  • BCRAN challlenging lab 1
    Bài tập lab tổng hợp cho CCNP-BCRAN. Bài 1.
    RE: BCRAN challlenging lab 1
    R1#sh run
    version 12.1
    hostname R1
    crypto isakmp policy 10
    hash md5
    authentication pre-share
    crypto isakmp key vnpro1 address 150.50.5.69
    crypto ipsec transform-set MYSET ah-md5-hmac esp-des
    crypto map MYMAP 10 ipsec-isakmp
    set peer 150.50.5.69
    set transform-set MYSET
    match address 113
     ip address 200.0.0.1 255.255.255.255
    interface Loopback1
    interface Ethernet0/0
    ip address 150.50.17.1 255.255.255.0
    half-duplex
    crypto map MYMAP
    router eigrp 100
    network 150.50.17.0 0.0.0.255
    network 200.0.0.1 0.0.0.0
    no auto-summary
    no eigrp log-neighbor-changes
    ip classless
    access-list 113 permit ip 192.168.10.0 0.0.0.255 150.50.4.0 0.0.0.255
    logging synchronous
    transport input none
    line aux 0
    password 7 00071A150754
    login
    no scheduler allocate
    R1#sh ip route
    200.0.0.0/32 is subnetted, 7 subnets
    D 200.0.0.8 [90/2861056] via 150.50.17.2, 00:02:57, Ethernet0/0
    D EX 200.0.0.9 [170/2198016] via 150.50.17.2, 00:02:57, Ethernet0/0
    C 200.0.0.1 is directly connected, Loopback0
    D 200.0.0.2 [90/409600] via 150.50.17.2, 01:06:35, Ethernet0/0
    D 200.0.0.4 [90/2323456] via 150.50.17.2, 00:03:51, Ethernet0/0
    D 200.0.0.5 [90/2323456] via 150.50.17.2, 00:02:13, Ethernet0/0
    D 200.0.0.7 [90/2349056] via 150.50.17.2, 00:02:57, Ethernet0/0
    C 192.168.10.0/24 is directly connected, Loopback1
    D 10.1.1.0 [90/2221056] via 150.50.17.2, 00:03:51, Ethernet0/0
    150.50.0.0/16 is variably subnetted, 9 subnets, 5 masks
    D EX 150.50.6.209/32 [170/2198016] via 150.50.17.2, 00:02:57, Ethernet0/0
    D 150.50.4.0/24 [90/2758656] via 150.50.17.2, 00:02:59, Ethernet0/0
    D EX 150.50.6.0/25 [170/2198016] via 150.50.17.2, 00:02:59, Ethernet0/0
    D 150.50.7.0/25 [90/2221056] via 150.50.17.2, 00:02:59, Ethernet0/0
    D 150.50.9.0/26 [90/40537600] via 150.50.17.2, 01:06:37, Ethernet0/0
    C 150.50.17.0/24 is directly connected, Ethernet0/0
    D 150.50.24.0/24 [90/2195456] via 150.50.17.2, 00:03:59, Ethernet0/0
    D 150.50.100.0/27 [90/2195456] via 150.50.17.2, 00:03:59, Ethernet0/0
    D 150.50.5.64/27 [90/2733056] via 150.50.17.2, 00:02:59, Ethernet0/0
    R2#sh run
    hostname R2
    isdn switch-type basic-ni
    interface Loopback0
    ip address 200.0.0.2 255.255.255.255
    ip address 150.50.17.2 255.255.255.0
    half-duplex
    interface Serial0/0
    encapsulation frame-relay
    interface Serial0/0.24 point-to-point
    ip address 150.50.24.2 255.255.255.0
    frame-relay interface-dlci 204
    interface Serial0/0.256 multipoint
    ip address 150.50.100.2 255.255.255.224
    no ip split-horizon
