This is a sticky topic.
  • Cấu hình ADSL trên Cisco 2600 dùng card ADSL WIC-
    Xin chào,
    Cấu hình ADSL cho Cisco 2620 dùng card WAN-ADSL cho mạng ADSL tại Việt Nam. Cấu hình dưới đây là một working configs.
    Trong cấu hình này, chú ý cách dùng load-balancing trên leased-line và đường ADSL dùng policy-routing. Ngoài ra, chú ý cách gán MAC address của FE cho interface ATM. Cool tips!
    Các bạn có thể tham khảo cấu hình này khi triển khai mạng ADSL tại Việt Nam.
    Chúc các bạn thành công,
    Minh
    logging buffered 4096 debugging
    enable secret 5 $1$7Nax$CUzFyEsXdb
    username thuan privilege 15 password 7 083141
    clock timezone GMT 7
    ip subnet-zero
    vpdn enable
    vpdn-group pppoe
     request-dialin
      protocol pppoe
    mta receive maximum-recipients 0
    interface ATM0/0
     mac-address 000d.65f9.d1f0
     no atm ilmi-keepalive
     dsl operating-mode auto
     hold-queue 224 in
    interface ATM0/0.1 point-to-point
     pvc 0/33
    interface FastEthernet0/0
     ip address 210.245.47.3 255.255.255.248
     ip nat inside
     ip tcp adjust-mss 1452
     ip policy route-map balance
     duplex auto
     speed auto
    interface Serial0/0
     bandwidth 256
     ip address 203.210.184.250 255.255.255.252
    interface FastEthernet0/1
     ip address 192.168.11.5 255.255.255.0
     duplex auto
     speed auto
    interface Serial0/1
     shutdown
     clockrate 2000000
    interface Virtual-Template1
    interface Dialer1
     ip address negotiated
     ip mtu 1492
     ip nat outside
     encapsulation ppp
     dialer pool 1
     no fair-queue
     ppp authentication pap callin
     ppp pap sent-username asp0105 password 0 pmh0105
    ip nat inside source list 102 interface Dialer1 overload
    ip classless
    ip route 0.0.0.0 0.0.0.0 Serial0/0
    ip route 210.245.47.0 255.255.255.248 210.245.47.4
    ip http server
    access-list 101 permit ip host 210.245.47.1 any
    access-list 101 permit ip host 210.245.47.2 any
    access-list 102 permit ip host 210.245.47.6 any
    route-map balance permit 10
     match ip address 101
     set ip next-hop 203.210.184.249
    route-map balance permit 20
     match ip address 102
     set interface Dialer1
    call rsvp-sync
    mgcp profile default
    dial-peer cor custom
    line 65 72
     flush-at-activation
    line aux 0
     password 7 03145603575D72
     login
    R3745_FL13#
    RE: Cấu hình ADSL trên Cisco 2600 dùng card ADSL WIC-
    Chào anh! Em không hiểu vấn đề cấu hình ADSL tai sao lai liên quan đến ATM.
    Cuộc đời như gió như ngàn cơn sóng, khi buồn khi vui.
      Vì do tính chất của ADSL thôi mà. Nó sử dụng ATM làm môi trường truyền dẫn từ DSLAM đến ISP
      Nothing Else Matter !
        Chào Tâm! Vậy em có biết hiện nay ở VIỆT NAM ISP nào không sử dụng ATM cho kết nối DSLAM tới ISP ko. Và Vpc sao lại là 0/33
        Không cần biết em là ai
        Ta yeu em chua bao gio nguoi lanh
        Yeu em vi chi biet do la em.
          ATM thường được dùng từ tổng đài DSLAM đến ISP vì dễ dàng triễn khai QOS (dv mới đây của VNN cam kết tốc độ Maxium va Minimum trên ADSL từ 1/7/2005)
          To be number 1 !!!
