I am looking to purchase a couple of WS-C2960S-48LPS-L or WS-C2960S-24TS-L
  • I am looking to purchase a couple of WS-C2960S-48LPS-L or WS-C2960S-24TS-L
    Hi, I am looking to purchase a couple of WS-C2960S-48LPS-L or WS-C2960S-24TS-L and stack them using WS-C2960S-STACK do they come with stacking cables? or will they have to be purchased separately?
    I am used to 3750's that come with the stacking cables.
    Thankyou
    Hi, The below mentioned are the part-code of the stack cables. By default when you purchase a switch you will get 0.5M stack cable.
    If you want a longer stack cable, then you should order for it by using the part id mentioned below.
    The maximum length would be 3 metres.
    Cisco Catalyst 2960-S FlexStack stacking cables:
    1. CAB-STK-E-0.5M FlexStack stacking cable with a 0.5 m length
    2. CAB-STK-E-1M FlexStack stacking cable with a 1.0 m length
    3. CAB-STK-E-3M FlexStack stacking cable with a 3.0 m length
    Hope this helps
      thanks for your reply!
