Các bạn xem dùm cấu hình trunking vlan này đi, có lỗi ở đâu mà sao các host ko thấy nhau được vậy? giúp tụi mình với.
Current configuration : 1496 bytes
version 12.1
no service single-slot-reload-enable
service timestamps log uptime
hostname phuong
no logging buffered
logging rate-limit console 10 except errors
ip subnet-zero
no ip finger
ip host Trung 210.120.15.65 210.120.15.34
ip host Nhon 210.120.15.98 210.120.15.129
ip host Phoenix 210.120.15.130
no mgcp timer receive-rtcp
call rsvp-sync
interface FastEthernet0/0
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation isl 1
ip address 210.120.15.162 255.255.255.224
no ip redirects
interface FastEthernet0/0.2
encapsulation isl 2
ip address 210.120.15.194 255.255.255.224
no ip redirects
interface Serial0/0
ip address 210.120.15.97 255.255.255.224
clockrate 64000
interface FastEthernet0/1
shutdown
duplex auto
speed auto
interface Serial0/1
ip address 210.120.15.66 255.255.255.224
interface Ethernet1/0
shutdown
half-duplex
interface Ethernet1/1
shutdown
half-duplex
interface Ethernet1/2
shutdown
half-duplex
interface Ethernet1/3
shutdown
half-duplex
router rip
network 210.120.15.0
ip kerberos source-interface any
ip classless
no ip http server
snmp-server packetsize 4096
snmp-server manager
dial-peer cor custom
gatekeeper
shutdown
transport input none
line aux 0
no scheduler allocate
#sh vlans
Virtual LAN ID: 1 (Inter Switch Link Encapsulation)
vLAN Trunk Interface: FastEthernet0/0.1
Protocols Configured: Address: Received: Transmitted:
IP 210.120.15.162 0 38
Virtual LAN ID: 2 (Inter Switch Link Encapsulation)
vLAN Trunk Interface: FastEthernet0/0.2
IP 210.120.15.194 0 35
phuong#sh int fa0/0.1
FastEthernet0/0.1 is up, line protocol is up
Hardware is AmdFE, address is 0002.16ac.f8a0 (bia 0002.16ac.f8a0)
Internet address is 210.120.15.162/27
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Encapsulation ISL Virtual LAN, Color 1.
ARP type: ARPA, ARP Timeout 04:00:00
#sh int fa0/0.1 2
FastEthernet0/0.2 is up, line protocol is up
Internet address is 210.120.15.194/27
Encapsulation ISL Virtual LAN, Color 2.
#sh int fa0/0
FastEthernet0/0 is up, line protocol is up
Encapsulation ARPA, loopback not set
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:31, output 00:00:06, output hang never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
376 packets input, 78176 bytes
Received 376 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog
0 input packets with dribble condition detected
978 packets output, 156003 bytes, 0 underruns(0/0/0)
0 output errors, 0 collisions, 6 interface resets
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier
0 output buffer failures, 0 output buffers swapped out
version 12.1
hostname phuong
no logging buffered
ip subnet-zero
no ip finger
call rsvp-sync
duplex auto
speed auto
encapsulation isl 1
no ip redirects
encapsulation isl 2
no ip redirects
interface Serial0/0
clockrate 64000
shutdown
duplex auto
speed auto
interface Serial0/1
shutdown
half-duplex
shutdown
half-duplex
shutdown
half-duplex
shutdown
half-duplex
router rip
ip classless
no ip http server
snmp-server manager
gatekeeper
shutdown
line aux 0
#sh vlans
#sh int fa0/0.1 2
#sh int fa0/0
0 watchdog