            dưới đây là cấu hình PPPoE server dùng Cisco router:
            sh run
            Current configuration : 1202 bytes
            version 12.1
            no service single-slot-reload-enable
            service timestamps log uptime
            hostname RAS
            no logging buffered
            logging rate-limit console 10 except errors
            username vnpro password 0 vnpro
            username Client password 0 cisco
            ip cef
            vpdn enable
            no vpdn logging
            vpdn-group 1
            accept-dialin
            protocol pppoe
            virtual-template 1
            interface Loopback0
            interface Ethernet0/0
            half-duplex
            pppoe enable
            ip unnumbered Loopback0
            ip mtu 1492
            no ip route-cache cef
            peer default ip address pool dsl
            ppp authentication chap
            ip local pool dsl 10.0.0.2 10.0.0.10
            ip kerberos source-interface any
            ip classless
            no ip http server
            snmp-server packetsize 4096
            snmp-server manager
            RAS#sh ip route
            10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
            C 10.0.0.2/32 is directly connected, Virtual-Access1
            C 10.0.0.0/24 is directly connected, Loopback0
            RAS#
              Cấu hình router 2600 với card WIC-1T-ADSL chế độ PPPoE client:
              Client#show run
              hostname Client
              ip subnet-zero
              no ip domain lookup
              vpdn enable
              vpdn-group 1
              request-dialin
              protocol pppoe
              interface ATM0/0
              mac-address 0005.5e96.2cc0
              pvc 8/35
              encapsulation aal5snap
              no fair-queue
              ip address 11.0.0.1 255.0.0.0
              no keepalive
              half-duplex
              interface Dialer1
              mtu 1492
              encapsulation ppp
              dialer pool 1
              dialer-group 1
              ppp authentication chap callin
              ppp chap hostname Client
              ppp chap password 0 cisco
              ip classless
              ip http server
              Client#show int dsl atm 0/0
              Alcatel 20150 chipset information
              ATU-R (DS) ATU-C (US)
              Modem Status: Showtime (DMTDSL_SHOWTIME)
              DSL Mode: ITU G.992.1 (G.DMT)
              ITU STD NUM: 0x01 0x1
              Vendor ID: 'ALCB' 'GSPN'
              Vendor Specific: 0x0000 0x0004
              Vendor Country: 0x00 0x00
              Capacity Used: 83% 107%
              Noise Margin: 11.5 dB 7.0 dB
              Output Power: 8.0 dBm 10.0 dBm
              Attenuation: 0.0 dB 4.0 dB
              Defect Status: None None
              Last Fail Code: Error in early non-CRC message or in first CRC-covered message
              Selftest Result: 0x00
              Subfunction: 0x15
              Interrupts: 2671 (0 spurious)
              PHY Access Err: 0
              Activations: 3
              SW Version: 3.8129
              FW Version: 0x1A04
              Interleave Fast Interleave Fast
              Speed (kbps): 8064 0 800 0
              Reed-Solomon EC: 5 0 134 0
              CRC Errors: 2 0 1 0
              Header Errors: 2 0 0 0
              Bit Errors: 0 0
              BER Valid sec: 0 0
              BER Invalid sec: 0 0
              DMT Bits Per Bin
              00: 0 0 0 0 0 0 0 8 8 8 9 A B B C C
              10: C C C C C C B B A A A 9 9 9 0 0
              20: 0 0 0 0 0 0 6 7 7 8 8 8 9 9 9 A
              30: A A A A A A B B B B B B B B B B
              40: 0 B B B B B B B B B B B B B B B
              50: B B B B B B B B B B B B 2 B B B
              60: B B B B B B B B B B B B B B B B
              70: B B B B B B B B B B B B B B B B
              80: B B B B B B B B B B B B B B B B
              90: B B B B B B B B B B B B B B B B
              A0: B B B B B B B B B B B B B B B B
              B0: B B B B B B B B B B B B B B B B
              C0: B B B B B B B B B B B B B B A A
              D0: A A A A A A A A A A A A A A A A
              E0: A A A A A A A A A A 9 9 9 8 8 7
              F0: 6 6 5 4 3 0 0 0 0 0 0 0 0 0 0 0
              DSL: Training log buffer capability is not enabled
              Client#show int atm 0/0
              ATM0/0 is up, line protocol is up
              Hardware is DSLSAR (with Alcatel ADSL Module)
              MTU 4470 bytes, sub MTU 4470, BW 800 Kbit, DLY 2560 usec,
              Encapsulation ATM, loopback not set
              Encapsulation(s): AAL5 AAL2, PVC mode
              23 maximum active VCs, 256 VCs per VP, 1 current VCCs
              VC idle disconnect time: 300 seconds
              Last input 00:00:01, output 00:00:03, output hang never
              Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
              Queueing strategy: fifo
              Output queue :0/40 (size/max)
              5 minute input rate 1000 bits/sec, 1 packets/sec
              968 packets input, 346594 bytes, 0 no buffer
              Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
              0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
              134 packets output, 10992 bytes, 0 underruns
              0 output errors, 0 collisions, 9 interface resets
              0 output buffer failures, 0 output buffers swapped out
              Client#show ip int brief
              ATM0/0 unassigned YES unset up up
              ATM0/0.1 unassigned YES unset up up
              Ethernet0/0 11.0.0.1 YES manual up up
              Serial0/0 unassigned YES unset administratively down down
              Virtual-Access1 unassigned YES unset up up
              Dialer1 10.0.0.2 YES BOOTP up up
              Client#ping 10.0.0.1
              Sending 5, 100-byte ICMP Echos to 10.0.0.1, timeout is 2 seconds:
              Success rate is 100 percent (5/5), round-trip min/avg/max = 40/42/44 ms
                các bạn ơi, mình muốn cấu hình VPN trên Wic-1ADSL cho Router 1760, nhưng em không biết IOS nào hỗ trợ hai tính năng trên, đã ai cấu hình như thế chưa, cho mình xin IOS của nó nhé, Thanhks
                  cho em hỏi mô hình của bài lab này là thế nào? Có cần phải có thiêt bị gì để làm DSLAM ko? Hay là PPPoE Client nối trực tiếp vào PPPoE Server? Nếu vậy thì cắm dây thế nào?
                  Nếu như router của em ko có Wic-ADSL, em phải chuyển modem ADSL thành mode nào để có thể config PPPoE Client trên router?
