  • Chứng thực PAP/CHAP (file.net)
    FILE .NET :
    autostart = False
    [localhost]
    [[3725]]
    image = \Program Files\Dynamips\images\C3725-AD.BIN
    ram = 128
    [[ROUTER R1]]
    model = 3725
    s2/0 = R2 s2/0
    idlepc = 0x612f1a04
    [[ROUTER R2]]
    model = 3725
    idlepc = 0x612f1a04
    Đặt IP :
    R1(config)#int s2/0
    R1(config-if)#ip add 200.200.200.1 255.255.255.252
    R1(config-if)#no shut
    R1(config-if)#exit
    R1(config)#
    *Mar 1 00:02:47.599: %LINK-3-UPDOWN: Interface Serial2/0, changed state to up
    R1(config)#
    *Mar 1 00:02:48.607: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/0
    changed state to up
    R1(config)#^Z
    R1#ping
    *Mar 1 00:05:08.463: %SYS-5-CONFIG_I: Configured from console by console
    R1#ping 200.200.200.2
    Sending 5, 100-byte ICMP Echos to 200.200.200.2, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 48/80/120 ms
    R1#
    R2(config)#int s2/0
    R2(config-if)#ip add 200.200.200.2 255.255.255.252
    R2(config-if)#no shut
    R2(config-if)#exit
    R2(config)#
    *Mar 1 00:02:55.263: %LINK-3-UPDOWN: Interface Serial2/0, changed state to up
    R2(config)#
    *Mar 1 00:02:56.271: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/0
    changed state to up
    R2(config)#^Z
    R2#pi9g
    *Mar 1 00:03:00.731: %SYS-5-CONFIG_I: Configured from console by console
    R2#ping 200.200.200.1
    Sending 5, 100-byte ICMP Echos to 200.200.200.1, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 48/77/100 ms
    R2#
    Chứng thực PAP :
    1. Trường hợp chứng thực thành công :
    R1
    R2 :
    Success rate is 100 percent (5/5), round-trip min/avg/max = 44/71/120 ms
    R1#
    Success rate is 100 percent (5/5), round-trip min/avg/max = 48/71/92 ms
    R2#
    Debug PPP authentication :
    R1#debug ppp authen
    R1#debug ppp authentication
    PPP authentication debugging is on
    R1#conf t
    R1(config)#int s2/0
    R1(config-if)#shut
    R1(config-if)#
    *Mar 1 00:11:55.291: %LINK-5-CHANGED: Interface Serial2/0, changed state to adm
    inistratively down
    *Mar 1 00:11:56.291: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/0,
    changed state to down
    R1(config-if)#
    Khi R1 muốn thiết lập với R2 thì sẽ bị yêu cầu gửi thông tin chứng thực :
    Username và Password  PASS
    LCP  PASS
    IPCP  PASS
    CDPCP  PASS.
    2. Trường hợp chứng thực thất bại :
    R1(config)#no user ti
    R1(config)#user ti pass abc
    Vào interface Serial của 2 router shut và no shut :
    Chứng thực CHAP :
    R1
    R1(config)#user r2 pass abc
    R1(config)#int s2/0
    R1(config-if)#enca
    R1(config-if)#encapsulation ppp
    R1(config-if)#ppp authen chap
    R1(config-if)#exit
    R1(config)#
    R2
    R2(config)#user r1 pass abc
    R2(config)#int s2/0
    R2(config-if)#enca
    R2(config-if)#encapsulation ppp
    R2(config-if)#ppp authen chap
    R2(config-if)#exit
    R2(config)#
    Khi R2 muốn thiết lập kết nối với R1, nó sẽ gửi thông tin chứng thực không bao gồm password, được mã hóa MD5.
