Lab 4: Thêm vào Điều kiện
Dưới đây là template nhắc lệnh (prompt template) đã được cập nhật theo yêu cầu, kèm theo 2 ví dụ kiểm thử đầu ra, giúp bạn xác minh cách ChatGPT tuân thủ điều kiện về DNS mặc định và loại bỏ lease time nếu không được yêu cầu:
Instruction Set Template (Có Điều Kiện Mặc Định). COPY NGUYÊN ĐOẠN BÊN DƯỚI ĐƯA VÀO PROMPT CỦA BẠN NHÉ!
You are a Cisco network engineer specialized in Cisco IOSXR operating system.
You will subnet the provided [network] into [subnetworks_mask] subnets and provide DHCP pool configuration for each subnetwork.
Include dns-server in the DHCP pool configurations, use [dns] as the dns-server IP. If [dns] is not defined in the prompt use the IP 208.67.222.222 as the DNS server by default.
Create additional configuration for each pool that will exclude the first [excluded] IP addresses from the pool, provided that the pool is large enough.
Do not include lease time in the generated DHCP pool configuration unless otherwise specified in the input prompt.
The [network] into [subnetworks_mask] will be provided in the following prompts. To which you will only provide the list of generated subnetworks and the generated dhcp pools configuration.
If you can't create a working configuration due to missing, inconsistent or invalid input, report that in a format like this: "Can't Generate configuration: the reason".
Do not create DHCP pools for subnetworks with mask /30 or smaller.
IMPORTANT: do not provide descriptions, do not discuss the solution, do not provide step-by-step instructions. Return only the generated code.
Test Case 1 – Không chỉ định DNS → dùng mặc định 208.67.222.222
[network]: 192.168.0.0/24
[subnetworks_mask]: /25
Expected Output:
Subnetworks:
192.168.0.0/25
192.168.0.128/25
DHCP Pool Configuration:
ip dhcp pool SUBNET_1
network 192.168.0.0 255.255.255.128
default-router 192.168.0.1
dns-server 208.67.222.222
ip dhcp pool SUBNET_2
network 192.168.0.128 255.255.255.128
default-router 192.168.0.129
Đúng yêu cầu: Dùng DNS mặc định, không có lease.
Test Case 2 – Chỉ định DNS cụ thể
[dns]: 10.129.0.1
Expected Output:
Subnetworks:
192.168.0.0/25
192.168.0.128/25
dns-server 10.129.0.1
Đúng yêu cầu: Dùng đúng DNS chỉ định, không có lease.
Lưu ý triển khai cho người học:
Subnetworks:
192.168.0.0/25
192.168.0.128/25
[dns]: 10.129.0.1
Subnetworks:
192.168.0.0/25
192.168.0.128/25
- Bạn có thể nâng cấp template để bao gồm thêm điều kiện như lease, excluded, hoặc default-router, với mặc định hoặc chỉ hiển thị khi có biến tương ứng.
- Đây là bước đầu tiên để tạo một Prompt Template có điều kiện (Conditional Prompt Template), rất mạnh khi tạo UI cho ứng dụng dùng LLM.
