I. Mục Tiêu Lab
Thông tin IP mẫu:
III. Các Bước Thực Hiện
Bước 1: Cấu Hình SSH Cho Switch (nếu chưa có)
Switch# configure terminal
Switch(config)# ip domain-name vnpro.local
Switch(config)# crypto key generate rsa
Switch(config)# ip ssh version 2
Switch(config)# line vty 0 15
Switch(config-line)# transport input ssh
Switch(config-line)# login local
Switch(config-line)# exit
Switch(config)# username admin privilege 15 secret vnpro@123
Switch(config)# interface vlan 1
Switch(config-if)# ip address 10.215.15.109 255.255.255.0
Switch(config-if)# no shutdown
Switch(config)# ip default-gateway 10.215.15.1
Bước 2: Tạo File testbed.yaml
devices:
Switch:
type: switch
os: iosxe
credentials:
default:
username: admin
password: vnpro@123
connections:
vty:
protocol: ssh
ip: 10.215.15.109
port: 22
ssh_options: -o KexAlgorithms=+diffie-hellman-group1-sha1 -o HostKeyAlgorithms=+ssh-rsa -o Ciphers=aes128-cbc,3des-cbc,aes192-cbc,aes256-cbc
Bước 3: Viết Script MCP Server (switch_mcp.py)
from typing import Any, Dict
from mcp.server.fastmcp import FastMCP
from genie.conf import Genie
# Khởi tạo máy chủ FastMCP
mcp = FastMCP("MCP pyATS")
@mcp.tool()
def get_switch_version() -> Dict[str, Any]:
try:
testbed_file = "testbed.yaml"
testbed = Genie.init(testbed_file)
device = testbed.devices['Switch']
device.connect(logfile=False, log_stdout=False)
output = device.parse('show version')
device.disconnect()
return {
"status": "success",
"version_info": output
except Exception as e:
import traceback
return {
"status": "error",
"message": str(e),
"traceback": traceback.format_exc()
if __name__ == "__main__":
mcp.run()
Bước 4: Khởi động Claude Desktop
"mcpServers": {
"switch_version": {
"command": "python3",
"args": [
"/Users/minh/PycharmProjects/pyATS/.venv/switch_mcp.py",
"/Users/minh/PycharmProjects/pyATS/.venv/testbed.yaml"
Kết Quả Mẫu
Khi Claude gọi:
@switch_version.get_switch_version()
Claude sẽ nhận về:
"version_info": {
"version": {
"version_short": "15.2(2)E7",
"uptime": "2 days, 4 hours, 32 minutes",
"hostname": "Switch",
IV. Troubleshooting Checklist
V. Kiến Thức Bạn Học Được Qua Lab
- Triển khai MCP Server cho pyATS.
- Tự động hóa kiểm thử phiên bản Switch Cisco qua API.
- Tích hợp MCP server vào Claude Developer Environment.
| Switch Cisco | OS: IOS XE (thật hoặc GNS3/EVE-NG) |
| Máy trạm | Python 3.9+, pyATS, FastMCP, Claude Desktop |
| File cấu hình | testbed.yaml |
| Switch | 10.215.15.109/24 |
devices:
Switch:
type: switch
os: iosxe
credentials:
default:
username: admin
password: vnpro@123
connections:
vty:
protocol: ssh
ip: 10.215.15.109
port: 22
@mcp.tool()
try:
device.disconnect()
return {
import traceback
return {
"status": "error",
"message": str(e),
mcp.run()
- Mở Claude Developer Mode (Claude Desktop).
- Đảm bảo bạn đang dùng bản build hỗ trợ MCP Custom Servers.
"mcpServers": {
"switch_version": {
"args": [
- Save file và restart Claude.
Kết Quả Mẫu
Khi Claude gọi:
Claude sẽ nhận về:
"version_info": {
"version": {
| MCP Server không chạy | Kiểm tra Python env, log lỗi, đường dẫn file script |
| SSH không kết nối được | Kiểm tra IP, SSH config, username/password trên Switch |
| Không parse được dữ liệu | Kiểm tra OS version của Switch có hỗ trợ parser hay không |
| Claude không nhận server | Kiểm tra claude_desktop_config.json và restart lại Claude |
| API call từ Claude bị fail | Kiểm tra port, firewall local, endpoint URL |
- Xây dựng MCP Automation Server cho Network Test.
- Tích hợp Claude Developer Environment với MCP.
- Thực hiện kiểm thử Switch qua API Automation.
- Xử lý lỗi, debug khi kết nối automation giữa pyATS và AI Workflow.