    Tiến trình chứng thực diễn ra ở 3 bước bắt tay (3 way handshake)
    R2#debug ppp authen
    R2#debug ppp authentication
    R2#conf t
    R2(config)#int s2/0
    R2(config-if)#shut
    R2(config-if)#
    *Mar 1 00:40:25.963: %LINK-5-CHANGED: Interface Serial2/0, changed state to adm
    inistratively down
    *Mar 1 00:40:26.963: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/0,
    R2(config-if)#
    *Mar 1 00:40:37.579: %LINK-3-UPDOWN: Interface Serial2/0, changed state to up
    R2(config-if)#
    *Mar 1 00:40:37.587: Se2/0 PPP: Using default call direction
    *Mar 1 00:40:37.591: Se2/0 PPP: Treating connection as a dedicated line
    *Mar 1 00:40:37.595: Se2/0 PPP: Session handle[C000021] Session id[127]
    *Mar 1 00:40:37.595: Se2/0 PPP: Authorization required
    *Mar 1 00:40:37.703: Se2/0 CHAP: O CHALLENGE id 2 len 23 from "R2"  O : out
    *Mar 1 00:40:37.703: Se2/0 CHAP: I CHALLENGE id 3 len 23 from "R1" I : in
    *Mar 1 00:40:37.719: Se2/0 CHAP: Using hostname from unknown source
    *Mar 1 00:40:37.723: Se2/0 CHAP: Using password from AAA
    *Mar 1 00:40:37.723: Se2/0 CHAP: O RESPONSE id 3 len 23 from "R2"
    *Mar 1 00:40:37.727: Se2/0 CHAP: I RESPONSE id 2 len 23 from "R1"
    *Mar 1 00:40:37.739: Se2/0 PPP: Sent CHAP LOGIN Request
    *Mar 1 00:40:37.771: Se2/0 PPP: Received LOGIN Response PASS
    *Mar 1 00:40:37.779: Se2/0 PPP: Sent LCP AUTHOR Request
    *Mar 1 00:40:37.783: Se2/0 PPP: Sent IPCP AUTHOR Request
    *Mar 1 00:40:37.815: Se2/0 LCP: Received AAA AUTHOR Response PASS
    *Mar 1 00:40:37.819
    R2(config-if)#: Se2/0 IPCP: Received AAA AUTHOR Response PASS
    *Mar 1 00:40:37.823: Se2/0 CHAP: O SUCCESS id 2 len 4
    *Mar 1 00:40:38.111: Se2/0 CHAP: I SUCCESS id 3 len 4
    *Mar 1 00:40:38.119: Se2/0 PPP: Sent CDPCP AUTHOR Request
    *Mar 1 00:40:38.127: Se2/0 PPP: Sent IPCP AUTHOR Request
    *Mar 1 00:40:38.143: Se2/0 CDPCP: Received AAA AUTHOR Response PASS
    R2(config-if)#
    *Mar 1 00:40:39.115: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/0,
    changed state to up
    R2(config-if)#^Z
    R2#u all
    *Mar 1 00:40:44.695: %SYS-5-CONFIG_I: Configured from console by console
    R2#u all
    All possible debugging has been turned off
    R2#
    R2(config)#user r1 pass xyz
    R2(config)#int s2/0
    R2(config-if)#shut
    R2(config-if)#
    *Mar 1 00:50:02.499: %LINK-5-CHANGED: Interface Serial2/0, changed state to adm
    inistratively down
    *Mar 1 0003.499: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/0,
    R2(config-if)#no shut^Z
    R2#
    *Mar 1 0019.695: %SYS-5-CONFIG_I: Configured from console by consoled
    R2#debug p
    *Mar 1 0021.651: %LINK-3-UPDOWN: Interface Serial2/0, changed state to up
    R2#debug ppp authen
    R2#conf t
     Vào interface Serial của 2 router shut và no shut :
    R2(config-if)#
    *Mar 1 0036.339: Se2/0 CHAP: O CHALLENGE id 3 len 23 from "R2"
    *Mar 1 0036.343: Se2/0 CHAP: I CHALLENGE id 4 len 23 from "R1"
    *Mar 1 0036.359: Se2/0 CHAP: Using hostname from unknown source
    *Mar 1 0036.363: Se2/0 CHAP: Using password from AAA
    *Mar 1 0036.363: Se2/0 CHAP: O RESPONSE id 4 len 23 from "R2"
    *Mar 1 0036.455: Se2/0 CHAP: I RESPONSE id 3 len 23 from "R1"
    *Mar 1 0036.463: Se2/0 PPP: Sent CHAP LOGIN Request
    *Mar 1 0036.475: Se2/0 PPP: Received LOGIN Response FAIL
    *Mar 1 0036.479: Se2/0 CHAP: O FAILURE id 3 len 25 msg is "Authentication f
    ailed"
    R2(config-if)#
    *Mar 1 0040.499: Se2/0 PPP: Authorization required
    *Mar 1 0040.639: Se2/0 CHAP: O CHALLENGE id 4 len 23 from "R2"
    *Mar 1 0040.887: Se2/0 CHAP: I CHALLENGE id 5 len 23 from "R1"
    *Mar 1 0040.899: Se2/0 CHAP: Using hostname from unknown source
    *Mar 1 0040.903: Se2/0 CHAP: Using password from AAA
    *Mar 1 0040.903: Se2/0 CHAP: O RESPONSE id 5 len 23 from "R2"