    frame-relay map ip 150.50.100.5 205 broadcast
    frame-relay map ip 150.50.100.6 206 broadcast
    interface BRI0/0
    ip address 150.50.9.2 255.255.255.192
    encapsulation ppp
    dialer callback-secure
    dialer idle-timeout 90
    dialer map ip 150.50.9.5 name R5 class dialback broadcast 8995101
    dialer map ip 150.50.9.5 name R5 class dialback broadcast 8995102
    dialer-group 1
    isdn spid1 5201 8995201
    isdn spid2 5202 8995202
    ppp callback accept
    ppp authentication chap
    router eigrp 100
    passive-interface BRI0/0
    network 150.50.9.0 0.0.0.63
    network 150.50.24.0 0.0.0.255
    network 150.50.100.0 0.0.0.31
    network 200.0.0.2 0.0.0.0
    no auto-summary
    ip classless
    no ip http server
    map-class dialer dialback
    dialer callback-server username
    logging synchronous
    line aux 0
    password 7 121A0C041104
    login
    R2#sh ip route
    D 200.0.0.8 [90/2835456] via 150.50.100.6, 00:02:42, Serial0/0.256
    [90/2835456] via 150.50.100.5, 00:02:42, Serial0/0.256
    D EX 200.0.0.9 [170/2172416] via 150.50.100.6, 00:02:42, Serial0/0.256
    D 200.0.0.1 [90/409600] via 150.50.17.1, 00:02:37, Ethernet0/0
    C 200.0.0.2 is directly connected, Loopback0
    D 200.0.0.4 [90/2297856] via 150.50.24.4, 00:02:37, Serial0/0.24
    D 200.0.0.5 [90/2297856] via 150.50.100.5, 00:02:42, Serial0/0.256
    D 200.0.0.7 [90/2323456] via 150.50.100.6, 00:02:42, Serial0/0.256
    [90/2323456] via 150.50.100.5, 00:02:42, Serial0/0.256
    D 10.1.1.0 [90/2195456] via 150.50.24.4, 00:02:37, Serial0/0.24
    [170/2172416] via 150.50.100.6, 00:02:44, Serial0/0.256
    D 150.50.4.0/24 [90/2733056] via 150.50.100.6, 00:02:44, Serial0/0.256
    [90/2733056] via 150.50.100.5, 00:02:44, Serial0/0.256
    D EX 150.50.6.0/25 [170/2172416] via 150.50.100.6, 00:02:44, Serial0/0.256
    D 150.50.7.0/25 [90/2195456] via 150.50.100.6, 00:02:44, Serial0/0.256
    [90/2195456] via 150.50.100.5, 00:02:44, Serial0/0.256
    C 150.50.9.0/26 is directly connected, BRI0/0
    C 150.50.24.0/24 is directly connected, Serial0/0.24
    C 150.50.100.0/27 is directly connected, Serial0/0.256
    D 150.50.5.64/27 [90/2707456] via 150.50.100.6, 00:02:44, Serial0/0.256
    [90/2707456] via 150.50.100.5, 00:02:44, Serial0/0.256
    R4#sh run
    hostname R4
    no ip domain lookup
    class-map match-all FTP-CLASS
    match access-group 100
    class-map match-any DEFAUTL
    match any
    class-map match-all ICMP-CLASS
    match access-group 102
    class-map match-all HTTP-CLASS
    match access-group 101
    policy-map CBWFQ-CENTRAL
    class HTTP-CLASS
    bandwidth 32
    class FTP-CLASS
    bandwidth 32
    class ICMP-CLASS
    bandwidth 32
    class DEFAUTL
    bandwidth 16
    queue-limit 40
    class class-default
    interface Loopback0
