Catalyst 3560 Only Features [12.2(25)SEE2]
Access Switch Device Manager (SDM) Template
IEEE 802.3af Power over Ethernet
IGMP Throttling
IPv6 (Internet Protocol Version 6)
MLD Snooping
Private VLANs
QoS Policy Propagation via Border Gateway Protocol (QPPB)
VLAN-Based QoS on Physical Ports
SRR (Shaped Round Robin)
Weighted Tail Drop (WTD)
Auto-MDIX
3560 Only Commands [12.2(25)SEE2]
clear dot1x
clear eap
clear ipc
clear mac address-table move update
exception crashinfo
ipv6 access-list
ipv6 mld snooping
ipv6 mld snooping last-listener-query-count
ipv6 mld snooping last-listener-query-interval
ipv6 mld snooping listener-message-suppression
ipv6 mld snooping robustness-variable
ipv6 mld snooping tcn
ipv6 mld snooping vlan
ipv6 traffic-filter
ip vrf (global configuration) - Not Documented
ip vrf (interface configuration) - Not Documented
mdix auto
mls qos queue-set output buffers
mls qos queue-set output threshold
mls qos rewrite ip dscp
mls qos srr-queue input bandwidth
mls qos srr-queue input buffers
mls qos srr-queue input cos-map
mls qos srr-queue input dscp-map
mls qos srr-queue input priority-queue
mls qos srr-queue input threshold
mls qos srr-queue output cos-map
mls qos srr-queue output dscp-map
mls qos vlan-based
power inline consumption
renew ip dhcp snooping database
queue-set
radius-server dead-criteria
show cable-diagnostics tdr
show controllers power inline
show eap
show ipc
show ipv6 access-list
show ipv6 mld snooping
show ipv6 mld snooping address
show ipv6 mld snooping mrouter
show ipv6 mld snooping querier
show link state group
show mac address-table move update
show mls qos input-queue
show mls qos queue-set
show mls qos vlan
srr-queue bandwidth limit
srr-queue bandwidth shape
srr-queue bandwidth share
switchport mode private-vlan
switchport private-vlan
system env temperature threshold yellow
test cable-diagnostics tdr
3550 Only Commands [12.2(25)SEE2]
access-list hardware program nonblocking
boot buffersize
ip dhcp snooping information option format snmp-ifindex
ip igmp snooping source-only-learning age-timer
mls qos cos policy-map
mls qos min-reserve
show fm
show fm interface
show fm vlan
show forward
show tcam
show tcam pbr
show tcam qos
switchcore
wrr-queue bandwidth
wrr-queue cos-map
wrr-queue dscp-map
wrr-queue min-reserve
wrr-queue queue-limit
wrr-queue random-detect max-threshold
wrr-queue threshold
Additional Notes
3560 - IPv6 routing is not documented in the 3560 command reference
3560 - IPv6 QoS not supported as of 12.2(25)SEE2
3560 - The SDM needs to be changed to support IPv6 routing. This will require a reload to take affect. More...
3560 - Support for bits per second when using Storm Control
3560 - Ports are set by default to dynamic auto as opposed to dynamic desireable. This means that two 3560's will not automatically trunk but a 3560 will trunk if connected to a 3550. More...
3560 - The SMI image is now called IP Base and the EMI image is now called IP Services
3550 - IPv6 can be bridged using fallback bridging
IGMP Throttling
MLD Snooping
Private VLANs
Auto-MDIX
clear dot1x
clear eap
clear ipc
exception crashinfo
ipv6 access-list
ipv6 mld snooping
ipv6 traffic-filter
mdix auto
mls qos vlan-based
queue-set
show eap
show ipc
show mls qos vlan
boot buffersize
mls qos min-reserve
show fm
show fm interface
show fm vlan
show forward
show tcam
show tcam pbr
show tcam qos
switchcore
wrr-queue bandwidth
wrr-queue cos-map
wrr-queue dscp-map
wrr-queue threshold
Additional Notes
