Bảo mật Router-Switch (P12)
  • Bảo mật Router-Switch (P12)
    15. Những file cấu hình ví dụ
    15.1 Cisco Catalyst 6500 Swtich
    ! 6500 - Distribution/Core Policy Layer
    version 12.1
    no service pad
    service tcp-keepalives-in
    service tcp-keepalives-out
    service timestamps debug datetime msec localtime show-timezone
    service timestamps log datetime msec localtime show-timezone
    service password-encryption
    service sequence-numbers
    hostname Cat121
    boot system flash sup-bootflash:c6k222-jk9sv-mz.122-14.SY.bin
    logging snmp-authfail
    logging buffered 64000 notifications
    aaa new-model
    aaa group server tacacs+ aaa-admin-servers
    server 10.1.6.88
    aaa authentication banner ^CAccessing AAA-Servers^C
    aaa authentication fail-message ^CAAA Authentication FAILED.^C
    aaa authentication login default group aaa-admin-servers
    aaa authentication login aaa-fallback group aaa-admin-servers enable
    aaa authorization exec default group aaa-admin-servers
    aaa authorization commands 15 default group aaa-admin-servers
    aaa authorization commands 15 aaa-config group aaa-admin-servers if-authenticated
    aaa authorization network default if-authenticated
    aaa authorization configuration default group aaa-admin-servers
    aaa accounting suppress null-username
    aaa accounting send stop-record authentication failure
    aaa accounting delay-start
    aaa accounting nested
    aaa accounting update periodic 1440
    aaa accounting exec default start-stop group aaa-admin-servers
    aaa accounting commands 15 default start-stop group aaa-admin-servers
    aaa accounting network default start-stop group aaa-admin-servers
    aaa accounting connection default start-stop group aaa-admin-servers
    aaa accounting system default start-stop group aaa-admin-servers
    enable secret <password>
    clock timezone EST -5
    clock summer-time EDT recurring
    clock calendar-valid
    vtp domain test.lab
    vtp mode transparent
    ip subnet-zero
    no ip source-route
    no ip gratuitous-arps
    ip icmp rate-limit unreachable 1000
    ip flow-cache feature-accelerate
    ip tcp synwait-time 10
    ip domain-name test.lab
    ip name-server 10.1.200.97
    ip dhcp relay information option
    no ip bootp server
    ip ssh time-out 10
    ip ssh authentication-retries 2
    mls flow ip destination
    mls flow ipx destination
    mls qos
    spanning-tree loopguard default
    spanning-tree portfast default
    spanning-tree portfast bpduguard default
    spanning-tree portfast bpdufilter default
    no spanning-tree vlan 1-5,7-9,11-19,21-100,102-1001
    spanning-tree vlan 6,10,20,101 priority 24576
    spanning-tree vlan 6,10,20,101 forward-time 7
    spanning-tree vlan 6,10,20,101 max-age 10
    redundancy
    mode rpr-plus
    main-cpu
    auto-sync running-config
    auto-sync standard
    mac access-list extended mac-any-any
    permit any any
    vlan access-map ipphone-vacl-map 10
    match ip address ipphone-permits
    action forward
    vlan access-map ipphone-vacl-map 20
    match ip address ipphone-no-log
    action drop
    vlan access-map ipphone-vacl-map 30
    match ip address ip-any-any
    action drop log
    vlan access-map ipphone-vacl-map 40
    match mac address mac-any-any
    action drop
    vlan access-map ipphone-vacl-map 50
    match ipx address ipx-any-any
    action drop
    vlan access-map server-vacl-map 10
    match ip address intraserver-permits
    action forward
    vlan access-map server-vacl-map 20
    match ip address intraserver-any-any
    action drop log
    vlan access-map server-vacl-map 30
    match ip address server-permits-in
    action forward
    vlan access-map server-vacl-map 40
    match ip address server-permits-out
    action forward