    ip address 200.0.0.4 255.255.255.255
    ip address 10.1.1.4 255.255.255.0
    half-duplex
    no keepalive
    interface Serial0/0
    interface Serial0/0.1 point-to-point
    ip address 150.50.24.4 255.255.255.0
    frame-relay interface-dlci 402
    interface Serial0/1
    shutdown
    router eigrp 100
    network 10.1.1.0 0.0.0.255
    network 200.0.0.4 0.0.0.0
    no auto-summary
    ip http server
    ip classless
    access-list 100 permit tcp 10.1.1.0 0.0.0.255 172.16.136.0 0.0.0.255 eq ftp
    access-list 100 permit tcp 10.1.1.0 0.0.0.255 172.16.136.0 0.0.0.255 eq ftp-data
    access-list 101 permit tcp 10.1.1.0 0.0.0.255 172.16.136.0 0.0.0.255 eq www
    access-list 102 permit icmp 10.1.1.0 0.0.0.255 172.16.136.0 0.0.0.255
    line aux 0
    password cisco
    login
    R4#sh ip route
    D 200.0.0.8 [90/3347456] via 150.50.24.2, 00:04:04, Serial0/0.1
    D EX 200.0.0.9 [170/2684416] via 150.50.24.2, 00:04:04, Serial0/0.1
    D 200.0.0.1 [90/2323456] via 150.50.24.2, 00:05:00, Serial0/0.1
    D 200.0.0.2 [90/2297856] via 150.50.24.2, 00:05:00, Serial0/0.1
    C 200.0.0.4 is directly connected, Loopback0
    D 200.0.0.5 [90/2809856] via 150.50.24.2, 00:03:21, Serial0/0.1
    D 200.0.0.7 [90/2835456] via 150.50.24.2, 00:04:04, Serial0/0.1
    C 10.1.1.0 is directly connected, Ethernet0/0
    D EX 150.50.6.209/32 [170/2684416] via 150.50.24.2, 00:04:04, Serial0/0.1
    D 150.50.4.0/24 [90/3245056] via 150.50.24.2, 00:04:04, Serial0/0.1
    D EX 150.50.6.0/25 [170/2684416] via 150.50.24.2, 00:04:06, Serial0/0.1
    D 150.50.7.0/25 [90/2707456] via 150.50.24.2, 00:04:06, Serial0/0.1
    D 150.50.9.0/26 [90/41024000] via 150.50.24.2, 00:05:03, Serial0/0.1
    D 150.50.17.0/24 [90/2195456] via 150.50.24.2, 00:05:03, Serial0/0.1
    C 150.50.24.0/24 is directly connected, Serial0/0.1
    D 150.50.100.0/27 [90/2681856] via 150.50.24.2, 00:05:03, Serial0/0.1
    D 150.50.5.64/27 [90/3219456] via 150.50.24.2, 00:04:07, Serial0/0.1
    R4#sh policy-map
    Policy Map CBWFQ-CENTRAL
    Class HTTP-CLASS
    Bandwidth 32 (kbps) Max Threshold 64 (packets)
    Class FTP-CLASS
    Class ICMP-CLASS
    Class DEFAUTL
    Bandwidth 16 (kbps) Max Threshold 40 (packets)
    Class class-default
    R4#sh ip route
    D 200.0.0.8 [90/3347456] via 150.50.24.2, 00:04:40, Serial0/0.1
    D EX 200.0.0.9 [170/2684416] via 150.50.24.2, 00:04:40, Serial0/0.1
    D 200.0.0.1 [90/2323456] via 150.50.24.2, 00:05:36, Serial0/0.1
    D 200.0.0.2 [90/2297856] via 150.50.24.2, 00:05:36, Serial0/0.1
    D 200.0.0.5 [90/2809856] via 150.50.24.2, 00:03:56, Serial0/0.1
    D 200.0.0.7 [90/2835456] via 150.50.24.2, 00:04:40, Serial0/0.1
    D EX 150.50.6.209/32 [170/2684416] via 150.50.24.2, 00:04:40, Serial0/0.1
    D 150.50.4.0/24 [90/3245056] via 150.50.24.2, 00:04:40, Serial0/0.1
