  • Max hopcount của các giao thức định tuyến ??
    Max. Hopcounts
    RIP1/RIP2 15
    IGRP 255
    EIGRP 224
    OSPF unlimited
    Nhưng...
    metric maximum-hops
    To have the IP routing software advertise as unreachable those routes with a hop count higher than is specified by the command (Enhanced Interior Gateway Routing Protocol [EIGRP] only), use the metric maximum-hops command in router configuration mode. To reset the value to the default, use the no form of this command.
    metric maximum-hops {hops-number}
    no metric maximum-hops {hops-number}
    Syntax Description
    hops-number
    Maximum hop count (in decimal). The default value is 100 hops; the maximum number of hops that can be specified is 255.
    Trích từ: http://www.cisco.com/univercd/cc/td/....htm#wp1000064
    Vậy xin hỏi maxhopcount của Eigrp là bao nhiêu ?
    .:Share link
    Tut & test CCNA: http://www.thebrightsparkshome.com/BSIG/default.aspx
    CCNA forum:
    http://www.sadikhov.com/forum/lofive...x.php/f33.html
    IGRP has a maximum hop count of 255. EIGRP has a maximum hop count limit of 224. This is more than adequate to support the largest, properly designed internetworks. @-) $-) :106: :105:
      Các bạn cho mình hỏi làm sao trong các giao thức định tuyến (trừ RIP) biết hop count của các network là bao nhiêu?
      Thanks
