Em đả thu Ctrl-C, Ctrl-D vẫn kô chạy.
Em đang dùng 12.2 (15)T17
Khi em ở router lên thi ra như sau:
500 processor with 14336 Kbytes of main memory
%SYS-4-CONFIG_NEWER: Configurations from version 12.1 may not be correctly under
stood.
F3: 15535804+889700+1236752 at 0x3000060
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) 2500 Software (C2500-IS-L), Version 12.2(15)T17, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Sat 13-Aug-05 15:26 by kehsiao
Image text-base: 0x0308038C, data-base: 0x00001000
cisco 2511 (68030) processor (revision M) with 14336K/2048K bytes of memory.
Processor board ID 14878400, with hardware revision 00000000
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
16 terminal line(s)
32K bytes of non-volatile configuration memory.