    vlan access-map server-vacl-map 50
    action drop log
    vlan access-map server-vacl-map 60
    action drop
    vlan access-map server-vacl-map 70
    action drop
    vlan access-map management-vacl-map 10
    match ip address management-permits
    action forward
    vlan access-map management-vacl-map 20
    action drop log
    vlan access-map management-vacl-map 30
    action drop
    vlan access-map management-vacl-map 40
    action drop
    vlan filter management-vacl-map vlan-list 6
    vlan filter ipphone-vacl-map vlan-list 101
    vlan filter server-vacl-map vlan-list 200
    vlan 6
    name MANAGEMENT-SUBNET
    vlan 10
    name NET10-SUBNET
    vlan 20
    name NET20-SUBNET
    vlan 101
    name IP-PHONE-SUBNET
    vlan 200
    name SERVERS-PRIVATE-PRIMARY
    private-vlan primary
    private-vlan association 201
    vlan 201
    name SERVERS-PRIVATE-SECONDARY
    private-vlan isolated
    vlan 996
    name CORE-LAYER-SUBNET
    vlan 997
    name ***BIT-BUCKET-for-2nd-Trunk***
    vlan 998
    name ***BIT-BUCKET-for-1st-Trunk***
    vlan 999
    name ***BIT-BUCKET-for-unused-ports**
    interface Loopback0
    ip address 10.0.0.121 255.255.255.255
    no ip redirects
    no ip unreachables
    no ip proxy-arp
    no ip route-cache
    no ip mroute-cache
    interface Null0
    no ip unreachables
    interface GigabitEthernet1/1
    description TRUNK to Cat122
    mls qos trust dscp
    switchport
    switchport access vlan 999
    switchport trunk encapsulation dot1q
    switchport trunk native vlan 996
    switchport trunk allowed vlan 6,10,20,101,200,201,996
    switchport mode trunk
    switchport nonegotiate
    no cdp enable
    spanning-tree bpdufilter disable
    spanning-tree bpduguard disable
    spanning-tree guard none
    interface GigabitEthernet1/2
    description *** UNUSED Port ***
    shutdown
    switchport
    switchport trunk native vlan 999
    switchport trunk allowed vlan none
    switchport mode access
    switchport port-security
    storm-control broadcast level 0.00
    storm-control multicast level 0.00
    storm-control unicast level 0.00
    dot1x port-control force-unauthorized
    no cdp enable
    spanning-tree bpdufilter enable
    spanning-tree bpduguard enable
    spanning-tree guard root
    interface GigabitEthernet6/1
    description SERVER CallManager
    mls qos trust dscp
    switchport
    switchport mode private-vlan host
    switchport private-vlan host-association 200 201
    no cdp enable
    interface GigabitEthernet6/2
    description SERVER Internal E-Mail (SMTP)
    switchport
    no cdp enable
    interface GigabitEthernet6/3
    description SERVER Internal Domain Name (DNS)
    switchport
    no cdp enable
    interface GigabitEthernet6/4
    description SERVER Internal File (FTP)
    switchport
    no cdp enable
    interface GigabitEthernet6/5
    description SERVER Internal Web (HTTP)
    switchport
    no cdp enable
    interface GigabitEthernet6/6
    description SERVER Network Time Source-Primary (NTP)
    switchport
    switchport mode private-vlan promiscuous
    switchport private-vlan mapping 200 201
    no cdp enable
    interface GigabitEthernet6/7
    shutdown
    switchport
    no cdp enable
    interface GigabitEthernet6/8
    shutdown
    switchport
    no cdp enable
    interface GigabitEthernet6/9
    description SERVER Management Logs (SysLog)
    switchport
    switchport access vlan 6
    no cdp enable
    interface GigabitEthernet6/10
    description SERVER Management Authentication (RADIUS)
    switchport
    switchport port-security maximum 5
    no cdp enable
    interface GigabitEthernet6/11
    description HOST Management (SNMPv3)
    switchport
    no cdp enable
    interface GigabitEthernet6/12
    description HOST Management (SSL, SSH, etc.)
