  • Xem số Serial cho Router 2611
    Chào mọi người,
    Xin hướng dẫn cách xem Serial và Partnumber trong Router 2611 bằng lệnh gì? Mình đã thử sh diag rồi nhưng ko có.
    Cảm ơn!
    The show diag command returns the following information about a router and its adaptors/modules:
    * Hardware version
    * Board revision
    * RMA number and history
    * Chassis serial number
    * Cisco field replaceable unit (FRU) number (a good identifiable part number for the device)
    * Cisco part number (the actual part number of the device)
    * Technical registers of the backplane, including power supply and temperature status (not readable by this command)
    * Ports built into the motherboard of the device
    * Hardware versions, serial numbers, and part numbers for WIC cards in the device
    * Part numbers, port information, and serial numbers for network modules (NMs) inserted in the device
    Sao lại ko có ta,bạn show và xem kỹ lại thử nhé,
    Hugo
      Cảm ơn ThanhNam0707, minh gửi log ban xem dùm nha:
      Slot 0:
      C2611XM 2FE Mainboard Port adapter, 4 ports
      Port adapter is analyzed
      Port adapter insertion time unknown
      EEPROM contents at hardware discovery:
      Hardware Revision : 1.0
      PCB Serial Number : JAD065202VY (3422221982)
      Part Number : 73-7679-02
      RMA History : 00
      RMA Number : 0-0-0-0
      Board Revision : A0
      Deviation Number : 0-0
      Product (FRU) Number : C2611XM-2FE
      EEPROM format version 4
      EEPROM contents (hex):
      0x00: 04 FF 40 03 6B 41 01 00 C1 18 4A 41 44 30 36 35
      0x10: 32 30 32 56 59 20 28 33 34 32 32 32 32 31 39 38
      0x20: 32 29 82 49 1D FF 02 04 00 81 00 00 00 00 42 41
      0x30: 30 80 00 00 00 00 FF FF FF FF FF FF FF FF FF FF
      0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      WIC Slot 0:
      Serial 2T (12in1)
      Hardware revision 1.0 Board revision D0
      Serial number 26007172 Part number 800-03181-01
      FRU Part Number WIC-2T=
      Test history 0x0 RMA number 00-00-00
      Connector type PCI
      EEPROM format version 1
      0x20: 01 12 01 00 01 8C D6 84 50 0C 6D 01 00 00 00 00
      0x30: 68 00 00 00 00 10 12 00 FF FF FF FF FF FF FF FF
        cái router bạn view đc part number,ko view Chassis Serial Number,mà chỉ view PCB Serial Number là serial của motherboard,
        bạn thử show ver,thấy dòng Processor board ID ... là serial của router,
        hoặc dùng lệnh: show diag | inc Serial để view đc nhiều thông tin serial hơn,
        Hugo
          Cảm ơn thanhnam0707,
          Mình đã dùng show version và Pocessor board ID vẫn là: JAD065202VY nhưng bên Cisco lại nói là ko có số serial number này.
          Mong bạn hướng dẫn thêm. Nhân tiện cho mình hỏi, ở Vietnam muốn tìm dịch vụ sửa, bảo trì Router thì tìm ở đâu, liên lạc với ai?
