  • FINAL S4,mong các anh và các bạn giúp đỡ
    Em có một số câu hỏi mong các anh và các bạn trả lời giúp em,em đang cần gấp,em xin chân thành cảm ơn !
    24/When configuring remote access to a router, what is the significance of the no password command on a VTY line?
    Logins are prevented on that line.
    No password is required to log in to that line.
    The remote user is not allowed to change the password for that line.
    The remote user is prompted to change the line password after connecting to the router.
    28/What type of ACL can be used to force a user to authenticate to the router before accessing a network?
    standard
    dynamic
    reflexive
    time-based
    29/Which two functions are provided by the Local Management Interface (LMI) that is used in Frame Relay networks? (Choose two.)
    flow control
    error notification
    congestion notification
    the mapping of DLCIs to network addresses
    the sending of keepalive packets to verify operation of the PVC
    32/hình vẽ click
    Refer to the exhibit. Router1 is not able to communicate with its peer that is connected to this interface. Based on the output as shown, what is the most likely cause?
    interface reset
    improper LMI type
    encapsulation failure
    local cable unplugged
    38/hình vẽ click
    Refer to the exhibit. An ACL numbered 101 already exists on this router. What happens if the network administrator issues the commands that are shown in the exhibit?
    The new ACL overwrites the existing ACL.
    The network administrator will receive an error message.
    The existing ACL is modified to include the new commands.
    A second ACL that is numbered 101 is created and contains only the new commands.
    Answer : No password is required to log in to that line.
    Trịnh Anh Luân
    - Search my site
    - Search VNPRO.ORG
    • Phát hành sách chuyên môn
      Mọi người ai có câu trả lời cho các câu hỏi trên mong trả lời giúp với. Mình xin chân thành cảm ơn!
        Câu 24 của bạn trả lời hay đáp án, vì theo tôi câu trả lời là Logins are prevented on that line
        Không biết thì hỏi...Không giỏi thì làm!
          Xin đính chính lại.
          -Nếu cấu hình 1 lệnh "no pass", thì khi telnet vào router này, nó sẽ Logins are prevented on that line
          -Nếu dùng thêm "no login", thì khi telnet vào router này, nó sẽ No password is required to log in to that line.
          Như vậy với đề bài câu này, chỉ nhắc đến no pass command thôi, do đó câu Logins are prevented on that line là đúng nhất !!!
          Trịnh Anh Luân
          - Search my site
          - Search VNPRO.ORG
