if)# tunnel protection ipsec profile dmvpn
    Bước 4: Cấu hình phase 2 cho spoke2
    spoke2(config)# crypto ipsec transform-set myset esp-des
    spoke2(config)# crypto map dmvpn local-address f0/0
    spoke2(config)# crypto map dmvpn 10 ipsec-isakmp
    spoke2(config-crypto-map)# set peer 172.30.2.1
    spoke2(config-crypto-map)# set security-association level per-host
    spoke2(config-crypto-map)# set transform-set myset
    spoke2(config-crypto-map)# match address 101
    spoke2(config-crypto-map)#exit
    spoke2(config)# access-list 101 permit gre 172.30.3.0 0.0.0.255 host 172.30.2.1
    Spoke2(config)# router eigrp 1
    Spoke2(config-router)# network 10.0.0.0 0.0.0.255
    Spoke2(config-router)# network 192.168.2.0 0.0.0.255
    Spoke2(config-router)# no auto-summary
    Thực hiện cấu hình cho HUB
    Hub(config)# crypto isakmp enable
    Hub(config)# crypto isakmp policy 1
    Hub(config- isakmp)# authentication pre-share
    Hub(config- isakmp)# hash md5
    Hub(config- isakmp)#encryption des
    Hub(config- isakmp)#exit
    Hub(config)# crypto isakmp key cisco47 address 0.0.0.0
    Hub(config)# crytpo ipsec transform-set myset esp-des
    # Tạo ipsec profile
    Hub(config)# crypto ipsec profile dmvpn
    Hub(config-profile)# set transform-set myset
    # Tạo tunnel
    Hub(config)# interface tunnel 0
    Hub(config-if)# ip address 10.0.0.1 255.255.255.0
    Hub(config-if)# ip mtu 600
    Hub(config-if)# ip nhrp authentication cisco47
    Hub(config-if)# ip nhrp multicast dynamic
    Hub(config-if)# ip nhrp hold-time 600
    Hub(config-if)# tunnel source f0/0
    Hub(config-if)# tunnel mode gre multipoint
    Hub(config-if)# tunnel key 1000
    Hub(config-if)# tunnel protection ipsec profile dmvpn
    # Định tuyến dùng giao thức EIGRP
    Hub(config)# router eigrp 1
    Hub(config-router)# network 10.0.0.0 0.0.0.255
    Hub(config-router)# network 192.168.0.0 0.0.0.255
    Hub(config-router)# no auto-summary
    Lâm Văn Tú
    Email :
    cntt08520610@gmail.com
    Fax (08) 35124314
    Tập tành bước đi....
