  • ASA 8.3 / 8.4 Double NAT / Source Destination NAT Migration Lab Guide – Lab 1.4
    Main Post
    This lab is part of the series of LAB which details how migrate NAT configurations from Pre ASA 8.2 version to ASA 8.3/8.4
    Lab1.3 Setup
    Double NAT/Source Destination NAT
    We will start with a fresh LAB, not building on what we had before because the old config/topology was getting too much complex now.
    The device configurations and GNS3 Topology can be downloaded from the the following link if you want it to import it for yourself.
    MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
    NAT Policy
    Outgoing
    Source Sourced Mapped Destination Destination Mapped
    10.10.10.1 192.168.100.200 192.168.0.200 12.12.12.1
    Incoming
    12.12.12.1 192.168.0.200 192.168.100.200 10.10.10.1
    1. Configure ASA for Inside address 10.10.10.1 such that when it tries to access 192.168.0.200, the NAT comes into action and translates sources (10.10.10.1) address to 192.168.100.200 and destination address(192.168.0.200) to 12.12.12.1. The same way when outside address 12.12.12.1 tries to access 192.168.100.200, the NAT is here again and translates source address(12.12.12.1) to 192.168.0.200 and destination address(192.168.1000.200) to 10.10.10.1
    Pre ASA 8.3 Configuration
    1.
    access-list out-nat permit ip host 10.10.10.1 host 192.168.0.200
    access-list in-nat permit ip host 12.12.12.1 host 192.168.100.200
    static (inside,outside) 192.168.100.200 access-list out-nat
    static (outside,inside) 192.168.0.200 access-list in-nat
    ASA 8.3/8.4 Configuration
    1. Again start object configuration for each IP address and then use the nat statement which will do all translations (in/out) in one statement.
    object network obj-outreal-12.12.12.1
    host 12.12.12.1
    object network obj-outmapped-192.168.100.200
    object network obj-inreal-10.10.10.1
    host 10.10.10.1
    object network obj-inmapped-192.168.0.200
    host 192.168.0.200
    nat (inside,outside) source static obj-inreal-10.10.10.1 obj-outmapped-192.168.100.200 destination static obj-inmapped-192.168.0.200 obj-outreal-12.12.12.1
    Verification
    1. Use ‘show run object’ to check the objects that we configured
    ASA1# sh run object
    host 12.12.12.1
    host 10.10.10.1
    host 192.168.0.200
    2. Use ‘show run nat’ to verify the NAT configuration
    ASA1# sh run nat
    3. Use ‘show nat’ to check the hits against rule
    ASA1# sh nat
    Manual NAT Policies (Section 1)
    1 (inside) to (outside) source static obj-inreal-10.10.10.1 obj-outmapped-192.168.100.200 destination static obj-inmapped-192.168.0.200 obj-outreal-12.12.12.1
    translate_hits = 0, untranslate_hits = 0
    4. Lets use extended ping from 10.10.10.1 to 192.168.0.200, we will enable ‘debug ip packet’ both on Inside and ISP router to see source and destination IP addresses.
    Inside#ping
    Protocol [ip]:
    Target IP address: 192.168.0.200
    Repeat count [5]:
    Datagram size [100]:
    Timeout in seconds [2]:
    Extended commands [n]: y
    Source address or interface: 10.10.10.1
    Type of service [0]:
    Set DF bit in IP header? [no]:
    Validate reply data? [no]:
    Data pattern [0xABCD]:
    Sweep range of sizes [n]:
    Sending 5, 100-byte ICMP Echos to 192.168.0.200, timeout is 2 seconds:
    Packet sent with a source address of 10.10.10.1
    Success rate is 100 percent (5/5), round-trip min/avg/max = 28/48/92 ms
    Inside#
    Inside#
    Inside#
    *Mar 12 15:19:15.986: IP: s=10.10.10.1 (local), d=192.168.0.200 (FastEthernet1/0), len 100, sending
    *Mar 12 15:19:15.986: IP: s=10.10.10.1 (local), d=192.168.0.200 (FastEthernet1/0), len 100, sending full packet
    *Mar 12 15:19:16.078: IP: s=192.168.0.200 (FastEthernet1/0), d=10.10.10.1, len 100, input feature, MCI Check(64), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    *Mar 12 15:19:16.078: IP: tableid=0, s=192.168.0.200 (FastEthernet1/0), d=10.10.10.1 (Loopback0), routed via RIB
    *Mar 12 15:19:16.078: IP: s=192.168.0.200 (FastEthernet1/0), d=10.10.10.1, len 100, rcvd 4