    switchport
    no cdp enable
    interface GigabitEthernet6/13
    shutdown
    switchport
    no cdp enable
    interface GigabitEthernet6/14
    shutdown
    switchport
    no cdp enable
    interface GigabitEthernet6/15
    description TRUNK to Cat142
    mls qos trust dscp
    switchport
    switchport trunk native vlan 997
    no cdp enable
    interface GigabitEthernet6/16
    description TRUNK to Cat141
    mls qos trust dscp
    switchport
    switchport trunk native vlan 998
    no cdp enable
    interface Vlan1
    description *** DEFAULT VLAN - Do NOT Use! ***
    no ip redirects
    no ip unreachables
    no ip proxy-arp
    no ip route-cache
    no ip mroute-cache
    shutdown
    ntp disable
    interface Vlan6
    description Layer 3 Interface to Management Subnet
    ip address 10.1.6.121 255.255.255.0
    no ip redirects
    no ip unreachables
    no ip proxy-arp
    no ip route-cache
    no ip mroute-cache
    interface Vlan10
    description Layer 3 Interface to Net10 Subnet
    ip address 10.1.10.121 255.255.255.0
    no ip redirects
    no ip unreachables
    no ip proxy-arp
    no ip route-cache
    no ip mroute-cache
    ntp disable
    interface Vlan20
    description Layer 3 Interface to Net20 Subnet
    ip address 10.1.20.121 255.255.255.0
    no ip redirects
    no ip unreachables
    no ip proxy-arp
    no ip route-cache
    no ip mroute-cache
    ntp disable
    interface Vlan101
    description Layer 3 Interface to IP Phone Subnet
    ip address 10.1.101.121 255.255.255.0
    ip helper-address 10.1.200.99
    no ip redirects
    no ip unreachables
    no ip proxy-arp
    no ip route-cache
    no ip mroute-cache
    ntp disable
    interface Vlan200
    description Layer 3 Interface to Internal Servers
    ip address 10.1.200.121 255.255.255.0
    no ip redirects
    no ip unreachables
    no ip proxy-arp
    no ip route-cache
    no ip mroute-cache
    private-vlan mapping 201
    interface Vlan996
    description Layer 3 Interface to Core Subnet
    ip address 10.1.250.121 255.255.255.252
    no ip redirects
    no ip unreachables
    no ip proxy-arp
    no ip route-cache
    no ip mroute-cache
    ntp disable
    interface Vlan997
    description *** BIT BUCKET for 2nd Trunk ***
    no ip redirects
    no ip unreachables
    no ip proxy-arp
    no ip route-cache
    no ip mroute-cache
    shutdown
    ntp disable
    interface Vlan998
    description *** BIT BUCKET for 1st Trunk ***
    no ip redirects
    no ip unreachables
    no ip proxy-arp
    no ip route-cache
    no ip mroute-cache
    shutdown
    ntp disable
    interface Vlan999
    description *** BIT BUCKET for unused ports ***
    no ip redirects
    no ip unreachables
    no ip proxy-arp
    no ip route-cache
    no ip mroute-cache
    shutdown
    ntp disable
    ip classless
    ip route 0.0.0.0 0.0.0.0 10.1.250.122
    ip route 0.0.0.0 0.0.0.0 Vlan996
    no ip http server
    ip http access-class 1
    ip http authentication aaa
    no ip http secure-server
    ip access-list extended intraserver-any-any
    remark Everything with Source AND Destination in VLAN200
    permit ip 10.1.200.0 0.0.0.255 10.1.200.0 0.0.0.255
    remark .
    ip access-list extended intraserver-permits
    remark Allow NTP to the VLAN200 Servers
    permit udp host 10.1.200.94 eq ntp 10.1.200.0 0.0.0.255 eq ntp
    remark Allow NTP from the VLAN200 Servers
    permit udp 10.1.200.0 0.0.0.255 eq ntp host 10.1.200.94 eq ntp
    remark .
    ip access-list extended ip-any-any
    remark Everything IP
    permit ip any any
    remark .
    ip access-list extended ipphone-no-log
    remark Known IPPhone packets to drop without logging
    permit tcp 10.1.101.0 0.0.0.255 10.1.101.0 0.0.0.255 eq 2000
    remark .