                  Thanks
                    Nhờ các bạn xem giúp : mình đang cấu hình C2650M, wic adsl - alcatel như bên dưới nhưng không chạy được.
                    ATM0/0, ATM0/0.1 báo như bên dưới.
                    Cảm ơn,
                    C2650M#sh run
                    Current configuration : 1497 bytes
                    version 12.4
                    service password-encryption
                    hostname C2650M
                    boot-start-marker
                    boot-end-marker
                    enable secret 5 $1$/IMn$LPLJLAsZ/3KRqJ2rUTQpB.
                    resource policy
                    no aaa new-model
                    memory-size iomem 15
                    no network-clock-participate slot 1
                    no network-clock-participate wic 0
                    ip subnet-zero
                    no ip dhcp use vrf connected
                    ip dhcp pool DHCP
                    network 192.168.2.0 255.255.255.0
                    dns-server 203.162.0.181
                    default-router 192.168.2.1
                    ip cef
                    vpdn enable
                    password encryption aes
                    bba-group pppoe global
                    interface ATM0/0
                    pvc 0/33
                    description LAN
                    ip nat inside
                    ip virtual-reassembly
                    duplex auto
                    speed auto
                    interface Serial0/1
                    shutdown
                    interface Dialer1
                    mtu 1492
                    ip nat outside
                    encapsulation ppp
                    dialer pool 1
                    no fair-queue
                    ppp chap hostname Dsl-inf2
                    ppp chap password 7 014254570F5E50
                    ppp pap sent-username congdh password 7 11584B5643475D
                    ip classless
                    no ip http server
                    no ip http secure-server
                    control-plane
                    line aux 0
                    password 7 011A12095A05
                    login
                    C2650M#
                    pvc 0/33
                    description LAN
                    ip nat inside
                    duplex auto
                    speed auto
                    interface Serial0/1
                    shutdown
                    interface Dialer1
                    mtu 1492
                    ip nat outside
                    encapsulation ppp
                    dialer pool 1
                    ppp chap password 0 123456
                    ppp pap sent-username Dsl-inf2 password 0 123456
                    ip classless
                    no ip http server
                    control-plane
                    line aux 0
                    password itman
                    login
                    C2650M#
                    ATM0/0 is initializing, line protocol is down
                    MTU 4470 bytes, sub MTU 4470, BW 512 Kbit, DLY 1000 usec,
                    reliability 0/255, txload 1/255, rxload 1/255
                    23 maximum active VCs, 256 VCs per VP, 0 current VCCs
                    VC Auto Creation Disabled.
                    Last input never, output never, output hang never
                    Queueing strategy: Per VC Queueing
                    0 packets input, 0 bytes, 0 no buffer
                    0 packets output, 0 bytes, 0 underruns
                    0 output errors, 0 collisions, 0 interface resets
                    ATM0/0.1 is initializing, line protocol is down
                    MTU 4470 bytes, BW 512 Kbit, DLY 1000 usec,
                    Encapsulation ATM
                    0 OAM cells input, 0 OAM cells output
                    AAL5 CRC errors : 0
                    AAL5 SAR Timeouts : 0
                    AAL5 Oversized SDUs : 0
                    What is LOVE ?
                      Đoạn này bị sai nè:
                        Client#show run
                        hostname Client
                        ip subnet-zero
                        no ip domain lookup
                        vpdn enable
                        vpdn-group 1
                        request-dialin
                        protocol pppoe
                        interface ATM0/0
                        pvc 8/35
                        no fair-queue
                        no keepalive
                        half-duplex
                        interface Dialer1
                        mtu 1492
                        encapsulation ppp
                        dialer pool 1
                        dialer-group 1
                        ip classless
                        ip http server
                        Subfunction: 0x15
                        PHY Access Err: 0
                        Activations: 3
                        SW Version: 3.8129
                        FW Version: 0x1A04
                        CRC Errors: 2 0 1 0
                        Bit Errors: 0 0
                        BER Valid sec: 0 0
                        DMT Bits Per Bin
                        Dear Mr. Minh,
                        Mình làm theo bài này thì khi tới lệnh int ATM, nó báo lỗi, vậy con router của mình ko support ADSL hả ?
                          Router đang dùng là router gì? Đang gắn modem vào cổng Ethernet phải không?
                            mình đang dùng router 1800, đúng vậy, modem gắn vào cổng f0/1 của router, còn cổng f0/0 gắn vào Lan.
                              Client#sh run
                              Current configuration : 1596 bytes
                              version 12.2
                              hostname Client
                              ip subnet-zero
                              vpdn enable
                              vpdn-group 1
                              request-dialin
                              protocol pppoe
                              ip address 10.10.10.10 255.255.255.0
                              ip nat inside
                              interface Loopback1
                              half-duplex
                              pppoe enable
                              interface Dialer1
                              mtu 1492
                              ip nat outside
                              encapsulation ppp
                              dialer pool 1
                              dialer-group 1
                              ip nat inside source list 1 interface Dialer1 overload
                              ip classless
                              ip route 0.0.0.0 0.0.0.0 203.106.10.1
                              ip http server
                              access-list 1 permit 10.10.10.0 0.0.0.255
