Yêu cầu đề bài:
Bài tập Case study 1 cho môn học CCNP Switching
Support Forum: http://www.vnpro.org- Chuyên đào tạo quản trị mạng và hạ tầng Internet
Blog: http://www.vnpro.org/blogTags: None
RE: Bài tập Case study 1 cho môn học CCNP Switching
Cấu hình cho các thiết bị
Core Layer Switch:
Current configuration : 2547 bytes
version 12.1
no service pad
service timestamps log uptime
hostname CLswitchB
ip subnet-zero
ip routing
no ip domain-lookup
spanning-tree mode pvst
interface FastEthernet0/1
switchport trunk encapsulation dot1q
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
switchport access vlan 10
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
switchport access vlan 20
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
switchport access vlan 30
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
no switchport
ip address 172.16.2.1 255.255.255.0
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
switchport mode trunk
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
interface Vlan10
ip address 172.16.10.1 255.255.255.0
interface Vlan20
ip address 172.16.20.1 255.255.255.0
interface Vlan30
ip address 172.16.30.1 255.255.255.0
router eigrp 100
network 172.16.0.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
ip http server
password cisco
logging synchronous
login
password cisco
login
line vty 5 15
password cisco
login
endEmail : vnpro@vnpro.org
Distribution Layer Switch 1:
Current configuration : 2971 bytes
version 12.1
no service pad
hostname DLswitch
ip subnet-zero
spanning-tree vlan 1 priority 24576
interface Port-channel1
interface Port-channel2
interface Port-channel3
channel-group 1 mode desirable
channel-group 2 mode desirable
channel-group 3 mode desirable
interface Vlan1
ip address 172.16.1.2 255.255.255.0
interface Vlan10
interface Vlan20
interface Vlan30
ip classless
ip http server
password cisco
logging synchronous
login
no login
line vty 5 15
no login
Cấu hình NAT router:
Current configuration:
version 12.0
hostname NAT
enable secret 5 $1$Qnlw$YUqWx9ZlXjoRsefRIFScz.
ip subnet-zero
no ip domain-lookup
ip host net 200.200.200.254
ip host sb 172.16.2.1
interface Ethernet0
ip address 172.16.2.254 255.255.255.0
no ip directed-broadcast
ip nat inside
interface Serial0
bandwidth 64
ip address 200.200.200.1 255.255.255.0
ip nat outside
no ip mroute-cache
no fair-queue
interface Serial1
shutdown
interface BRI0
shutdown
router eigrp 100
redistribute static
router eigrp 100
redistribute static
network 172.16.0.0
ip nat pool khanh 200.200.200.18 200.200.200.30 netmask 255.255.255.240
ip nat inside source list 1 pool khanh overload
ip classless
ip route 0.0.0.0 0.0.0.0 200.200.200.254
access-list 1 permit 172.16.0.0 0.0.255.255
logging synchronous
transport input none
line aux 0
privilege level 15
password cisco
login
Cấu hình EtherChannel trên Access layer Switch
Switch(config)#hostname Switch1
Switch1(config)#int f0/1
Switch1(config-if)#switchport trunk encapsulation dot1q
Switch1(config-if)#switchport mode trunk
Switch1(config-if)#channel-group 1 mode ?
auto Enable PAgP only if a PAgP device is detected
desirable Enable PAgP unconditionally
on Enable Etherchannel only
Switch1(config-if)#channel-group 1 mode desirable
Creating a port-channel interface Port-channel1
Switch1(config)#int f0/2
Switch1(config-if)#exit
Switch1#sh vtp st
VTP Version : 2
Configuration Revision : 1
Maximum VLANs supported locally : 1005
Number of existing VLANs : 5
VTP Operating Mode : Client
VTP Domain Name : cisco
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0x18 0x28 0x12 0x2B 0x91 0x41 0xBB 0xE3
Configuration last modified by 0.0.0.0 at 3-1-93 00:01:16
Switch1#sh etherchannel summary
Flags: D - down P - in port-channel
I - stand-alone s - suspended
R - Layer3 S - Layer2
u - unsuitable for bundling
U - port-channel in use
d - default port
Group Port-channel Ports
1 Po1(SU) Fa0/1(D) Fa0/2(P)
Switch1#sh ru
Current configuration : 2293 bytes
version 12.1
no service pad
hostname ALswitch1
ip subnet-zero
interface Vlan1
ip address 172.16.1.3 255.255.255.0
ip classless
ip http server
password cisco
login
no login
line vty 5 15
no login
