Em có 2 con router, muốn cấu hình MPLS nhưng kiểm tra thì không thấy lệnh nào liên quan đến MPLS. Em không biết có phải là vấn đề IOS không, nhờ các huynh kiểm tra giúp và cho ý kiến.
Thanks so much;
R_LNS1#sh version
Cisco IOS Software, 7301 Software (C7301-IS-M), Version 12.3(8)T11, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Wed 10-Aug-05 20:38 by dchih
ROM: System Bootstrap, Version 12.2(8r)B3a, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7301 Software (C7301-BOOT-M), Version 12.3(8)T4, RELEASE SOFTWARE (fc2)
R_LNS1 uptime is 35 weeks, 1 day, 14 hours, 33 minutes
System returned to ROM by power-on
System restarted at 22:34:55 CET-DST Mon Jul 3 2006
System image file is "disk0:c7301-is-mz.123-8.T11.bin"
Cisco 7301 (NPE) processor (revision C) with 983040K/65536K bytes of memory.
Processor board ID 74811033
SB-1 CPU at 700MHz, Implementation 1025, Rev 0.2, 512KB L2 Cache
1 slot midplane, Version 3.0
Last reset from power-on
3 Gigabit Ethernet interfaces
509K bytes of NVRAM.
62976K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
32768K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x2102
lo-bgp4#sh version
Cisco IOS Software, 7200 Software (C7200-IS-M), Version 12.4(5a), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Sat 14-Jan-06 00:25 by alnguyen
ROM: System Bootstrap, Version 12.3(4r)T3, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200-KBOOT-M), Version 12.4(5a), RELEASE SOFTWARE (fc3)
lo-bgp4 uptime is 5 weeks, 1 hour, 4 minutes
System restarted at 10:17:51 UTC Wed Jan 31 2007
System image file is "disk2:c7200-is-mz.124-5a.bin"
Cisco 7204VXR (NPE-G1) processor (revision A) with 983040K/65536K bytes of memory.
Processor board ID 25859009
4 slot VXR midplane, Version 2.5
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 300 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
1 ATM interface
62976K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
Thanks so much;
R_LNS1#sh version
lo-bgp4#sh version
1 ATM interface