    D EX 150.50.6.0/25 [170/2684416] via 150.50.24.2, 00:04:41, Serial0/0.1
    D 150.50.7.0/25 [90/2707456] via 150.50.24.2, 00:04:41, Serial0/0.1
    D 150.50.9.0/26 [90/41024000] via 150.50.24.2, 00:05:37, Serial0/0.1
    D 150.50.17.0/24 [90/2195456] via 150.50.24.2, 00:05:37, Serial0/0.1
    D 150.50.100.0/27 [90/2681856] via 150.50.24.2, 00:05:37, Serial0/0.1
    D 150.50.5.64/27 [90/3219456] via 150.50.24.2, 00:04:41, Serial0/0.1
    R5#sh run
    hostname R5
    enable password cisco
    username R2 password 0 cisco
    interface Loopback0
    ip address 200.0.0.5 255.255.255.255
    ip address 150.50.7.5 255.255.255.128
    half-duplex
    interface Serial0/0
    ip address 150.50.100.5 255.255.255.224
    no fair-queue
    frame-relay class TSLAB
    frame-relay traffic-shaping
    interface BRI0/0
    ip address 150.50.9.5 255.255.255.192
    encapsulation ppp
    dialer idle-timeout 60
    dialer map ip 150.50.9.2 broadcast 8995201
    dialer map ip 150.50.9.2 broadcast 8995202
    dialer-group 1
    isdn spid1 5101
    isdn spid2 5102
    ppp callback request
    router eigrp 100
    network 150.50.7.0 0.0.0.127
    network 200.0.0.5 0.0.0.0
    no auto-summary
    ip classless
    ip route 150.50.17.0 255.255.255.0 150.50.9.2 130
    no ip http server
    map-class frame-relay TSLAB
    no frame-relay adaptive-shaping
    frame-relay cir 16000
    frame-relay bc 2000
    frame-relay be 2500
    line aux 0
    password cisco
    login
    R5#sh ip route
    D 200.0.0.8 [90/2323456] via 150.50.7.7, 00:04:28, Ethernet0/0
    D EX 200.0.0.9 [170/284160] via 150.50.7.6, 00:04:28, Ethernet0/0
    D 200.0.0.1 [90/2323456] via 150.50.100.2, 00:04:38, Serial0/0
    D 200.0.0.2 [90/2297856] via 150.50.100.2, 00:04:38, Serial0/0
    D 200.0.0.4 [90/2809856] via 150.50.100.2, 00:04:38, Serial0/0
    C 200.0.0.5 is directly connected, Loopback0
    D 200.0.0.7 [90/409600] via 150.50.7.7, 00:04:28, Ethernet0/0
    D 10.1.1.0 [90/2707456] via 150.50.100.2, 00:04:38, Serial0/0
    D EX 150.50.6.209/32 [170/284160] via 150.50.7.6, 00:04:28, Ethernet0/0
    D 150.50.4.0/24 [90/2221056] via 150.50.7.7, 00:04:28, Ethernet0/0
    D EX 150.50.6.0/25 [170/284160] via 150.50.7.6, 00:04:30, Ethernet0/0
    C 150.50.7.0/25 is directly connected, Ethernet0/0
    D 150.50.17.0/24 [90/2195456] via 150.50.100.2, 00:04:40, Serial0/0
    D 150.50.24.0/24 [90/2681856] via 150.50.100.2, 00:04:40, Serial0/0
    D 150.50.5.64/27 [90/2195456] via 150.50.7.7, 00:04:30, Ethernet0/0
    R5#sh dialer
    BRI0/0 - dialer type = ISDN
    Dial String Successes Failures Last DNIS Last status
    8995202 0 1 00:16:01 failed
    8995201 3 1 00:15:17 successful
    0 incoming call(s) have been screened.
    0 incoming call(s) rejected for callback.
