CCNA4 Final Exam 100/100
  • CCNA4 Final Exam 100/100
    source: http://testccna-4u.blogspot.com/2009...a-4-final.html
    1. A network administrator is asked to design a system to allow simultaneous access to the Internet for 250 users. The ISP for this network can only supply five public IPs. What can be used to accomplish this task?
    routable translation
    dynamic translation
    static translation
    • port address translation
    2. The LAN attached to the Ethernet interface of the Raleigh router shown in the graphic is addressed with private IP addresses. If one public IP is assigned to the company, which commands could be used in a configuration that allows all devices with private IPs in this network to access the Internet? (Choose two.)
    • ip nat inside source list 1 interface serial0 overload
    ip nat outside source list 1 interface serial0 overload
    ip nat inside serial0
    • ip nat inside source list 1 pool Raleigh overload
    ip nat inside Raleigh overload
    ip inside nat source list 1 interface serial0 Raleigh
    3. The command output shown in the graphic was taken from a Cisco 806 broadband router. Which kind of address translation is in effect on this router?
    static
    dynamic
    • overload
    private
    public
    4. Which of the following IP addresses are defined by RFC 1918 as private addresses? (Choose three.)
    • 192.168.146.0/22
    172.10.25.0/16
    • 172.31.0.0/16
    20.0.0.0/8
    • 10.172.92.8/29
    5. How will data be transmitted from the router to the ISP if the router has the two links shown in the graphic?
    Both links will transmit data at the same rate.
    1544 bits can be transmitted simultaneously from the router over the T1 line.
    • Both links will transmit bits one by one.
    The 56K link will transmit a maximum of 53 bits at the same time.
    6. Which statements about DHCP are true? (Choose three.)
    DHCP uses TCP.
    DHCP uses UDP.
    • DHCP sends messages to the server on port 67.
    DHCP sends messages to the server on port 68.
    • DHCP sends messages to the client on port 67.
    • DHCP sends messages to the client on port 68.
    7. Which command would be used to exclude the IP address 192.168.24.5 from the DHCP address pool on a router?
    Router(dhcp-config)# ip dhcp excluded-address 192.168.24.5
    Router# ip dhcp excluded-address 192.168.24.5
    Router(config-excluded)# ip dhcp excluded-address 192.168.24.5
    • Router(config)# ip dhcp excluded-address 192.168.24.5
    Router(config)# excluded-address 192.168.24.5
    Router(dhcp-config)# excluded-address 192.168.24.5
    8. The WAN connection for a nationwide company with 250 offices must support constant connections to core layer services for file sharing, and occasional Internet access. Which combination of WAN technologies will meet these needs with minimum expense?
    Frame Relay PVC for Internet access and ATM for file server access
    Frame Relay PVC for Internet access and ISDN for file server access
    ISDN for Internet access and X.25 for file server access
    • ISDN for Internet access and Frame Relay PVC for file server access
    9. Which command would produce the output shown in the graphic?
    show ip dhcp server statistics
    show ip dhcp binding
    • debug ip dhcp server events
    debug ip dhcp binding
    10. Which of the following devices is used to establish the communications link between the customer equipment and the local loop for digital lines?
    terminal adapter
    modem
    • CSU/DSU
    PBX switch
    ISDN switch
    Frame Relay Switch
    11. Which of the following statements are true about Frame Relay? (Choose three.)
    Frame Relay operation is defined by a series of ISO standards.
    • Frame Relay is a packet switched, connection-oriented, wide area network service.
    Frame Relay only supports point-to-point connections.
    • A router can be considered as data terminal equipment (DTE) in a frame relay system.
    Frame Relay is a cell switched, connection-oriented, wide area network service.
    • Frame Relay networks use a subset of the HDLC protocol to carry information.
    12. ITU-T Q.921 specifies the use of which protocol for sending control and signaling messages between the router and the ISDN switch?
    HDLC
    IPCP
    LAPB
    • LAPD
    NCP
    SS7
    13. A company needs a WAN connection that is capable of transferring voice, video, and data at a minimum data rate of 155 Mbps. Which WAN connection is the best choice?
    X.25
    DSL
    • ATM
    ISDN BRI
    ISDN PRI
    14. Which statement explains why basic DSL is an unpopular WAN connectivity choice for enterprise computer departments that support home users?
    DSL offers insufficient bandwidth to home users.
    DSL requires the installation of new cables, which is not always possible for home users.
    DSL dialup connection time is too slow for business use.
    • DSL has limited geographical availability.
    15. When planning simple WAN connections for a small company, which feature of the three layer hierarchical model makes it a good choice for the WAN topology.
    It provides for redundancy.
    • It allows for easy WAN expansion in case of company growth.
    It is less expensive.
    It provides faster connection time.
    It provides less latency and jitter.