    *Mar 1 0040.983: Se2/0 CHAP: I RESPONSE id 4 len 23 from "R1"
    *Mar 1 0040.987: Se2/0 CHAP: I FAILURE id 5 len 25 msg is "Authentication f
    ailed"
    *Mar 1 0040.999: Se2/0 PPP: Sent CHAP LOGIN Request
    *Mar 1 0041.003: Se2/0 PPP: Received LOGIN Response FAIL
    R2(config-if)#
    *Mar 1 0041.003: Se2/0 CHAP: O FAILURE id 4 len 25 msg is "Authentication f
    ailed"
    R2(config-if)#
    *Mar 1 0045.107: Se2/0 PPP: Authorization required
    *Mar 1 0045.199: Se2/0 CHAP: O CHALLENGE id 5 len 23 from "R2"
    *Mar 1 0045.203: Se2/0 CHAP: I CHALLENGE id 6 len 23 from "R1"
    *Mar 1 0045.223: Se2/0 CHAP: Using hostname from unknown source
    *Mar 1 0045.223: Se2/0 CHAP: Using password from AAA
    *Mar 1 0045.227: Se2/0 CHAP: O RESPONSE id 6 len 23 from "R2"
    *Mar 1 0045.295: Se2/0 CHAP: I RESPONSE id 5 len 23 from "R1"
    *Mar 1 0045.307: Se2/0 PPP: Sent CHAP LOGIN Request
    *Mar 1 0045.315: Se2/0 CHAP: I FAILURE id 6 len 25 msg is "Authentication f
    ailed"
    R2(config-if)#
    *Mar 1 0047.375: Se2/0 PPP: Authorization required
    *Mar 1 0047.551: Se2/0 CHAP: O CHALLENGE id 6 len 23 from "R2"
    *Mar 1 0047.551: Se2/0 CHAP: I CHALLENGE id 7 len 23 from "R1"
    *Mar 1 0047.567: Se2/0 CHAP: Using hostname from unknown source
    *Mar 1 0047.567: Se2/0 CHAP: Using password from AAA
    *Mar 1 0047.571: Se2/0 CHAP: O RESPONSE id 7 len 23 from "R2"
    *Mar 1 0047.639: Se2/0 CHAP: I RESPONSE id 6 len 23 from "R1"
    *Mar 1 0047.647: Se2/0 PPP: Sent CHAP LOGIN Request
    *Mar 1 0047.655: Se2/0 PPP: Received LOGIN Response FAIL
    *Mar 1 0047.659: Se2/0 CHAP: O FAILURE id 6 len 25 msg is "Authentication f
    ailed"
    R2(config-if)#
    *Mar 1 009.747: Se2/0 PPP: Authorization required
    *Mar 1 0049.823: Se2/0 CHAP: O CHALLENGE id 7 len 23 from "R2"
    *Mar 1 0049.887: Se2/0 CHAP: I CHALLENGE id 8 len 23 from "R1"
    *Mar 1 0049.903: Se2/0 CHAP: Using hostname from unknown source
    *Mar 1 0049.903: Se2/0 CHAP: Using password from AAA
    *Mar 1 0049.907: Se2/0 CHAP: O RESPONSE id 8 len 23 from "R2"
    *Mar 1 0049.959: Se2/0 CHAP: I RESPONSE id 7 len 23 from "R1"
    *Mar 1 0049.963: Se2/0 CHAP: I FAILURE id 8 len 25 msg is "Authentication f
    ailed"
    *Mar 1 0049.971: Se2/0 PPP: Sent CHAP LOGIN Request
    R2(config-if)#^Z
    R2#u
    *Mar 1 0052.095: Se2/0 PPP: Authorization required
    *Mar 1 0052.151: %SYS-5-CONFIG_I: Configured from console by console
    R2#u all
    R2#
    *Mar 1 0052.243: Se2/0 CHAP: O CHALLENGE id 8 len 23 from "R2"
    *Mar 1 0052.243: Se2/0 CHAP: I CHALLENGE id 9 len 23 from "R1"
    *Mar 1 0052.259: Se2/0 CHAP: Using hostname from unknown source
    *Mar 1 0052.263: Se2/0 CHAP: Using password from AAA
    *Mar 1 0052.263: Se2/0 CHAP: O RESPONSE id 9 len 23 from "R2"
    *Mar 1 0052.383: Se2/0 CHAP: I RESPONSE id 8 len 23 from "R1"
    *Mar 1 002.391: Se2/0 PPP: Sent CHAP LOGIN Request
    *Mar 1 0052.399: Se2/0 PPP: Received LOGIN Response FAIL
    *Mar 1 0052.403: Se2/0 CHAP: O FAILURE id 8 len 25 msg is "Authentication f
    ailed"
    R2#
    Trần Mỹ Phúc
    tranmyphuc@hotmail.com
    Juniper Certs :
    JNCIP-ENT & JNCIP-SEC
    [version 4.0] Ôn tập CCNA
    R1
    R1(config)#int s2/0
    R1(config-if)#enca
    R1(config-if)#exit
    R1(config)#
    R2
    R2(config)#int s2/0
    R2(config-if)#enca
    R2(config-if)#exit
    R2(config)#
    Với cấu hình như trên thì không phải bắt tay 3 bước 1 lần mà phải 2 lần bắt tay 3 bước. Vì anh cấu hình R1 như là server bắt buộc chứng thực bằng lệnh R1(config-if)#ppp authen chap . tương tự đối với R2.
    Vì thế ở LAB này chỉ cần chứng thực 1 bên là đủ đúng không nhỉ?
      ủa... mình tưởng chỉ dùng câu lệnh show interface serial ... thấy LCP open là đc mà ( khi dùng authen đúng thì nó mới open đc chứ)