    BRI0/0:1 - dialer type = ISDN
    Idle timer (60 secs), Fast idle timer (20 secs)
    Wait for carrier (30 secs), Re-enable (15 secs)
    Dialer state is idle
    BRI0/0:2 - dialer type = ISDN
    R5# sh ip route
    D 200.0.0.8 [90/2323456] via 150.50.7.7, 00:04:55, Ethernet0/0
    D EX 200.0.0.9 [170/284160] via 150.50.7.6, 00:04:55, Ethernet0/0
    D 200.0.0.1 [90/2323456] via 150.50.100.2, 00:05:05, Serial0/0
    D 200.0.0.2 [90/2297856] via 150.50.100.2, 00:05:05, Serial0/0
    D 200.0.0.4 [90/2809856] via 150.50.100.2, 00:05:05, Serial0/0
    D 200.0.0.7 [90/409600] via 150.50.7.7, 00:04:55, Ethernet0/0
    D 10.1.1.0 [90/2707456] via 150.50.100.2, 00:05:05, Serial0/0
    D EX 150.50.6.209/32 [170/284160] via 150.50.7.6, 00:04:55, Ethernet0/0
    D 150.50.4.0/24 [90/2221056] via 150.50.7.7, 00:04:55, Ethernet0/0
    D EX 150.50.6.0/25 [170/284160] via 150.50.7.6, 00:04:58, Ethernet0/0
    D 150.50.17.0/24 [90/2195456] via 150.50.100.2, 00:05:07, Serial0/0
    D 150.50.24.0/24 [90/2681856] via 150.50.100.2, 00:05:07, Serial0/0
    D 150.50.5.64/27 [90/2195456] via 150.50.7.7, 00:04:58, Ethernet0/0
    R8#sh run
    hostname R8
    logging rate-limit console 10 except errors
    aaa new-model
    aaa authentication username-prompt "Who is it _"
    aaa authentication login default local-case enable
    username vnpro privilege 15 password 0 minhdq
    username minhdp password 0 vnpro
    username minhdq password 0 vnpro
    ip subnet-zero
    crypto isakmp policy 100
    hash md5
    crypto isakmp key vnpro1 address 150.50.17.1
    crypto map MYMAP 110 ipsec-isakmp
    set peer 150.50.17.1
    match address 120
    interface Loopback0
    ip address 200.0.0.8 255.255.255.255
    ip address 150.50.4.8 255.255.255.0
    no keepalive
    half-duplex
    interface Serial0/0
    ip address 150.50.5.69 255.255.255.224
    no fair-queue
    clockrate 64000
    crypto map MYMAP
    router eigrp 100
    network 150.50.4.0 0.0.0.255
    network 150.50.5.64 0.0.0.31
    network 200.0.0.8 0.0.0.0
    no auto-summary
    router rip
    version 2
    network 150.50.0.0
    network 200.0.0.0
    ip classless
    ip route 192.168.10.0 255.255.255.0 150.50.5.68
    no ip http server
    access-list 120 permit ip 150.50.4.0 0.0.0.255 192.168.10.0 0.0.0.255
    dial-peer cor custom
    R8#sh ip route
    Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
    E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
    i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
    * - candidate default, U - per-user static route, o - ODR
    P - periodic downloaded static route
    C 200.0.0.8 is directly connected, Loopback0
    D EX 200.0.0.9 [170/2198016] via 150.50.5.68, 00:27:17, Serial0/0
    D 200.0.0.1 [90/2861056] via 150.50.5.68, 00:07:13, Serial0/0
    D 200.0.0.2 [90/2835456] via 150.50.5.68, 00:07:13, Serial0/0
    D 200.0.0.4 [90/3347456] via 150.50.5.68, 00:07:13, Serial0/0
    D 200.0.0.5 [90/2323456] via 150.50.5.68, 00:27:17, Serial0/0
    D 200.0.0.7 [90/2297856] via 150.50.5.68, 00:27:17, Serial0/0
    S 192.168.10.0/24 [1/0] via 150.50.5.68
    D 10.1.1.0 [90/3245056] via 150.50.5.68, 00:07:13, Serial0/0
    D EX 150.50.6.209/32 [170/2198016] via 150.50.5.68, 00:27:17, Serial0/0
    C 150.50.4.0/24 is directly connected, Ethernet0/0
