You've created an MCP server and want to test your tools before connecting them to Claude. What's the best way to do this? - Use the MCP Inspector in your browser
You're building a document system where users can type @document_name to reference files. What MCP feature is best for exposing the document contents? - Resources
Your MCP server and client need to communicate. What's the most common way they connect during development? - Through standard input/output on the same machine
You're building a chatbot that needs to access GitHub data. What is the main benefit of using MCP instead of writing your own GitHub integration? - MCP handles the tool definitions and execution for you
You want to create a tool for your MCP server that reads document contents. Using the Python SDK, what's the easiest way to define this tool? - Use the @mcp.tool decorator on a function
You want to provide users with a high-quality, pre-tested instruction for formatting documents. What MCP feature should you use? - Prompts