    ip access-list extended ipphone-permits
    remark -Allow DHCP BOOTP from IPPhones
    permit udp host 0.0.0.0 eq bootpc host 255.255.255.255 eq bootps
    remark -Allow DHCP BOOTP to IPPhone subnets (through ip helper-address)
    permit udp host 10.1.101.121 eq bootps host 255.255.255.255 eq bootpc
    permit udp host 10.1.101.122 eq bootps host 255.255.255.255 eq bootpc
    remark -Allow DNS lookup requests from IPPhones to CCM
    permit udp 10.1.101.0 0.0.0.255 gt 32767 host 10.1.200.99 eq domain
    remark -Allow DNS lookup replies from CCM to IPPhones
    permit udp host 10.1.200.99 eq domain 10.1.101.0 0.0.0.255 gt 32767
    remark -Allow TFTP request from IPPhones to CCM
    permit udp 10.1.101.0 0.0.0.255 gt 32767 host 10.1.200.99 eq tftp
    remark -Open (too many) ports for TFTP transfer from CCM to IPPhones
    permit udp host 10.1.200.99 10.1.101.0 0.0.0.255 gt 32767
    remark -Open (too many) ports for TFTP Acks from IPPhones to CCM
    remark -Allow Skinny from IPPhones to CCM
    permit tcp 10.1.101.0 0.0.0.255 gt 32767 host 10.1.200.99 range 2000 2002 dscp af31
    permit tcp 10.1.101.0 0.0.0.255 gt 32767 host 10.1.200.99 range 2000 2002 rst dscp default
    remark -Allow Skinny from CCM to IPPhones
    permit tcp host 10.1.200.99 range 2000 2002 10.1.101.0 0.0.0.255 gt 32767 dscp af31
    permit tcp host 10.1.200.99 range 2000 2002 10.1.101.0 0.0.0.255 gt 32767 rst dscp default
    remark -Allow RTP Voice between IPPhones
    permit udp 10.1.101.0 0.0.0.255 range 16384 32767 10.1.101.0 0.0.0.255 range 16384 32767 dscp ef
    remark -Allow HTTP management of IPPhones from CCM
    permit tcp host 10.1.200.99 10.1.101.0 0.0.0.255 eq www
    remark -Allow HTTP management replies from IPPhones to CCM
    permit tcp 10.1.101.0 0.0.0.255 eq www host 10.1.200.99 established
    remark -Allow ICMPs to IPPhones from CCM
    permit icmp host 10.1.200.99 10.1.101.0 0.0.0.255
    remark -Allow ICMPs from IPPhones to CCM
    permit icmp 10.1.101.0 0.0.0.255 host 10.1.200.99
    remark .
    ip access-list extended management-permits
    remark Allowable MANAGEMENT Subnet Permits
    permit ip 10.1.6.0 0.0.0.255 10.1.6.0 0.0.0.255
    remark .
    ip access-list extended server-permits-in
    remark HTTP Server Permits
    permit tcp 10.1.20.0 0.0.0.255 host 10.1.200.95 eq www
    permit tcp 10.1.20.0 0.0.0.255 host 10.1.200.95 eq 443
    remark FTP Server Permits
    permit tcp 10.1.10.0 0.0.0.255 host 10.1.200.96 eq ftp-data
    remark DNS Server Permits
    permit udp 10.1.10.0 0.0.0.255 host 10.1.200.97 eq domain
    permit udp 10.1.20.0 0.0.0.255 host 10.1.200.97 eq domain
    permit tcp 10.1.10.0 0.0.0.255 host 10.1.200.97 eq domain
    permit tcp 10.1.20.0 0.0.0.255 host 10.1.200.97 eq domain
    remark SMTP Server Permits
    permit tcp 10.1.10.0 0.0.0.255 host 10.1.200.98 eq smtp
    permit tcp 10.1.20.0 0.0.0.255 host 10.1.200.98 eq smtp
    remark -Allow DHCP BOOTP from IPPhone subnets (through ip helper-address)
    permit udp host 10.1.101.121 eq bootpc host 10.1.200.99 eq bootps
    permit udp host 10.1.101.122 eq bootpc host 10.1.200.99 eq bootps
    remark -Allow DNS lookup requests to CCM
    remark .
    ip access-list extended server-permits-out
    permit tcp host 10.1.200.95 eq www 10.1.20.0 0.0.0.255
    permit tcp host 10.1.200.95 eq 443 10.1.20.0 0.0.0.255
    permit tcp host 10.1.200.96 eq ftp-data 10.1.10.0 0.0.0.255
    permit tcp host 10.1.200.96 eq ftp 10.1.10.0 0.0.0.255
    permit udp host 10.1.200.97 eq domain 10.1.10.0 0.0.0.255
    permit udp host 10.1.200.97 eq domain 10.1.20.0 0.0.0.255
    permit tcp host 10.1.200.97 eq domain 10.1.10.0 0.0.0.255
    permit tcp host 10.1.200.97 eq domain 10.1.20.0 0.0.0.255
    permit tcp host 10.1.200.98 eq smtp 10.1.10.0 0.0.0.255
    permit tcp host 10.1.200.98 eq smtp 10.1.20.0 0.0.0.255
    permit udp host 10.1.200.99 eq bootps host 10.1.101.121 eq bootps
    permit udp host 10.1.200.99 eq bootps host 10.1.101.122 eq bootps
    remark -Allow DNS lookup replies to IPPhone subnets
    remark -Allow ICMPs from CCM to IPPhones
    remark .
