Các bác giúp em với : :p
Câu 1: A hay D
After update BIOS, the computer display a STOP erron message whenever you attempt to restart the computer and you are unable to successfully start the computer. What should do ?
a. Use System Restore to restore the last point
b. Restart the computer with Last Know Good configuration
c. Use the Recovery console to add the correct Advanced configuration and Power interface (ACPI) HAL the computer
d. Reinstalls Windows XP to enable Advanced configuration and Power interface (ACPI) and Power management support
=> Khong biet cau nao la dung nhat.Sau khi update BIOS, nếu máy bị lỗi thì bác giải quyết ra sao? A hay D hả các bác
=>Không boot được thì sao dùng System Restore hả bác
Câu 2: A hay B
Your company has a domain-based Active Directory a network. You have to deploy WinXP on 150 new computers
Vivian, a trainee, assists you in deploying Windows XP Professional. You create a new domain user account for him and add it to the Domain Users group. Vivian is able to install Windows XP Professional on the new computers, but he is unable to add them to the Active Directory domain. You verify that the computers are connected to the network and are receiving their IP address from the DHCP server.
You realize that lack of proper privilege is the cause of the problem. As a security precaution, you do not want Vivian to have any extra privileges on the network.
What will you do to ensure that Vivian is able to add the new computers to the Active Directory domain?
a.Use the Delegation of Control wizard to grant Vivian’s domain user account the Create Computer Objects privilege for Computers container.
b. On a domain controller, give "Add workstation to a domain" privilege to Vivan's user account through the Local Computer Policy MMC
c.Install the Active Directory Users and Computers MMC on Vivian’s Windows XP Professional computer. Add Vivian’s domain user account to the Domain Administrators group.
d. Add Vivian’s domain user account to the Server Operators group.
=>A hay B ?
Nếu chọn câu A sẽ cho user nhiều quyền hơn
(giải thích của chương trình test : This will enable her to create any object in computer container)
=>Các bác cho em ý kiến với
Câu 1: A hay D
Câu 2: A hay B
=>A hay B ?
