  • Lab 15-4: Cấu hình Sparse mode động
    Mô tả
    Ta sử dụng sơ đò sau
    Cấu hình:
    Host1 và Host2 Tương tự như trên
    R2
    hostname R2
    enable password cisco
    ip subnet-zero
    no ip domain-lookup
    ip host R3 192.168.1.18
    ip host host1 192.168.3.2
    ip host R5 192.168.1.6
    ip host R4 192.168.1.14
    ip host R2 192.168.1.22
    ip host R1 192.168.1.1
    ip multicast-routing
    interface Loopback0
    ip address 192.168.4.1 255.255.255.255
    interface Ethernet0
    ip pim sparse-mode
    interface Serial0
    ip address 192.168.1.17 255.255.255.252
    ip pim sparse-mode
    no ip mroute-cache
    clockrate 64000
    interface Serial1
    ip address 192.168.1.22 255.255.255.252
    ip pim sparse-mode
    no ip mroute-cache
    clockrate 64000
    router ospf 1
    log-adjacency-changes
    network 0.0.0.0 255.255.255.255 area 0
    ip classless
    ip pim spt-threshold infinity
    ip pim send-rp-announce Loopback0 scope 50
    End
    R3
    hostname R3
    no ip domain-lookup
    interface Loopback0
    ip address 192.168.4.3 255.255.255.255
    ip pim sparse-mode
    interface Ethernet0/0
    ip address 192.168.1.2 255.255.255.252
    ip pim sparse-mode
    interface Serial0/0
    ip address 192.168.1.13 255.255.255.252
    ip pim sparse-mode
    no fair-queue
    clockrate 64000
    interface Serial0/1
    ip address 192.168.1.18 255.255.255.252
    ip pim sparse-mode
    interface Ethernet1/1
    ip pim sparse-mode
    router ospf 1
    ip classless
    ip pim send-rp-discovery Loopback0 scope 10
    R4
    hostname R4
    ip subnet-zero
    no ip domain-lookup
    ip dvmrp route-limit 20000
    interface Loopback0
    ip address 192.168.4.2 255.255.255.255
    no ip directed-broadcast
    interface Ethernet0
    ip address 192.168.1.5 255.255.255.252
    ip pim sparse-mode
    no ip mroute-cache
    interface Serial1
    ip address 192.168.1.14 255.255.255.252
    ip pim sparse-mode
    no ip mroute-cache
    router ospf 1
    ip classless
    End
    R5#show run
    hostname R5
    no ip domain lookup
    interface Loopback0
    ip address 131.108.4.1 255.255.255.0
    interface FastEthernet0/0
    ip address 192.168.1.6 255.255.255.252
    ip pim sparse-mode
    no ip mroute-cache
    no keepalive
    duplex auto
    speed auto
    interface FastEthernet0/1
    ip pim sparse-mode
    no ip mroute-cache
    duplex auto
    speed auto
    router ospf 1
    router rip
    version 2
    network 131.108.0.0
    ip classless
    End
    Show ip mroute
    R2# show ip mroute
    IP Multicast Routing Table
    Flags: D - Dense, S - Sparse, C - Connected, L - Local, P - Pruned
    R - RP-bit set, F - Register flag, T - SPT-bit set, J - Join SPT
    M - MSDP created entry, X - Proxy Join Timer Running
    A - Advertised via MSDP
    Outgoing interface flags: H - Hardware switched
    Timers: Uptime/Expires
    Interface state: Interface, Next-Hop or VCD, State/Mode
    (*, 224.0.1.39), 00:02:59/00:02:59, RP 0.0.0.0, flags: DP
    Incoming interface: Null, RPF nbr 0.0.0.0
    Outgoing interface list: Null
    (192.168.4.2, 224.0.1.39), 00:02:59/00:00:00, flags: PT
    Incoming interface: Serial0, RPF nbr 192.168.1.18