    logging history notifications
    logging trap informational
    logging facility local0
    logging 10.1.6.89
    no access-list 1
    access-list 1 remark Permit access from ADMINISTRATION addresses
    access-list 1 permit 10.1.6.1 log
    access-list 1 permit 10.1.6.2 log
    access-list 1 deny any log
    no access-list 2
    access-list 2 remark Permit access from Master NTP Server addresses
    access-list 2 permit 10.1.200.94
    access-list 2 deny any log
    no access-list 3
    access-list 3 remark Permit access from Client NTP Server addresses
    access-list 3 permit 10.1.6.141
    access-list 3 deny any log
    no access-list 4
    access-list 4 remark Deny access from any address
    access-list 4 deny any log
    no cdp run
    tacacs-server host 10.1.6.88 key lablablab
    tacacs-server directed-request
    banner exec #
    Connected to $(hostname).$(domain) on $(line-desc) $(line).
    Use of this system constitutes your consent to monitoring.
    banner login #
    Session established with AUTHENTICATION Servers.
    Provide the following tokens for User Access Verification
    banner motd #
    NOTICE TO USERS
    This is an official computer system and is the property of the ORGANIZATION. It is for authorized users only. Unauthorized users are prohibited. Users (authorized or unauthorized) have no explicit or implicit expectation of privacy. Any or all uses of this system may be subject to one or more of the following actions: interception, monitoring, recording, auditing, inspection and disclosing to security personnel and law enforcement personnel, as well as authorized officials of other agencies, both domestic and foreign. By using this system, the user consents to these actions. Unauthorized or improper use of this system may result in administrative disciplinary action and civil and criminal penalties. By accessing this system you indicate your awareness of and consent to these terms and conditions of use. Discontinue access immediately if you do not agree to the conditions stated in this notice.
    Contacting AUTHENTICATION Servers...#
    banner prompt-timeout #
    Session timed-out with AUTHENTICATION Servers. Goodbye!#
    exec-timeout 9 0
    privilege level 0
    password <password>
    logging synchronous
    login authentication aaa-fallback
    length 50
    notify
    transport preferred none
    transport output ssh
    access-class 1 in
    exec-timeout 9 0
    privilege level 0
    password <password>
    transport input ssh
    transport output none
    line vty 5 15
    access-class 4 in
    exec-timeout 0 10
    privilege level 0
    password <password>
    no exec
    transport input none
    scheduler allocate 4000 400
    ntp authentication-key 123 md5 <key>
    ntp authentication-key 124 md5 <key>
    ntp authenticate
    ntp trusted-key 123
    ntp access-group peer 2
    ntp access-group serve-only 3
    ntp master 2
    ntp server 10.1.200.94 key 123 prefer
    15.2 Cisco Catalyst 3550
    ! 3550 - Access Layer
    version 12.1
    no service pad
    hostname Cat141
    aaa new-model
    server 10.1.6.88
    aaa group server radius aaa-host-servers
    server 10.1.6.88 auth-port 1812 acct-port 1813
    aaa authentication dot1x default group aaa-host-servers
    ip subnet-zero
    no ip source-route
    no ip domain-lookup
    ip ssh time-out 10
    ip ssh authentication-retries 3
    vtp domain test.lab
    mls qos
    spanning-tree mode pvst
    no spanning-tree vlan 995
    no spanning-tree vlan 998
    no spanning-tree vlan 999
    mac access-list extended mac-device-list
    permit host 0000.0101.0011 any
    permit host 0000.0101.0012 any
    permit host 0000.0101.0013 any
    permit host 0000.0101.0014 any
    permit host 0000.0010.0003 any
    permit host 0000.0020.0005 any
    vlan 5
    vlan 6
    name ADMINISTRATION-VLAN
    vlan 10
    name NET10-VLAN
    vlan 20
    name NET20-VLAN
    vlan 101
    vlan 995
