  • Không ping được card mạng PC
    Em có problem sau:
    PC cài win XP Pro. Ngồi tại máy tính, ping địa chỉ card mạng của máy tính không được, nhưng ping default gateway thì được. Ngồi trên router cũng vậy, chỉ có thể ping được cổng E0 của router chứ không ping được card mạng của PC.
    Xin các anh, chị chỉ em troubleshoot problem này. Xin cám ơn
    Sau đây là quá trình ping:
    c:\>ping 127.0.0.1
    Pinging 127.0.0.1 with 32 bytes of data:
    Reply from 127.0.0.1: bytes=32 time<1ms TTL=128
    Ping statistics for 127.0.0.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
    c:\>ping 192.168.216.2
    Pinging 192.168.216.2 with 32 bytes of data:
    Request timed out.
    Request timed out.
    Request timed out.
    Request timed out.
    Ping statistics for 192.168.216.2:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
    c:\>ping 192.168.216.1
    Pinging 192.168.216.1 with 32 bytes of data:
    Reply from 192.168.216.1: bytes=32 time=2ms TTL=255
    Ping statistics for 192.168.216.1:
    Minimum = 2ms, Maximum = 2ms, Average = 2ms
    c:\>ipconfig /all
    Windows IP Configuration
    Host Name . . . . . . . . . . . . : PC
    Primary Dns Suffix . . . . . . . :
    Node Type . . . . . . . . . . . . : Unknown
    IP Routing Enabled. . . . . . . . : No
    WINS Proxy Enabled. . . . . . . . : No
    Ethernet adapter Local Area Connection:
    Connection-specific DNS Suffix . :
    Description . . . . . . . . . . . : CNet PRO200 PCI Fast Ethernet Adapter
    Physical Address. . . . . . . . . : 00-08-A1-25-82-77
    Dhcp Enabled. . . . . . . . . . . : No
    IP Address. . . . . . . . . . . . : 192.168.216.2
    Subnet Mask . . . . . . . . . . . : 255.255.255.0
    Default Gateway . . . . . . . . . : 192.168.216.1
    NetBIOS over Tcpip. . . . . . . . : Disabled
    c:\>route print
    Interface List
    0x1 ........................... MS TCP Loopback interface
    0x2 ...00 08 a1 25 82 77 ...... CNet PRO200 PCI Fast Ethernet Adapter - Packet Scheduler Miniport
    Active Routes:
    Network Destination Netmask Gateway Interface Metric
    0.0.0.0 0.0.0.0 192.168.216.1 192.168.216.2 30
    127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
    192.168.216.0 255.255.255.0 192.168.216.2 192.168.216.2 30
    192.168.216.2 255.255.255.255 127.0.0.1 127.0.0.1 30
    192.168.216.255 255.255.255.255 192.168.216.2 192.168.216.2 30
    224.0.0.0 240.0.0.0 192.168.216.2 192.168.216.2 30
    255.255.255.255 255.255.255.255 192.168.216.2 192.168.216.2 1
    Default Gateway: 192.168.216.1
    Persistent Routes:
    None
    Router#ping 192.168.216.1
    Sending 5, 100-byte ICMP Echos to 192.168.216.1, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 4/4/4 ms
    Router#ping 192.168.216.2
    Sending 5, 100-byte ICMP Echos to 192.168.216.2, timeout is 2 seconds:
    Router#
    paste running hay startup lên luôn đi tuaninbox. bạn cấu hình router thế nào?
      Mình chỉ mới cấu hình có cổng E0 của router thôi, chưa làm gì khác cả.
        bạn đang chạy một personal firewall trong win XP. tắt fw đi.
        nếu không, bạn disable tính năng fw sẵn có trong winXP xem.
        cuối cùng, netmask của ethernet0 đã bị cấu hình sai.
          con router này có do bạn cấu hình từ đầu ko hay trước đó đã có ai cấu hình rồi?