    D EX 150.50.6.0/25 [170/2198016] via 150.50.5.68, 00:27:20, Serial0/0
    D 150.50.7.0/25 [90/2195456] via 150.50.5.68, 00:27:20, Serial0/0
    D 150.50.9.0/26 [90/41049600] via 150.50.5.68, 00:27:20, Serial0/0
    D 150.50.17.0/24 [90/2733056] via 150.50.5.68, 00:07:15, Serial0/0
    D 150.50.24.0/24 [90/3219456] via 150.50.5.68, 00:07:15, Serial0/0
    D 150.50.100.0/27 [90/2707456] via 150.50.5.68, 00:17:04, Serial0/0
    C 150.50.5.64/27 is directly connected, Serial0/0
    R5#sh run
    hostname R5
    interface Loopback0
    half-duplex
    interface Serial0/0
    no fair-queue
    interface BRI0/0
    encapsulation ppp
    dialer-group 1
    isdn spid1 5101
    isdn spid2 5102
    router eigrp 100
    no auto-summary
    ip classless
    no ip http server
    frame-relay bc 2000
    frame-relay be 2500
    R9#150.50.7.7
    R7#sh run
    hostname R7
    interface Loopback0
    ip address 200.0.0.7 255.255.255.255
    ip address 150.50.7.7 255.255.255.128
    half-duplex
    interface Serial0/0
    ip address 150.50.5.68 255.255.255.224
    no fair-queue
    router eigrp 100
    network 200.0.0.7 0.0.0.0
    no auto-summary
    router rip
    network 150.50.0.0
    network 200.0.0.0
    ip classless
    ip http server
    R7#sh ip route
    200.0.0.0/24 is variably subnetted, 8 subnets, 2 masks
    D 200.0.0.8/32 [90/2297856] via 150.50.5.69, 00:28:30, Serial0/0
    D EX 200.0.0.9/32 [170/284160] via 150.50.7.6, 01:21:15, Ethernet0/0
    R 200.0.0.0/24 [120/1] via 150.50.5.69, 00:00:05, Serial0/0
    D 200.0.0.1/32 [90/2349056] via 150.50.7.6, 00:07:37, Ethernet0/0
    [90/2349056] via 150.50.7.5, 00:07:37, Ethernet0/0
    D 200.0.0.2/32 [90/2323456] via 150.50.7.6, 00:07:37, Ethernet0/0
    [90/2323456] via 150.50.7.5, 00:07:37, Ethernet0/0
    D 200.0.0.4/32 [90/2835456] via 150.50.7.6, 00:07:37, Ethernet0/0
    [90/2835456] via 150.50.7.5, 00:07:37, Ethernet0/0
    D 200.0.0.5/32 [90/409600] via 150.50.7.5, 00:58:14, Ethernet0/0
    C 200.0.0.7/32 is directly connected, Loopback0
    D 10.1.1.0 [90/2733056] via 150.50.7.6, 00:07:39, Ethernet0/0
    [90/2733056] via 150.50.7.5, 00:07:39, Ethernet0/0
    D EX 150.50.6.209/32 [170/284160] via 150.50.7.6, 01:21:17, Ethernet0/0
    D 150.50.4.0/24 [90/2195456] via 150.50.5.69, 00:28:32, Serial0/0
    D EX 150.50.6.0/25 [170/284160] via 150.50.7.6, 01:21:17, Ethernet0/0
    D 150.50.9.0/26 [90/40537600] via 150.50.7.5, 00:58:16, Ethernet0/0
    D 150.50.17.0/24 [90/2221056] via 150.50.7.6, 00:07:39, Ethernet0/0
    [90/2221056] via 150.50.7.5, 00:07:39, Ethernet0/0
    D 150.50.24.0/24 [90/2707456] via 150.50.7.6, 00:07:39, Ethernet0/0
    [90/2707456] via 150.50.7.5, 00:07:39, Ethernet0/0
    D 150.50.100.0/27 [90/2195456] via 150.50.7.6, 00:09:00, Ethernet0/0
    [90/2195456] via 150.50.7.5, 00:09:00, Ethernet0/0
    R6#sh run
    hostname R6
    enable password 7 110A1016141D
    class-map HTTP
    class-map FTP
    policy-map PRIO
    class HTTP
    bandwidth percent 10
    class FTP
    bandwidth percent 20
    ip subnet-zero
    interface Ethernet0
    ip address 150.50.7.6 255.255.255.128
    service-policy output PRIO
    interface Ethernet1
    ip address 150.50.6.6 255.255.255.128
    interface Serial0
    ip address 150.50.100.6 255.255.255.224