    name **BIT-BUCKET-trunk-with-Cat122**
    vlan 998
    name **BIT-BUCKET-trunk-with-Cat121**
    vlan 999
    interface Null0
    no ip unreachables
    interface FastEthernet0/1
    description Host 10.1.10.3
    switchport access vlan 10
    switchport trunk native vlan 10
    switchport block multicast
    switchport block unicast
    switchport port-security aging time 10
    switchport port-security aging type inactivity
    ip access-group ip-device-list in
    mls qos cos override
    dot1x port-control auto
    dot1x guest-vlan 999
    dot1x host-mode multi-host
    mac access-group mac-device-list in
    no cdp enable
    interface FastEthernet0/2
    description IP PHONE x1011
    switchport voice vlan 101
    switchport port-security maximum 2
    mls qos trust device cisco-phone
    mls qos trust dscp
    interface FastEthernet0/3
    description IP PHONE x1012
    mls qos trust dscp
    interface FastEthernet0/4
    description IP PHONE x1013
    mls qos trust dscp
    interface FastEthernet0/5
    description IP PHONE x1014 & HOST 10.1.20.5
    switchport access vlan 20
    switchport trunk native vlan 20
    switchport port-security maximum 3
    mls qos trust dscp
    dot1x reauthentication
    interface FastEthernet0/6
    shutdown
    no cdp enable
    interface FastEthernet0/23
    switchport trunk native vlan 995
    mls qos trust dscp
    no cdp enable
    spanning-tree portfast disable
    interface FastEthernet0/24
    description TRUNK to Cat121
    mls qos trust dscp
    interface Vlan1
    no ip redirects
    no ip unreachables
    no ip proxy-arp
    no ip route-cache
    no ip mroute-cache
    shutdown
    ntp disable
    interface Vlan6
    description ADMINISTRATION VLAN
    ip address 10.1.6.141 255.255.255.0
    no ip redirects
    no ip unreachables
    no ip proxy-arp
    no ip route-cache
    no ip mroute-cache
    interface Vlan995
    description **BIT-BUCKET-trunk-with-Cat122**
    no ip redirects
    no ip unreachables
    no ip proxy-arp
    no ip route-cache
    no ip mroute-cache
    shutdown
    ntp disable
    interface Vlan998
    description **BIT-BUCKET-trunk-with-Cat121**
    no ip redirects
    no ip unreachables
    no ip proxy-arp
    no ip route-cache
    no ip mroute-cache
    shutdown
    ntp disable
    interface Vlan999
    description **BIT BUCKET for unused ports**
    no ip redirects
    no ip unreachables
    no ip proxy-arp
    no ip route-cache
    no ip mroute-cache
    shutdown
    ntp disable
    ip default-gateway 10.1.6.121
    ip classless
    no ip http server
    ip access-list extended ip-device-list
    permit ip host 10.1.101.11 any
    permit ip host 10.1.101.12 any
    permit ip host 10.1.101.13 any
    permit ip host 10.1.101.14 any
    permit ip host 10.1.10.3 any
    permit ip host 10.1.20.5 any
    deny tcp any range 0 65535 any range 0 65535 log-input
    deny udp any range 0 65535 any range 0 65535 log-input
    deny ip any any log-input
    logging history warnings
    logging 10.1.6.89
    no access-list 1
    no access-list 2
    access-list 2 remark Permit access from NTP Server addresses
    access-list 2 permit 10.1.6.121
    no access-list 3
    access-list 3 remark Deny access from any address
    tacacs-server host 10.1.6.88 key <key>
    radius-server host 10.1.6.88 auth-port 1812 acct-port 1813
    radius-server key <key>
    banner exec #
    banner login #
    banner motd #
    NOTICE TO USERS
    exec-timeout 9 0
    privilege level 0
    password <password>
    logging synchronous
    length 50
    notify
    access-class 1 in
    exec-timeout 9 0
    privilege level 0
    password <password>
    line vty 5 15
    access-class 3 in
    exec-timeout 0 10
    privilege level 0
    password <password>
    no exec
    scheduler interval 500
    ntp authenticate
    ntp trusted-key 124
    ntp server 10.1.6.121 key 124 prefer
    Phạm Minh Tuấn
    Yahoo : phamminhtuan_vnpro
