  • Help:khong update duoc dyndns tren cisco 877
    Tình hình mà minh mới cấu hình xong cisco 877, đã nat va gán dịch vụ dyndns trên cisco 877. Nhưng gặp gắc rối là không update duoc dyndns khi bi thay đổi ip. Mình đã cấu hình update nhưng vẫn chưa chạy, bro nao biết thì help mình khúc này nhé. thank
    Current configuration : 6672 bytes
    version 12.4
    no service pad
    hostname company
    boot-start-marker
    boot-end-marker
    logging buffered 52000
    no aaa new-model
    clock timezone Bangkok 7
    crypto pki trustpoint TP-self-signed-3934559720
    enrollment selfsigned
    subject-name cn=IOS-Self-Signed-Certificate-3934559720
    revocation-check none
    rsakeypair TP-self-signed-3934559720
    crypto pki certificate chain TP-self-signed-3934559720
    certificate self-signed 01
    3082025A 308201C3 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
    31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
    69666963 6174652D 33393334 35353937 3230301E 170D3032 30333133 30373538
    31345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
    4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 39333435
    35393732 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
    8100B372 8D840BB4 1B137911 06B51B7B 9C4F48EC D2806E86 83F62DA4 EF282EEC
    D582F512 8EF6366C CDB93107 6F080F47 59225063 2E17042F FA3C2DE2 C58DD273
    246A80E9 B8EF5A18 61B6FEF7 2977A96A 296B1665 18552484 DCE75505 354CC35D
    71733C5B C3D22CA2 7C5616E8 2126E8EE E14667E7 49E9CA7A 83522B71 7F021A12
    05C50203 010001A3 8181307F 300F0603 551D1301 01FF0405 30030101 FF302C06
    03551D11 04253023 82217369 735F6B69 6E646572 776F726C 642E6475 796E686F
    2E64796E 646E732E 636F6D30 1F060355 1D230418 30168014 22915390 BAC075E7
    7BE68CD2 B62A4DA8 42F4A9A5 301D0603 551D0E04 16041422 915390BA C075E77B
    E68CD2B6 2A4DA842 F4A9A530 0D06092A 864886F7 0D010104 05000381 810036C9
    30AFB405 D005CA61 964B72A1 D757B5FB 9FB99D49 CF801F49 C07DCCA5 B791B22B
    067C61DA 7BD9E067 47C5B60B DD52C1A0 B41365B0 0118598E 9E654268 4FD7C016
    DE317DDF A911323B 225F9912 77C18AD9 16D8C99B 980ADDDE 69CB8AED C06E3862
    415F8CDA 22A1B144 BFCC08D3 D6F6A055 E9CACC8C ED58F501 75F385FB 6C1F
    quit
    dot11 syslog
    ip cef
    no ip dhcp use vrf connected
    ip dhcp excluded-address 192.168.3.1 192.168.3.9
    ip dhcp excluded-address 192.168.3.101 192.168.3.254
    ip dhcp pool sdm-pool
    import all
    network 192.168.3.0 255.255.255.0
    dns-server 221.133.0.1 221.133.0.2
    default-router 192.168.3.1
    lease infinite
    ip domain name test.dyndns.com
    ip name-server 221.133.0.1
    ip ddns update method sdm-ddns1
    HTTP
    add http://testdyndns:123456@members.dyn...esystem=dyndns
    &hostname=test.dyndns.org&myip=
    interval maximum 0 1 0 0
    username company privilege 15 secret 5 $1$MvEE$a2VS5u2IJkFthOdjWhCVg.
    archive
    log config
    hidekeys
    interface ATM0
    no atm ilmi-keepalive
    dsl operating-mode auto
    interface ATM0.1 point-to-point
    pvc 0/33
    interface FastEthernet0
    interface FastEthernet1
    interface FastEthernet2
    interface FastEthernet3
    interface Vlan1
    description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
    ip ddns update hostname test.dyndns.org
    ip ddns update sdm-ddns1 host members.dyndns.org
    ip nat inside
    ip virtual-reassembly
    ip tcp adjust-mss 1412
    interface Dialer0
    ip address negotiated
    ip mtu 1452
    ip nat outside
    encapsulation ppp
    dialer pool 1
    dialer-group 1
    no cdp enable
    ppp authentication chap pap callin
    ppp chap hostname s_company
    ppp chap password 0 123456
    ppp pap sent-username s_company password 0 123456
    ip forward-protocol nd
    ip route 0.0.0.0 0.0.0.0 Dialer0
    ip http server
    ip http access-class 23
    ip http authentication local
    ip http secure-server
    ip http timeout-policy idle 60 life 86400 requests 10000
    ip nat inside source list 1 interface Dialer0 overload
    i
    access-list 1 permit 192.168.3.0 0.0.0.255
    no cdp run
    control-plane
    banner login ^C
    Cisco Router and Security Device Manager (SDM) is installed on this device.
    This feature requires the one-time use of the username "cisco"
    with the password "cisco". The default username and password have a privilege le
    vel of 15.
    Please change these publicly known initial credentials using SDM or the IOS CLI.
    Here are the Cisco IOS commands.
    username <myuser> privilege 15 secret 0 <mypassword>
    no username cisco
    Replace <myuser> and <mypassword> with the username and password you want to use
    For more information about SDM please follow the instructions in the QUICK START
    GUIDE for your router or go to http://www.cisco.com/go/sdm
    ^C
    login local
    no modem enable
    line aux 0
    line vty 0 3
    privilege level 15
    login local
    transport input telnet ssh
    line vty 4
    privilege level 15
    password xxx
    login
    scheduler max-task-time 5000
    tham khảo link này dùm mình nha:
    Configuring Dynamic DNS (DDNS)for No-ip.com & Dyndns.com on a Cisco router. This article will show you how to successfully configure the DDNS service on a Cisco router.
    Nguyễn Quốc Lễ, CCNP CCSP
    Email: nguyenquocle@wimaxpro.org
    Tel: (08) 35124257
    Fax: (08) 5124314
    Support Forum : http://www. vnpro.org
    Live Chat http://vnpro.org/forum/image.php?u=2...ine=1233770177 : http://www.vnpro.vn/support
    Blog VnPro : http://www.vnpro.org/blog
    Cộng Đồng Mạng Không Dây Việt Nam
      Mình cấu hình như trên nhưng sao vẫn ko update được dyndns, chuyển từ dyndns sang no-ip nhưng vẫn vậy, ko biết có vấn đề gì với đường internet ko nửa, hiện mình đang dùng SPT adsl O:-)