    *Mar 12 15:19:16.078: IP: s=192.168.0.200 (FastEthernet1/0), d=10.10.10.1, len 100, stop process pak for forus packet
    *Mar 12 15:19:16.078: IP: s=10.10.10.1 (local), d=192.168.0.200 (FastEthernet1/0), len 100, sending
    *Mar 12 15:19:16.078: IP: s=10.10.10.1 (local), d=192.168.0.200 (FastEthernet1/0), len 100, sending full packet
    *Mar 12 15:19:16.098: IP: s=192.168.0.200 (FastEthernet1/0), d=10.10.10
    Let see what ISP router thinks
    *Mar 12 15:19:16.138: IP: s=192.168.100.200 (FastEthernet1/0), d=12.12.12.1, len 100, input feature, MCI Check(64), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    *Mar 12 15:19:16.142: IP: tableid=0, s=192.168.100.200 (FastEthernet1/0), d=12.12.12.1 (Loopback0), routed via RIB
    *Mar 12 15:19:16.146: IP: s=192.168.100.200 (FastEthernet1/0), d=12.12.12.1, len 100, rcvd 4
    *Mar 12 15:19:16.150: IP: s=192.168.100.200 (FastEthernet1/0), d=12.12.12.1, len 100, stop process pak for forus packet
    *Mar 12 15:19:16.154: IP: s=12.12.12.1 (local), d=192.168.100.200 (FastEthernet1/0), len 100, sending
    *Mar 12 15:19:16.158: IP: s=12.12.12.1 (local), d=192.168.100.200 (FastEthernet1/0), len 100, sending full packet
    *Mar 12 15:19:16.178: IP: s=192.168.100.200 (FastEthernet1/0), d=12.12.12.1, len 100, input feature
    ISP#, MCI Check(64), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    As you can see above inside router thinks its pining 192.168.0.200 and reply is coming from the same IP. The same way ISP router thinks ping request is coming from 192.168.1000.200 and is replying to same.
    5. Now, try the same from ISP router
    ISP#ping
    Protocol [ip]:
    Target IP address: 192.168.100.200
    Repeat count [5]:
    Source address or interface: 12.12.12.1
    Sending 5, 100-byte ICMP Echos to 192.168.100.200, timeout is 2 seconds:
    Packet sent with a source address of 12.12.12.1
    *Mar 12 15:25:52.686: IP: s=12.12.12.1 (local), d=192.168.100.200 (FastEthernet1/0), len 100, sending
    *Mar 12 15:25:52.690: IP: s=12.12.12.1 (local), d=192.168.100.200 (FastEthernet1/0), len 100, sending full packet
    *Mar 12 15:25:52.786: IP: s=192.168.100.200 (FastEthernet1/0), d=12.12.12.1, len 100, input feature, MCI Check(64), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    *Mar 12 15:25:52.786: IP: tableid=0, s=192.168.100.200 (FastEthernet1/0), d=12.12.12.1 (Loopback0), routed via RIB
    *Mar 12 15:25:52.786: IP: s=192.168.100.200 (FastEthernet1/0), d=12.12.12.1, len 100, rcvd 4
    *Mar 12 15:25:52.786: IP: s=192.168.100.200 (FastEthernet1/0), d=12.12.12.1, len 100, stop process pak for forus packet
    *Mar 12 15:25:52.786: IP: s=12.12.12.1 (local), d=192.168.100.200 (FastEthernet1/0), len 100, sending
    *Mar 12 15:25:52.786: IP: s=12.12.12.1 (local), d=192.168.100.200 (FastEthernet1/0), len 100, sending full packet
    *Mar 12 15:25:52.822: IP: s=192.168.100.200 (FastEther!
    Let see what Inside router thinks of it
    *Mar 12 15:25:52.870: IP: s=192.168.0.200 (FastEthernet1/0), d=10.10.10.1, len 100, input feature, MCI Check(64), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    *Mar 12 15:25:52.874: IP: tableid=0, s=192.168.0.200 (FastEthernet1/0), d=10.10.10.1 (Loopback0), routed via RIB
    *Mar 12 15:25:52.878: IP: s=192.168.0.200 (FastEthernet1/0), d=10.10.10.1, len 100, rcvd 4
    *Mar 12 15:25:52.882: IP: s=192.168.0.200 (FastEthernet1/0), d=10.10.10.1, len 100, stop process pak for forus packet
    *Mar 12 15:25:52.882: IP: s=10.10.10.1 (local), d=192.168.0.200 (FastEthernet1/0), len 100, sending
    *Mar 12 15:25:52.882: IP: s=10.10.10.1 (local), d=192.168.0.200 (FastEthernet1/0), len 100, sending full packet
    *Mar 12 15:25:52.894: IP: s=192.168.0.200 (FastEthernet1/0), d=10.10.10.1, len 100, input feature, MCI Check(64), rtype 0, forus FALSE, sendself FA
    Inside#LSE, mtu 0, fwdchk FALSE
    As you can see from the output above that Inside router is getting ping request from 192.168.0.200 and its replying to same
    6. We have hits against NAT rule confirming the same
    ASA1# sh nat
    translate_hits = 2, untranslate_hits = 2
