cho mình hỏi số lượng router tối đa trong 1 hệ thống dùng OSPF là bao nhiêu.
số lượng router tối đa trong 1 hệ thống dùng giao thức OSPF
Bạn xem theo link này: http://puck.nether.net/pipermail/cis...ch/039383.html
Alcatel says 200:
"Concerning the number of router per area, we generally consider that the
maximum number of router per AS is 200."
IS-IS Wiki says 50:
"While OSPF only supports 50 routers in a single area, IS-IS can support up
to one thousand routers per area."
[and no, the OSPF Wikipedia entry doesn't state anything on the matter]
Imagestream says 40-50:
"Nevertheless, a general rule of thumb is to limit areas to no more than 40
or 50 routers to ensure adequate OSPF network performance."
Cisco is non-commital:
Cisco is a worldwide technology leader. Our purpose is to power an inclusive future for all through software, networking, security, computing, and more solutions.
"The maximum number of routers per area depends on several factors,
including the following:
What kind of area do you have?
What kind of CPU power do you have in that area?
What kind of media?
Will you be running OSPF in NBMA mode?
Is your NBMA network meshed?
Do you have a lot of external LSAs in the network?
Are other areas well summarized?
For this reason, it's difficult to specify a maximum number of routers per
area. Consult your local sales or system engineer for specific network
design help."
Data Network Resource says 60-80:
OSPF tutorial explaining how link state routing occurs using the dijkstra algorithm. Topics covered include, ospf area, stub area, summary advertisement, hello interval, dead interval, NSSA and virtual link.
"60-80 routers are considered to be the maximum to have in one area."
So, what to do you use and if you follow some other rule of thumb, do you
have a web reference to point me to?
Thanks,
Hank Nussbacher
http://www.interall.co.ilTừ nay quyết chí đi tu, ráng luyện công mong ngày thành chính quả. Nam mô a di đà phật. Thiện tai. Thiện tai.
Hiện tại mình tính setup 80 con router chạy trên cùng 1 area 2 nhưng mình không sure hệ thống sau đó có chạy nổi và ổn định không? AE nào nắm vững thì advise giúp mình nhé hoặc có link nào nói về giới hạn số lượng router trong 1 OSPF thì chỉ mình giúp. Tks a lot
Nếu như anh định đưa 80 con router vào trong một area mạng thì theo như em nghĩ nó sẽ làm cho mạng của anh hội tụ chậm, vì ospf nó cần thời gian để tất cả các con router trong cùng một area có một map hoàn chỉnh về mạng. Anh để 80 con router trong một area thì thời gian đó sẽ tăng lên. Và lúc ban đầu sẽ tốn rất nhiều băng thông của hệ thống. Ông anh em bảo trong một are thì nên để tối đa là 30 router thôi.
à còn cái này nữa anh ạ, nếu như anh chạy nhiều router dùng chung OSPF ( của anh định dùng là 80 router).Các router ngoài việc anh chia thành nhiều AREA khác nhau, thì anh nên để cho các area khác nhau kết nối chung vào area 0 mà không để cho chúng kết nối với nhau,lúc này area 0 là backbone.