    16. Which of the following terms describes a device that will put data on the local loop?
    DLCI
    CO
    • DCE
    DTE
    PRI
    BRI
    17. Which of the following are supported by a BRI interface on a router? (Choose two.)
    • Two independent channels that can carry analog data with a bandwidth of 64 KHz.
    A single 128 Kbps digital bearer channel.
    Two multiplexed channels carrying digital data.
    A single 64 Kbps signaling channel.
    A multiplexed data channel that can only handle SS7 information.
    • A 16 Kbps delta channel used for signaling purposes.
    18. A network administrator has been asked to provide the network in the United States with an ISDN WAN link. The router available to provide the WAN connection is a non-modular Cisco router with two ****** connections. What must be done to adapt one of the ****** interfaces of this router for the ISDN connection?
    Nothing. The router is already suitable.
    Purchase a BRI WAN interface card to install in the router.
    Purchase a U interface to install in the router.
    • Purchase a TA/NT1 device to install on the router.
    19 (NEED ANSWERS!!!)Which of the following is a function of a DCE device?
    determines the next-hop address for a packet
    • multiplexes signals from several sources
    adapts information for use on a service provider's network
    used to directly connect two DTEs to simulate a WAN network
    20. Why would data frames be discarded in a Frame Relay network? (Choose two.)
    The frame contains an incorrect IP address.
    • An error has been detected in computing the frame check sequence.
    There is not enough bandwidth dedicated for the data contained in the frame.
    Data is transmitted at a rate greater than the access speed.
    • The frame contains an incorrect DLCI.
    21. Which of the following are commonly used as Data Communications Equipment? (Choose two.)
    • modem
    router
    • CSU/DSU
    ISDN Switch
    Frame Relay Switch
    22. Which of the following LCP options can be configured for PPP? (Choose three.)
    • CHAP
    • Stacker
    IPCP
    CDPCP
    • Multilink
    23. Which command will provide for CHAP authentication if the hostname on a challenging router is tampa with a password of florida?
    • username tampa password florida
    username tampa florida
    hostname tampa password florida
    hostname tampa florida
    24. Which of the following describes the PAP protocol? (Choose two.)
    • sends unencrypted authentication passwords
    performs a three-way handshake
    • allows repeated login attempts
    uses the remote router hostname to verify identity
    sends a random challenge throughout the session
    25. Why was NAT created? (Choose two.)
    to create firewalls on routers
    • to conserve IP addresses
    to translate domain names into IP addresses
    to map network addresses to the corresponding data link address
    • to hide internal addresses from external devices
    26. An ISDN router is configured for DDR as shown in the graphic to provide Internet connectivity for the company. Immediately after a user in the company attempts opens a web browser to connect to the Internet, another user in the company tries to download a file using FTP. What will happen? (Choose two.)
    • The user that opened the browser will connect to the Internet because the DDR link will consider this traffic interesting.
    The Internet user will be disconnected because the FTP data will cause the DDR link to shut down.
    The DDR link will allow the FTP traffic because it is interesting.
    The DDR link will not allow the FTP traffic because it is not interesting.
    The FTP connection will fail because the DDR link is already in use for the Internet connection.
    • The FTP connection will succeed because the web user already opened the DDR link.
    27. Which command configures the SPID on the first B channel of an ISDN interface?
    Router(config)# isdn spid0 spid-number [ldn]
    Router(config)# isdn spid1 spid-number [ldn]
    Router(config-if)# isdn spid0 spid-number [ldn]
    • Router(config-if)# isdn spid1 spid-number [ldn]
    28. What does the command debug isdn q921 display?
    exchange of call setup and teardown messages
    PAP and CHAP authentication traffic
    • Layer 2 messages on the D channel
    protocol errors and statistics
    Layer 2 messages on the B channel
    29. When PPP authentication is enabled, which of the following may be checked before establishing a PPP link between two devices? (Choose two.)
    the enable password on the remote device
    the ip host configuration on the remote device
    • the security server database for the username and password of the remote device
    the hostname and enable password on the local device
    • the local database for the username and password of the remote device
    30. How many separate B channel circuits can be provisioned on a PRI interface that uses a T1 line for connectivity?
    2
    16
    • 23
    24
    30
    128
    31. Which operating systems support multiuser capability? (Choose three.)
    • Linux
    Windows 98
    Windows ME
    • Windows XP
    • Windows 2000
    32. What is placed in the address field of a frame that will travel from the DC office of ABC company to the Orlando office?
    MAC address of the Orlando router
    MAC address of the DC router
    192.168.1.25
    192.168.1.26
    DLCI 100
    • DLCI 200
    33. What does a DLCI of 0 indicate about a frame? (Choose two.)
    This is the first data frame sent by the router.
    • This is a management frame.
    The encapsulation type is Cisco.
    The encapsulation type is IETF.
    • The LMI type is Ansi or q933a.
