  • Bài tập cho Vlan ra internet !!!
    Thưa các thầy, em có sơ đồ như thế này:
    Em ko biết mô hình này ngoài thực tế có chạy dc ko ạ @-)
    Em đang gặp vấn đề như sau: các máy bên trong vlan ko ping ra dc ISP trong khi từ RA đã ping ra dc rồi :106:
    Mog các thầy và các bạn giúp em với !!! Em xin cảm ơn !!!
    Em xin post file cấu hình:
    RA:
    hostname R1
    boot-start-marker
    boot-end-marker
    no aaa new-model
    memory-size iomem 5
    ip cef
    interface FastEthernet0/0
    duplex auto
    speed auto
    interface FastEthernet0/0.1
    encapsulation dot1Q 2
    ip address 192.168.2.200 255.255.25
    interface FastEthernet0/1
    ip address 192.168.1.1 255.255.255.
    duplex auto
    speed auto
    interface Serial1/0
    shutdown
    serial restart-delay 0
    interface Serial1/1
    shutdown
    interface Serial1/2
    shutdown
    interface Serial1/3
    shutdown
    ip route 0.0.0.0 0.0.0.0 192.168.1.2
    ip http server
    no ip http secure-server
    control-plane
    line aux 0
    login
    R2:
    hostname R2
    boot-start-marker
    boot-end-marker
    no aaa new-model
    memory-size iomem 5
    ip cef
    shutdown
    duplex auto
    speed auto
    ip nat inside
    ip virtual-reassembly
    duplex auto
    speed auto
    interface Serial1/0
    ip address 210.10.10.2 255.255.255.0
    ip nat outside
    interface Serial1/1
    shutdown
    interface Serial1/2
    shutdown
    interface Serial1/3
    shutdown
    ip route 0.0.0.0 0.0.0.0 210.10.10.1
    ip http server
    ip nat inside source list 10 interface Serial1/0 overload
    access-list 10 permit 192.168.1.0 0.0.0.255
    control-plane
    line aux 0
    login
    ISP:
    hostname ISP
    boot-start-marker
    boot-end-marker
    no aaa new-model
    memory-size iomem 5
    ip cef
    interface Loopback1
    ip address 65.5.5.1 255.255.255.0
    shutdown
    duplex auto
    speed auto
    shutdown
    duplex auto
    speed auto
    interface Serial1/0
    ip address 210.10.10.1 255.255.255.0
    interface Serial1/1
    shutdown
    interface Serial1/2
    shutdown
    interface Serial1/3
    shutdown
    ip http server
    control-plane
    line aux 0
    login
    SW:
    hostname SW
    boot-start-marker
    boot-end-marker
    no aaa new-model
    memory-size iomem 5
    ip cef
    no ip dhcp use vrf connected
    ip dhcp pool vlan2
    network 192.168.2.0 255.255.255.0
    default-router 192.168.2.200
    shutdown
    duplex auto
    speed auto
    shutdown
    duplex auto
    speed auto
    interface FastEthernet1/0
    interface FastEthernet1/1
    interface FastEthernet1/2
    switchport access vlan 2
    interface FastEthernet1/3
    switchport access vlan 3
    interface FastEthernet1/4
    switchport access vlan 4
    interface FastEthernet1/5
    interface FastEthernet1/6
    interface FastEthernet1/7
    interface FastEthernet1/8
    interface FastEthernet1/9
    interface FastEthernet1/10
    switchport mode trunk
    interface FastEthernet1/11
    interface FastEthernet1/12
    interface FastEthernet1/13
    interface FastEthernet1/14
    interface FastEthernet1/15
    interface Vlan1
    interface Vlan2
    ip http server
    control-plane
    line aux 0
    login
    RA ping được là nhờ Default Gateway, còn các host trong Vlan chưa đi được là do chưa định tuyến, nếu đây là mô hình thực tế thì bạn cần phải NAT nữa, vì Ip private ko thể ra Internet.
    Trịnh Anh Luân
    - Search my site
    - Search VNPRO.ORG
    • Phát hành sách chuyên môn
      Bạn xem lại cấu hình Interface Vlan Routing trên con RA và cấu hình trên con SW
      HỌC QUẢN TRỊ MẠNG - HOCQUANTRIMANG.COM
      LÝ QUANG THIỆN - MASAN'S NETWORK ADMIN
        Bạn cấu hình Định tuyến vlan còn thiếu !
        Trịnh Anh Luân
        - Search my site
        - Search VNPRO.ORG
          RA vẫn ra được mạng ngoài là do bạn đã thực hiện NAT cho cổng F0/1 của RA thuộc mạng 192.168.1.0 ra ngoài. Còn các VLANs bên trong bạn chưa NAT ra ngoài cho nó nên nó không thể nào ping tới được ISP được vì địa chỉ Private không thể giao tiếp được với địa chỉ Public khi ta chưa thực hiện NAT
            Cách thứ 2 là bạn sữa cái:
            access-list 10 permit any
            là được,ko cần Nat thêm ở RA,
            Hugo
