Nhờ mọi người giúp
  • Nhờ mọi người giúp
    ASA# show run
    : Saved
    ASA Version 8.0(2)
    hostname ASA
    names
    interface Ethernet0/0
    nameif outside
    security-level 0
    ip address 203.200.2.1 255.255.255.0
    interface Ethernet0/1
    nameif inside
    security-level 100
    interface Ethernet0/2
    nameif dmz
    security-level 50
    ip address 172.16.1.2 255.255.255.0
    interface Ethernet0/3
    shutdown
    no nameif
    no security-level
    interface Ethernet0/4
    shutdown
    no nameif
    no security-level
    interface Ethernet0/5
    shutdown
    no nameif
    no security-level
    boot config disk0:/.private/startup-config
    ftp mode passive
    access-list AL_WEB extended permit tcp any host 203.200.2.10 eq www
    access-list AL_WEB extended permit tcp any host 203.200.2.10 eq 3389
    access-list AL_WEB extended permit icmp any any echo-reply
    access-list IN_DMZ extended permit ip 10.10.10.0 255.255.255.0 host 172.16.1.1
    pager lines 24
    no logging message 402128
    mtu outside 1500
    mtu inside 1500
    mtu dmz 1500
    no failover
    no asdm history enable
    arp timeout 14400
    global (outside) 1 interface
    nat (inside) 0 access-list IN_DMZ
    nat (inside) 1 10.10.10.0 255.255.255.0
    static (dmz,outside) tcp 203.200.2.10 www 172.16.1.1 www netmask 255.255.255.255
    static (dmz,outside) tcp 203.200.2.10 3389 172.16.1.1 3389 netmask 255.255.255.255
    access-group AL_WEB in interface outside
    route outside 0.0.0.0 0.0.0.0 203.200.2.2 1
    timeout xlate 3:00:00
    timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
    timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
    timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
    timeout uauth 0:05:00 absolute
    dynamic-access-policy-record DfltAccessPolicy
    http server enable
    no snmp-server location
    no snmp-server contact
    snmp-server enable traps snmp authentication linkup linkdown coldstart
    no crypto isakmp nat-traversal
    telnet timeout 5
    ssh timeout 5
    console timeout 0
    threat-detection basic-threat
    threat-detection statistics access-list
    class-map inspection_default
    match default-inspection-traffic
    policy-map type inspect dns preset_dns_map
    parameters
    message-length maximum 512
    policy-map global_policy
    class inspection_default
    inspect ftp
    inspect h323 h225
    inspect h323 ras
    inspect netbios
    inspect rsh
    inspect rtsp
    inspect skinny
    inspect esmtp
    inspect sqlnet
    inspect sunrpc
    inspect tftp
    inspect sip
    inspect xdmcp
    service-policy global_policy global
    prompt hostname context
    Cryptochecksum:07ff3d35209eb408587278c7e51f7756
    : end
    ASA#
    Mình đã cấu hình như trên. Máy ở vùng inside có thể sử dụng remote desktop tới webserver nằm trong vùng dmz nhưng lại ko thể sử dụng dịch vụ web là sao ?
    Mong các cao thủ giúp đỡ.
    Hi bạn,
    Thay vì dùng
    Bạn chỉ cần dùng 1 câu
    static (dmz,outside) 203.200.2.10 172.16.1.1 netmask 255.255.255.255
    Còn port thì bạn đã dùng ACL để cho phép cái nào chạy, cái nào không rồi phía bên trên rồi.
    Làm rồi thử lại nhé.
    Nếu vẫn chưa được kiểm tra xem nếu nối trực tiếp thì client có truy cập được web server không
    Cám ơn bạn,
    Phạm Minh Tuấn
    Yahoo : phamminhtuan_vnpro
    hi...vấn đề của bạn mình củng đã từng gặp .
    bạn không sử dụng identity nat nữa mà thay bằng lệnh global (dmz) 1 interface.
    chúc bạn thành công!!!
    • Working...
