This is a sticky topic.
  • Bài viết FR with Tunnel
    CONFIGURATION DOCUMENT
    A. LAB DIAGRAM
    B. CONFIGURATION
    Configuration on Router R1 :
    Current configuration : 1060 bytes
    version 12.2
    service timestamps log uptime
    hostname R1
    frame-relay switching
    interface Tunnel0
    ip address 192.168.1.5 255.255.255.252
    tunnel source FastEthernet0/0
    tunnel destination 192.168.1.2
    interface Tunnel2
    ip address 192.168.1.22 255.255.255.252
    tunnel source Serial0/1
    tunnel destination 192.168.1.14
    interface FastEthernet0/0
    ip address 192.168.1.1 255.255.255.252
    duplex auto
    speed auto
    interface Serial0/0
    encapsulation frame-relay
    no fair-queue
    clockrate 64000
    frame-relay intf-type dce
    frame-relay route 16 interface Tunnel0 16
    frame-relay route 17 interface Tunnel2 17
    interface Serial0/1
    ip address 192.168.1.13 255.255.255.252
    ip classless
    ip http server
    line aux 0
    login
    Configuration on Router R2:
    Current configuration:
    version 12.0
    hostname R2
    ip subnet-zero
    interface Tunnel1
    ip address 192.168.1.18 255.255.255.252
    no ip directed-broadcast
    tunnel source Ethernet0/0
    tunnel destination 192.168.1.10
    interface Tunnel2
    ip address 192.168.1.21 255.255.255.252
    tunnel source Serial0/0
    tunnel destination 192.168.1.13
    interface Ethernet0/0
    ip address 192.168.1.9 255.255.255.252
    interface Serial0/0
    ip address 192.168.1.14 255.255.255.252
    no ip mroute-cache
    no fair-queue
    clockrate 64000
    interface Serial0/1
    logging event subif-link-status
    logging event dlci-status-change
    clockrate 64000
    frame-relay route 18 interface Tunnel1 18
    ip classless
    transport input none
    line aux 0
    login
    no scheduler allocate
    Configuration on Router R7:
    Current configuration : 1747 bytes
    version 12.2
    hostname R7-3600
    enable password cisco
    call rsvp-sync
    interface Tunnel0
    ip address 192.168.1.6 255.255.255.252
    interface Tunnel1
    ip address 192.168.1.17 255.255.255.252
    tunnel source FastEthernet0/1
    tunnel destination 192.168.1.9
    ip address 192.168.1.2 255.255.255.252
    duplex auto
    speed auto
    interface FastEthernet0/1
    ip address 192.168.1.10 255.255.255.252
    duplex auto
    speed auto
    interface Serial1/3
    clockrate 64000
    line aux 0
    password cisco
    login
    Configuration on R3:
    version 12.0
    hostname R3
    ip subnet-zero
    interface Serial1
    ip address 172.16.1.3 255.255.255.0
    ip classless
    logging synchronous
    line aux 0
    login
    Configuration on R5:
    version 12.0
    hostname R5
    ip subnet-zero
    interface Serial1
    ip address 172.16.1.5 255.255.255.0
    ip classless
    line aux 0
    login
    Configuration on R6:
    version 12.0
    hostname R6
    ip subnet-zero
    interface Serial0
    ip address 172.16.1.4 255.255.255.0
    no ip mroute-cache
    no fair-queue
    interface Serial1
    shutdown
    ip classless
    logging synchronous
    line aux 0
    login
    RE: Bài viết FR with Tunnel
    Nếu có hai router 2500 mỗi router có 2 cổng serials, có thể kết hợp với nhau để làm một FrameRelay Switch có 4 cổng serials. Hai router sẽ nối với nhau qua cổng Ethernet, sau đó tạo một tunnel trên kết nối Ethernet này.
    Cấu hình chi tiết như sau:
    FRSwitch 2:
    sh run
    version 12.1
    hostname FrameSW2
    interface Tunnel0
    tunnel destination 192.168.11.1
    ip address 192.168.11.2 255.255.255.0
    duplex auto
    speed auto
    interface Serial0/0
    no fair-queue
    clockrate 64000
    frame-relay route 103 interface Tunnel0 103
    frame-relay route 203 interface Tunnel0 203
    frame-relay route 304 interface Serial0/1 403
    interface Serial0/1
    clockrate 64000
    frame-relay route 104 interface Tunnel0 104
    frame-relay route 204 interface Tunnel0 204
    frame-relay route 403 interface Serial0/0 304
    ip classless
    password cisco
    login
    line aux 0
    password cisco
    login
    sh run
    Current configuration : 1436 bytes
    version 12.1
    hostname FrameSW1
    interface Tunnel0
    tunnel destination 192.168.11.2
    ip address 192.168.11.1 255.255.255.0
    half-duplex
    interface Serial0/0
    frame-relay route 102 interface Serial0/1 201
    interface Serial0/1
    clockrate 64000
    frame-relay route 201 interface Serial0/0 102
    ip kerberos source-interface any
    ip classless
    no ip http server
    Cần chú ý cách dùng lệnh frame-relay route trên các framerelay switch.
