  • Giúp mình phần cấu hình Firewall ASA này với
    Mình cấu hình VPN client access nhưng khi vpn vào thì thấy lớp mạng bên trong nhưng vẫn không telnet được vào firewall và máy client access lại không ra được internet, còn cái phần split tunnel mình vẫn chưa hiểu rõ nữa, các bạn hướng dẫn mình với !
    Show run đây :
    Fw-5520-tdttdn# show run
    : Saved
    ASA Version 8.4(2)
    hostname Fw-5520-tdttdn
    enable password Pqi8e1eD2uj36YH/ level 14 encrypted
    passwd xp/7b8xPD887FrwT encrypted
    names
    interface GigabitEthernet0/0
    description #### Ket noi vao Router ####
    nameif Outside
    security-level 0
    interface GigabitEthernet0/1
    description #### Ket noi vao CoreSwitch ####
    nameif Inside
    security-level 100
    ip address 10.59.25.1 255.255.255.0
    interface GigabitEthernet0/1.1
    no vlan
    no nameif
    no security-level
    interface GigabitEthernet0/2
    shutdown
    no nameif
    no security-level
    interface GigabitEthernet0/3
    shutdown
    no nameif
    no security-level
    interface Management0/0
    shutdown
    nameif management
    security-level 100
    ip address 192.168.100.100 255.255.0.0
    management-only
    banner login #### Firewall ASA 5520 - truong DH TDTT Da Nang ####
    ftp mode passive
    object network SVR01
    host 10.59.25.5
    access-list FULL extended permit ip any any
    access-list PING extended permit icmp any any
    access-list SPLIT_TUNNEL standard permit 10.59.0.0 255.255.0.0
    access-list REMOTE extended permit tcp any object SVR01 eq 3389
    pager lines 24
    logging enable
    mtu Outside 1500
    mtu Inside 1500
    mtu management 1500
    ip local pool VPN_POOL 10.59.0.20-10.59.0.100 mask 255.255.255.0
    no failover
    icmp permit any Outside
    no asdm history enable
    arp timeout 14400
    access-group REMOTE in interface Outside
    access-group FULL in interface Inside
    route Outside 0.0.0.0 0.0.0.0 192.168.2.1 1
    timeout xlate 3:00:00
    timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
    timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
    timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
    timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
    timeout tcp-proxy-reassembly 0:01:00
    timeout floating-conn 0:00:00
    dynamic-access-policy-record DfltAccessPolicy
    user-identity default-domain LOCAL
    aaa authentication telnet console LOCAL
    no snmp-server location
    no snmp-server contact
    snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
    crypto ipsec ikev1 transform-set VPN_MYSET esp-3des esp-sha-hmac
    crypto dynamic-map VPN_DYNMAP 1 set ikev1 transform-set VPN_MYSET
    crypto dynamic-map VPN_DYNMAP 1 set reverse-route
    crypto map VPN_MAP 1 ipsec-isakmp dynamic VPN_DYNMAP
    crypto map VPN_MAP interface Outside
    crypto ikev1 enable Outside
    crypto ikev1 policy 1
    authentication pre-share
    encryption 3des
    hash sha
    group 2
    lifetime 36000
    crypto ikev1 policy 65535
    encryption 3des
    hash sha
    group 2
    lifetime 86400
    telnet 10.59.25.0 255.255.255.0 Inside
    telnet timeout 5
    ssh timeout 5
    console timeout 0
    threat-detection basic-threat
    threat-detection statistics access-list
    no threat-detection statistics tcp-intercept
    group-policy VPN_DYNMAP internal
    group-policy VPN_DYNMAP attributes
    dns-server value 10.59.25.10
    split-tunnel-policy tunnelspecified
    split-tunnel-network-list value SPLIT_TUNNEL
    username tdttdn password Q.8uuLSxCw5QrW12 encrypted privilege 15
    username admin password ihqPJ78Nh4GnjT59 encrypted
    username user4 password TTNKHqfM6YyTcEzA encrypted
    username user1 password 8jXOrP2GU4S4Gn/o encrypted
    username user3 password TTNKHqfM6YyTcEzA encrypted
    username user2 password TTNKHqfM6YyTcEzA encrypted
    tunnel-group VPN_TUNNEL type remote-access
    tunnel-group VPN_TUNNEL general-attributes
    address-pool VPN_POOL
    tunnel-group VPN_TUNNEL ipsec-attributes
    ikev1 pre-shared-key *****
    class-map inspection_default
    match default-inspection-traffic
    policy-map type inspect dns preset_dns_map
    parameters
    message-length maximum client auto
    message-length maximum 512
    policy-map global_policy
    class inspection_default
    inspect ftp
    inspect h323 h225
    inspect h323 ras
    inspect ip-options
    inspect netbios
    inspect rsh
    inspect rtsp
    inspect skinny
    inspect esmtp
    inspect sqlnet
    inspect sunrpc
    inspect tftp
    inspect sip
    inspect xdmcp
    service-policy global_policy global
    prompt hostname context
    no call-home reporting anonymous
    call-home
    profile CiscoTAC-1
    no active
    destination address http https://tools.cisco.com/its/service/oddce/services/DD
    CEService
    destination address email callhome@cisco.com
    destination transport-method http
    subscribe-to-alert-group diagnostic
    subscribe-to-alert-group environment
    subscribe-to-alert-group inventory periodic monthly
    subscribe-to-alert-group configuration periodic monthly
    subscribe-to-alert-group telemetry periodic daily
    Cryptochecksum:ac60b1a2ad47cc126798fa647342fd94
    : end
    Chào bạn,
    Để client access có thể truy cập Internet khi đang dùng VPN bạn bật thêm chức năng split tunnel trên ASA để chỉ các lớp mạng này được mã hóa, bảo mật.
    Còn về telnet
    Phạm Minh Tuấn
    Yahoo : phamminhtuan_vnpro
      Cám ơn bạn nhiều nhé ! Cái phần telnet vào Firewall khi vpn client access vào vẫn chưa được bạn ơi ! Có cần tạo thêm access-list nào ko ?
        nếu bạn access từ outside thì phải dùng ssh, trên outside không hổ trợ telnet.
        Hugo
          dung command nay
          management-access inside
          telnet a.b.c.d 255.255.255.x inside
          OR/AND
          ssh a.b.c.d 255.255.255.x inside
          a.b.c.d la vpn client ip
          VPN vao va` trelnet vao` inside ip address
          HTH
          Tao Lao
          Thương Nhất Là Mẹ,
          Hận Nhất Là Thời Gian.