    The LMI type is Cisco.
    34. Which of the following protocols can be used to encapsulate data traffic sent from a router BRI interface? (Choose two.)
    Link Access Protocol - Data
    • High-Level Data Link Control
    Logical Link Control
    ****** Data Link Control
    • Point to Point protocol
    Binary Synchronous Control protocol
    35. An administrator consoled into the Jelly router needs to telnet to the Butter router. What DLCI will the Jelly router place in the frame to perform this operation?
    110
    115
    220
    • 225
    36. Which commands can be used to identify which DLCIs are active? (Choose two.)
    • show frame-relay map
    show frame-relay lmi
    • show frame-relay pvc
    show frame-relay interface
    show interfaces
    show ip route
    37. A technician is testing the functionality of a recently installed router. The technician is unable to ping the ****** interface of a remote router. The technician executes the show interface serial0/0 command on the local router and sees the following line in the output:
    Serial0/0 is up, line protocol is down
    What are possible causes for this command output? (Choose three.)
    • remote CSU/DSU failure
    ****** cable missing
    interface shutdown
    • keepalives not being sent
    • clocking signal missing
    38. A router needs to forward a message received from a host. How does the router identify the correct VC to forward the message? (Choose two.)
    The router forwards the frame to all ports in the network and learns the address from the reply frame.
    The destination host IP address is embedded in the DLCI.
    • The router searches Inverse ARP tables for maps of DLCIs to IP addresses.
    • A table of static mappings can be searched.
    The router broadcasts a request for the required IP address.
    39. Which of the following statements regarding point-to-point subinterfaces are true? (Choose two.)
    A point-to-point subinterface on one router must be connected to a similar subinterface on a remote router.
    Each point-to-point subinterface connection is configured with its own subnet.
    The DLCIs configured on the remote and local routers must be the same for the PVC.
    LMI frames are not transmitted through a subinterface.
    Routing updates in point-to-point networks are not subject to the split-horizon rule.
    40. Which of the following can be concluded from the router output displayed in the graphic? (Choose two.)
    • The local DLCI number of this PVC is 100.
    The interface has been configured for subinterfaces and this map is for subinterface 0.
    • Inverse ARP has determined the remote ip address as 10.140.1.1.
    The LMI type is ANSI (0x64).
    There is currently no congestion on the link.
    41. Which of the following are functions of the Local Management Interface used in Frame Relay networks? (Choose three.)
    • exchange information about the status of virtual circuits
    map DLCIs to network addresses
    • provide flow control
    provide error notification
    provide congestion notification
    • send keepalive packets to verify operation of the PVC
    42. Which of the following describe functions of the Point-to-Point protocol with regards to the OSI model? (Choose three.)
    PPP uses Layer 3 of the OSI model to establish and maintain a session between devices.
    PPP operates at all layers of the OSI model.
    • PPP uses the data link layer to configure such options as error detection and compression.
    • PPP provides a mechanism to multiplex several network layer protocols.
    PPP uses Network Control Protocols (NCP) to test and maintain connectivity between devices.
    • PPP can be configured on both synchronous and asynchronous ****** interfaces.
    43. Which of the following describes the CHAP protocol? (Choose three.)
    • exchanges a random challenge number during the session to verfiy identity
    sends authentication password to verify identity
    • prevents transmission of login information in plain text
    • disconnects the PPP session if authentication fails
    initiates a two-way handshake
    44. Which of the following switching types will allow the communication devices in the provider's network to be shared and only allocated to an individual subscriber during data transfer?
    circuit-switched
    • packet-switched
    frame-switched
    dedicated-switched lines
    lease-switched
    45. How does Frame Relay technology process frames that contain errors? (Choose two.)
    • Frame Relay services depend on the upper layer protocols to handle error recovery.
    It requires the receiving device to request that the sender retransmit erroneous frames.
    FECN, BECN, and DE bits are set in the frames to minimize errors.
    • The receiving device drops any frames that contain errors without notifying the sender.
    The frame relay switch notifies the sender that errors were detected.
    46. Which of the following describes the WAN devices and cabling shown in the graphic? (Choose two.)
    A null-modem cable is used between RouterD and DeviceC for connectivity.
    A DB-25 or DB-9 ****** cable is connected to interface S0/0 of RouterA.
    • DeviceB and DeviceC are DCE devices.
    • The same encoding scheme must be used by DeviceB and DeviceC.
    A synchronous ****** connection exists between DeviceB and DeviceC.
    Hi ban,
    Đây có phải là những câu hỏi đã ra thi không vậy?
    Mình đang ôn thi CCNA nên rất quan tâm. Bạn nào có tài liệu hay gì liên quan tới bài thi CCNA thì cho mình xin với nhé
    Thanks a lot
    mrtrild@gmail.com
    Đời là phù du...!!!:105:
