  • AOMEI Dynamic Disk Manager Pro 1.1.0.0
    Aomei Dynamic Disk Manager Pro Edition is an advanced application that includes Dynamic Volume Management, Disk Conversion and a Step-by-Step Wizard to offer you full control over your PC.
    It enables you to resize/move/shrink/extend dynamic volume to maximize disk space usage, extend dynamic system volume to solve low disk space problem on C drive, convert dynamic disk to basic and vice versa without losing data, fix GPT Protective Partition problem by converting GPT disk to MBR, convert MBR disk to GPT for creating volumes larger than 2TB, add drive to RAID 0 and remove drive from RAID 0 to adjust (extend and shrink) RAID 0 volume, move volume slices from one disk to another, etc.
    Here are some key features of "Aomei Dynamic Disk Manager Pro Edition":
    Dynamic Volume Management:
    · Create/Delete/Format all types of dynamic volume easily.
    · Resize dynamic disk without losing data for better computer performance.
    · Extend dynamic system volume to solve "low disk space on C drive" problem.
    · Shrink dynamic volume to free up some unallocated space for further usage.
    · Move slice to change the location of volume flexibly on the same disk.
    · Move/Adjust simple volume and spanned volume among disks.
    · Change drive letter to identify a volume.
    · Change volume label for easier recognition.
    Disk Converter:
    · Convert dynamic disk to basic disk without losing data.
    · Convert basic disk to dynamic disk safely and quickly.
    · Convert GPT disk to MBR disk and ensure data integrity.
    · Convert basic disk between MBR and GPT.
    · Initialize disk as MBR or GPT.
    Step-by-Step Wizard:
    · Create Volume Wizard allows you to configure dynamic disk easily.
    · Add Drive to RAID for capacity expansion and better read & write performance.
    · Remove Drive from RAID to shrink volume and redistribute free space.
    · Move Volume Slice Wizard help relocate dynamic volume in other disks.
    Homepage:
    http://www.dynamic-disk.com/
    Links: Turbobit.net
    http://turbobit.net/2s4osl5ui4u2.html
    Links: Uploaded.net
    http://uploaded.net/file/iqkgvgom
    Links: Extabit.com
    http://extabit.com/file/28wcl0fnet6dk