    frame-relay map ip 150.50.100.2 602 broadcast
    frame-relay map ip 150.50.100.5 605 broadcast
    frame-relay lmi-type cisco
    router eigrp 100
    redistribute ospf 1 metric 100000 10 255 255 1500
    network 150.50.7.0 0.0.0.255
    network 150.50.100.0 0.0.0.255
    no auto-summary
    router ospf 1
    log-adjacency-changes
    redistribute eigrp 100 metric 111 metric-type 1 subnets
    network 150.50.6.0 0.0.0.255 area 0
    ip classless
    no ip http server
    access-list 101 permit tcp any any eq www
    access-list 102 permit tcp any any eq ftp
    R6#sh ip route
    D 200.0.0.8 [90/2323456] via 150.50.7.7, 00:08:25, Ethernet0
    O 200.0.0.9 [110/11] via 150.50.6.9, 01:22:52, Ethernet1
    D 200.0.0.1 [90/2323456] via 150.50.100.2, 00:08:31, Serial0
    D 200.0.0.2 [90/2297856] via 150.50.100.2, 00:08:31, Serial0
    D 200.0.0.4 [90/2809856] via 150.50.100.2, 00:08:31, Serial0
    D 200.0.0.5 [90/409600] via 150.50.7.5, 00:08:25, Ethernet0
    D 200.0.0.7 [90/409600] via 150.50.7.7, 00:08:25, Ethernet0
    D 10.1.1.0 [90/2707456] via 150.50.100.2, 00:08:31, Serial0
    O 150.50.6.209/32 [110/11] via 150.50.6.9, 01:22:52, Ethernet1
    D 150.50.4.0/24 [90/2221056] via 150.50.7.7, 00:08:25, Ethernet0
    C 150.50.6.0/25 is directly connected, Ethernet1
    D 150.50.9.0/26 [90/40537600] via 150.50.7.5, 00:08:27, Ethernet0
    D 150.50.17.0/24 [90/2195456] via 150.50.100.2, 00:08:33, Serial0
    D 150.50.24.0/24 [90/2681856] via 150.50.100.2, 00:08:33, Serial0
    D 150.50.5.64/27 [90/2195456] via 150.50.7.7, 00:08:27, Ethernet0
    R6#sh fr
    R9#sh run
    hostname R9
    interface Loopback0
    ip address 200.0.0.9 255.255.255.255
    interface Loopback1
    ip address 150.50.6.209 255.255.255.128
    ip address 150.50.6.9 255.255.255.128
    half-duplex
    router ospf 63
    network 150.50.6.0 0.0.0.127 area 0
    network 150.50.6.128 0.0.0.127 area 0
    network 200.0.0.9 0.0.0.0 area 0
    R9#sh ip route
    O E1 200.0.0.8 [110/121] via 150.50.6.6, 00:29:58, Ethernet0/0
    C 200.0.0.9 is directly connected, Loopback0
    O E1 200.0.0.1 [110/121] via 150.50.6.6, 00:09:55, Ethernet0/0
    O E1 200.0.0.2 [110/121] via 150.50.6.6, 00:09:55, Ethernet0/0
    O E1 200.0.0.4 [110/121] via 150.50.6.6, 00:09:55, Ethernet0/0
    O E1 200.0.0.5 [110/121] via 150.50.6.6, 00:59:43, Ethernet0/0
    O E1 200.0.0.7 [110/121] via 150.50.6.6, 01:23:26, Ethernet0/0
    O E1 10.1.1.0 [110/121] via 150.50.6.6, 00:09:57, Ethernet0/0
    150.50.0.0/16 is variably subnetted, 9 subnets, 4 masks
    C 150.50.6.128/25 is directly connected, Loopback1
    O E1 150.50.4.0/24 [110/121] via 150.50.6.6, 00:29:54, Ethernet0/0
    C 150.50.6.0/25 is directly connected, Ethernet0/0
    O E1 150.50.7.0/25 [110/121] via 150.50.6.6, 01:23:28, Ethernet0/0
    O E1 150.50.9.0/26 [110/121] via 150.50.6.6, 00:59:45, Ethernet0/0
    O E1 150.50.17.0/24 [110/121] via 150.50.6.6, 00:09:57, Ethernet0/0
    O E1 150.50.24.0/24 [110/121] via 150.50.6.6, 00:09:57, Ethernet0/0
    O E1 150.50.100.0/27 [110/121] via 150.50.6.6, 00:19:47, Ethernet0/0
    O E1 150.50.5.64/27 [110/121] via 150.50.6.6, 01:23:28, Ethernet0/0
      Search, download and share files from 4shared: music, video, images, books, apk. Use advanced search filters to find favorite songs, video clips and mobile apps.
