  • Router 2811 khởi động lỗi
    Cty mình có router2811 đã cấu hình sẵn rồi. Nhưng hôm nay cúp điên đội ngột, nên khi khởi động báo lệnh rommon 1 > ..... Mình đã thử dùng lệng confreg 2142 nhưng không ăn thua . Nhờ anh Minh giúp đỡ. Cám ơn anh nhiều
    Router báo như sau :
    program load complete, entry point: 0x8000f000, size: 0xc940
    program load complete, entry point: 0x8000f000, size: 0xe360d8
    Error : compressed image checksum is incorrect 0xFA5CBC88
    Expected a checksum of 0x865CBC91
    *** System received a Software forced crash ***
    signal= 0x17, code= 0x5, context= 0x80014ac0
    PC = 0x8000f0d4, Cause = 0x20, Status Reg = 0x3040a803
    c2811 processor with 262144 Kbytes of main memory
    Main memory is configured to 64 bit mode with ECC enabled
    Readonly ROMMON initialized
    rommon 1 >
    Hi Trung
    Chỉnh thanh ghi thành 0x2102, sau đó, reset lại xem.
      IOS bi crash. Neu reload khong duoc thi upload new IOS
      Thương Nhất Là Mẹ,
      Hận Nhất Là Thời Gian.
        Corrupt software image:
        When booting, a router may detect that a Cisco IOS software image is corrupt, return the compressed image checksum is incorrect message, and attempt to reload, reporting the event as a software-forced crash:
        Error : compressed image checksum is incorrect 0x54B2C70A
        Expected a checksum of 0x04B2C70A
        signal= 0x17, code= 0x5, context= 0x0
        PC = 0x800080d4, Cause = 0x20, Status Reg = 0x3041f003
        This can be caused by a Cisco IOS software image that has actually been corrupted during transfer to the router, in which case it can be resolved by loading a new image onto the router. [Search for a ROMMON recovery method for your platform here.]
        It may also be caused by faulty memory hardware or by a software bug.
        ( http://www.cisco.com/warp/public/122...ubleshoot.html )
        Bạn thử dùng IOS khác xem sao.
        Chúc thành công :)
          - IOS bi loi, copy lai la duoc. Co 2 cach copy
          1 - Dung card reader
          2 -trong Rommon dung len tftpdownload
