xin hỏi về cách cấu hình nat dùng hsrp
  • xin hỏi về cách cấu hình nat dùng hsrp
    Xin mọi người chỉ giúp làm sao để dùng nat pool thay thế cho số dòng lệnh quá nhiều như sau:
    redundancy
    track 1 interface GigabitEthernet0/0 line-protocol
    track 2 interface GigabitEthernet0/1 line-protocol
    description $ETH-LAN$
    ip address 192.168.0.2 255.255.255.0
    ip nat inside
    ip virtual-reassembly
    duplex auto
    speed auto
    standby 1 ip 192.168.0.1
    standby 1 timers 1 3
    standby 1 priority 110
    standby 1 preempt delay minimum 1800
    standby 1 authentication mobionrt
    standby 1 track 2 decrement 10
    description $ETH-WAN$
    ip address 203.191.200.2 255.255.255.0
    ip nat outside
    duplex auto
    speed auto
    standby 0 priority 105
    standby 2 ip 203.191.200.1
    standby 2 priority 105
    standby 2 preempt delay minimum 60 reload 60 sync 60
    standby 2 name HSRP_IN
    standby 2 track 1 decrement 20
    ip nat Stateful id 1
    redundancy HSRP_IN
    mapping-id 1
    as-queuing disable
    protocol udp
    ip nat translation udp-timeout 120
    ip nat translation dns-timeout 120
    ip nat inside source static 192.168.10.101 203.191.200.11 redundancy HSRP_IN mapping-id 1
    ip nat inside source static 192.168.10.102 203.191.200.12 redundancy HSRP_IN mapping-id 1
    ip nat inside source static 192.168.10.103 203.191.200.13 redundancy HSRP_IN mapping-id 1
    ip nat inside source static 192.168.10.104 203.191.200.14 redundancy HSRP_IN mapping-id 1
    ip nat inside source static 192.168.10.105 203.191.200.15 redundancy HSRP_IN mapping-id 1
    ip nat inside source static 192.168.10.106 203.191.200.16 redundancy HSRP_IN mapping-id 1
    ip nat inside source static 192.168.10.107 203.191.200.17 redundancy HSRP_IN mapping-id 1
    ip nat inside source static 192.168.10.108 203.191.200.18 redundancy HSRP_IN mapping-id 1
    ip nat inside source static 192.168.10.109 203.191.200.19 redundancy HSRP_IN mapping-id 1
    ip nat inside source static 192.168.10.120 203.191.200.10 redundancy HSRP_IN mapping-id 1
    ip nat inside source static 192.168.10.228 203.191.200.128 redundancy HSRP_IN mapping-id 1
    ip nat inside source static 192.168.20.129 203.191.200.129 redundancy HSRP_IN mapping-id 1
    ip nat inside source static 192.168.20.130 203.191.200.130 redundancy HSRP_IN mapping-id 1
    ip nat inside source static 192.168.20.131 203.191.200.131 redundancy HSRP_IN mapping-id 1
    ip nat inside source static 192.168.20.132 203.191.200.132 redundancy HSRP_IN mapping-id 1
    ip nat inside source static 192.168.20.133 203.191.200.133 redundancy HSRP_IN mapping-id 1
    ip nat inside source static 192.168.20.134 203.191.200.134 redundancy HSRP_IN mapping-id 1
    ip nat inside source static 192.168.20.135 203.191.200.135 redundancy HSRP_IN mapping-id 1
    ip nat inside source static 192.168.20.136 203.191.200.136 redundancy HSRP_IN mapping-id 1
    ip nat inside source static 192.168.20.137 203.191.200.137 redundancy HSRP_IN mapping-id 1
    ip nat inside source static 192.168.20.138 203.191.200.38 redundancy HSRP_IN mapping-id 1
    ip nat inside source static 192.168.20.254 203.191.200.254 redundancy HSRP_IN mapping-id 1
    access-list 1 permit 192.168.10.0 0.0.0.255
    access-list 2 permit 192.168.20.0 0.0.0.255
    Xin cảm ơn nhiều.