    (*, 224.0.1.40), 00:03:10/00:00:00, RP 0.0.0.0, flags: DJCL
    Serial0, Forward/Sparse, 00:03:10/00:00:00
    (192.168.4.3, 224.0.1.40), 00:02:26/00:02:33, flags: PCLT
    (*, 227.1.1.1), 00:02:57/00:02:59, RP 192.168.4.2, flags: SJC
    Ethernet0, Forward/Sparse, 00:02:57/00:02:40
    (192.168.2.3, 227.1.1.1), 00:00:27/00:02:32, flags: CJT
    Ethernet0, Forward/Sparse, 00:00:27/00:02:40
    (*, 228.0.0.1), 00:03:09/00:02:59, RP 192.168.4.2, flags: SJC
    Ethernet0, Forward/Sparse, 00:03:09/00:02:38
    (192.168.2.3, 228.0.0.1), 00:03:04/00:02:25, flags: CJT
    Ethernet0, Forward/Sparse, 00:03:04/00:02:37
    R5#show ip mroute
    Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
    L - Local, P - Pruned, R - RP-bit set, F - Register flag,
    T - SPT-bit set, J - Join SPT, M - MSDP created entry,
    X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
    U - URD, I - Received Source Specific Host Report, s - SSM
    (*, 224.0.1.39), 00:00:10/00:02:49, RP 0.0.0.0, flags: DC
    FastEthernet0/1, Forward/Sparse, 00:00:10/00:02:49
    (*, 224.0.1.40), 00:00:28/00:00:00, RP 0.0.0.0, flags: DCL
    FastEthernet0/0, Forward/Sparse, 00:00:28/00:02:56
    (192.168.4.3, 224.0.1.40), 00:00:15/00:02:44, flags: CLT
    Incoming interface: FastEthernet0/1, RPF nbr 192.168.2.1
    FastEthernet0/0, Forward/Sparse, 00:00:15/00:02:56
    (*, 227.1.1.1), 00:00:27/00:02:59, RP 192.168.4.2, flags: SCF
    Incoming interface: FastEthernet0/0, RPF nbr 192.168.1.5
    FastEthernet0/1, Forward/Sparse, 00:00:27/00:02:41
    (192.168.2.3, 227.1.1.1), 00:00:27/00:02:32, flags: CFT
    Incoming interface: FastEthernet0/1, RPF nbr 0.0.0.0
    FastEthernet0/0, Forward/Sparse, 00:00:27/00:03:03
    (*, 228.0.0.1), 00:00:19/00:03:29, RP 192.168.4.2, flags: SCF
    FastEthernet0/1, Forward/Sparse, 00:00:19/00:03:29
    (192.168.2.3, 228.0.0.1), 00:00:18/00:03:20, flags: CFT
    FastEthernet0/0, Forward/Sparse, 00:00:18/00:03:11
    Kiểm tra:
    ping từ Host1 đến host2 ta có
    R5#debug ip mpacket
    IP multicast packets debugging is on
    R5#
    *Mar 1 01:25:02.483: IP: s=192.168.3.2 (FastEthernet0/1) d=227.1.1.1 (FastEthernet0/0) len 114, mforward
    *Mar 1 01:25:04.483: IP: s=192.168.3.2 (FastEthernet0/1) d=227.1.1.1 (FastEthernet0/0) len 114, mforward
    *Mar 1 01:25:05.555: %PIM-4-DEPRECATED_HELLO_TLV: Deprecated PIM Hello Option TLV 19 (Bidir TLV) from 192.168.2.1 (FastEthernet0/1)
    *Mar 1 01:25:06.487: IP: s=192.168.3.2 (FastEthernet0/1) d=227.1.1.1 (FastEthernet0/0) len 114, mforward
    *Mar 1 01:25:08.491: IP: s=192.168.3.2 (FastEthernet0/1) d=227.1.1.1 (FastEthernet0/0) len 114, mforward
    *Mar 1 01:25:10.491: IP: s=192.168.3.2 (FastEthernet0/1) d=227.1.1.1 (FastEthernet0/0) len 114, mforward
    R2#
    01:28:21: IP: s=192.168.3.2 (Ethernet0) d=227.1.1.1 (Serial0) len 114, mforward
    01:28:23: IP: s=192.168.3.2 (Ethernet0) d=227.1.1.1 (Serial0) len 114, mforward
    01:28:25: IP: s=192.168.3.2 (Ethernet0) d=227.1.1.1 (Serial0) len 114, mforward
    01:28:27: IP: s=192.168.3.2 (Ethernet0) d=227.1.1.1 (Serial0) len 114, mforward
    01:28:29: IP: s=192.168.3.2 (Ethernet0) d=227.1.1.1 (Serial0) len 114, mforward
