Bác nào có tài liệu về cấu hình kết nối dialup cho con Cisco 2811 qua card HWIC 8A giúp em với.Em xin cảm ơn ạ!
Current configuration : 1251 bytes
version 12.2
service timestamps log uptime
hostname cisco3640
boot system flash:c3640-i-mz.122-8.T
enable secret 5 <deleted>
username abc password 0 abc
! -- Usernames for local authentication of the call.
! -- The client presents the username/password and the NAS
! -- authenticates the peer. To use AAA with RADIUS or TACACS+, refer to
! -- Implementing the Server-Based AAA Subsystem.
ip subnet-zero
no ip domain-lookup
ip domain-name cisco.com
async-bootp dns-server 5.5.5.1 5.5.5.2
! -- Specifies (for async clients) the IP address of domain name server.
interface Loopback0
ip address 1.1.1.1 255.255.255.0
interface Ethernet2/0
ip address 20.20.20.1 255.255.255.0
half-duplex
! <<--Unused interface configuration omitted.
interface Group-Async1
! -- This group-async interface is the configuration template for all modems.
! -- Individual async interface do not have to be configured since they
! -- can be cloned from one managed copy.
ip unnumbered Loopback0
encapsulation ppp
dialer in-band
dialer idle-timeout 600
! -- Sets Idle timer to 600 seconds (10 minutes).
dialer-group 1
!--- Apply interesting traffic definition from dialer-list 1.
! -- Note: The specified dialer-group number must be the same as
! -- the dialer-list number; in this example, defined to be "1".
! -- Interesting traffic specifies the packets that should reset the idle timer.
async mode interactive
! -- If the async interface is to answer different connection types
! -- (exec,ppp,slip), use this command in conjunction with autoselect ppp
! -- under the line configuration to auto detect the connection type.
! -- To prevent users from establishing an "EXEC session" to the router.
! -- use the command async modem dedicated instead.
peer default ip address pool DIALIN
! -- Clients are assigned addresses from the ip address pool named "DIALIN".
ppp authentication chap
group-range 1 8
! -- Modems/lines 1 to 8 are members of this group async interface.
! -- If you want, for example, only 4 modems for incoming and the rest
! -- for outgoing then configure the group range for any set of
! -- four consecutive modems in the module.
! -- Note: this range must be included within the line configuration below.
ip local pool DIALIN 10.1.1.1 10.1.1.10
! -- IP address pool for dialin clients.
ip classless
ip route 0.0.0.0 0.0.0.0 20.20.20.100
ip http server
ip pim bidir-enable
! -- Specifies all IP traffic as interesting. Interesting traffic
! -- specifies the packets that should reset the idle timer.
! -- This is applied to interface Group-Async 1 using dialer-group 1.
! -- Note: The specified dialer-list number must be the same as the
! -- dialer-group number; in this example, defined to be "1".
password abc
line 1 8
! -- TTY lines for the NM-8AM Modems.
! -- Note the line number range matched the group-range
! -- under the group-async config.
modem InOut
! -- Support incoming and outgoing modem calls.
transport input all
autoselect ppp
! -- Launch PPP if PPP packets are detected. This is used in conjunction
! -- with async mode interactive under the group-async configuration.
flowcontrol hardware
line aux 0
login
source:
