  • cấu hình mẫu router CME dành cho doanh nghiệp nhỏ (voice/DHCP/Fiewall/QoS/radius/SIP)
    cấu hình này lấy router ra làm tổng đài IP, firewall, DHCP, QoS. Các bạn có thể tham khảo và ứng dụng khi cần thiết.
    Begin CME Configuration:
    ENRT-1UC#sh run
    Current configuration : 33776 bytes
    ! Last configuration change at 21:20:45 PST Mon Jul 26 2010 by cisco
    ! NVRAM config last updated at 18:49:53 PST Wed Jul 28 2010
    version 15.0
    parser config cache interface
    no service pad
    service internal
    service compress-config
    service sequence-numbers
    hostname ENRT-1UC
    boot-start-marker
    boot-end-marker
    enable secret 5 $1$U.Dy$FX2gvX
    aaa new-model
    aaa group server radius radius_local
    server 192.168.0.75 auth-port 1812 acct-port 1813
    aaa authentication login default local
    aaa authentication login auth_method_radius_local group radius_local
    aaa authorization exec default local
    aaa accounting update periodic 10
    aaa accounting network acct_method_radius_local
    action-type start-stop
    group radius_local
    aaa session-id common
    clock timezone EST -5
    clock summer-time PST recurring
    crypto pki trustpoint TP-self-signed-588276992
    enrollment selfsigned
    subject-name cn=IOS-Self-Signed-Certificate-588276992
    revocation-check none
    rsakeypair TP-self-signed-588276992
    crypto pki certificate chain TP-self-signed-588276992
    certificate self-signed 02
    3082023E 308201A7 A0030201 02020102 300D0609 2A864886 F70D0101 04050030
    30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
    69666963 6174652D 35383832 37363939 32301E17 0D313030 37323531 39303730
    355A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
    532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3538 38323736
    39393230 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
    A6DA1AA7 6591DB57 2FB94B3C 197022A0 CA29B4F6 78D0EA31 017880F7 44A873BF
    AFDC2C34 FA56C6AA DF17FA8B 107E1154 D599AC64 C57EB04E 9D8EF113 5A9B5020
    F3FB668B E8FE4C15 4A09D719 C8237B7C 9183D8E6 D5C51C3B E384645B 15A385C2
    F4A1898C EB81CB58 912D4E3D 1DE64A55 437F402D BDA078D9 3E53C16F EBBA875B
    FD5075F7 40F6D0FE E80E7DFA 9B3AB953 11DA1C87 3606A939 41AD9032 763EC09A 4B16
    quit
    dot11 syslog
    dot11 ssid cisco-data
    vlan 1
    authentication open
    guest-mode
    dot11 ssid cisco-voice
    vlan 100
    authentication open
    ip source-route
    ip cef
    ip dhcp relay information trust-all
    ip dhcp excluded-address 10.1.1.1 10.1.1.10
    ip dhcp pool phone
    network 10.1.1.0 255.255.255.0
    default-router 10.1.1.1
    option 150 ip 10.1.1.1
    ip name-server 24.200.241.37
    ip name-server 192.168.0.50
    ip inspect log drop-pkt
    ip inspect name SDM_HIGH appfw SDM_HIGH
    ip inspect name SDM_HIGH icmp
    ip inspect name SDM_HIGH dns
    ip inspect name SDM_HIGH esmtp
    ip inspect name SDM_HIGH https
    ip inspect name SDM_HIGH imap reset
    ip inspect name SDM_HIGH pop3 reset
    ip inspect name SDM_HIGH tcp router-traffic
    ip inspect name SDM_HIGH udp router-traffic timeout 300
    no ipv6 cef
    appfw policy-name SDM_HIGH
    application im aol
    service default action reset alarm
    service text-chat action reset alarm
    server deny name login.oscar.aol.com
    server deny name toc.oscar.aol.com
    server deny name oam-d09a.blue.aol.com
    audit-trail on
    application im msn
    server deny name messenger.hotmail.com
    server deny name gateway.messenger.hotmail.com
    server deny name webmessenger.msn.com
    audit-trail on
    application http
    strict-http action reset alarm
    port-misuse im action reset alarm
    port-misuse p2p action reset alarm
    port-misuse tunneling action reset alarm
    application im yahoo
    server deny name scs.msg.yahoo.com
    server deny name scsa.msg.yahoo.com
    server deny name scsb.msg.yahoo.com
    server deny name scsc.msg.yahoo.com
    server deny name scsd.msg.yahoo.com
    server deny name cs16.msg.dcn.yahoo.com
    server deny name cs19.msg.dcn.yahoo.com
    server deny name cs42.msg.dcn.yahoo.com
    server deny name cs53.msg.dcn.yahoo.com
    server deny name cs54.msg.dcn.yahoo.com
    server deny name ads1.vip.scd.yahoo.com
    server deny name radio1.launch.vip.dal.yahoo.com
    server deny name in1.msg.vip.re2.yahoo.com
    server deny name data1.my.vip.sc5.yahoo.com
    server deny name address1.pim.vip.mud.yahoo.com
    server deny name edit.messenger.yahoo.com
    server deny name messenger.yahoo.com
    server deny name http.pager.yahoo.com
    server deny name privacy.yahoo.com
    server deny name csa.yahoo.com
    server deny name csb.yahoo.com
    server deny name csc.yahoo.com
    audit-trail on
    stcapp ccm-group 1
    stcapp
    stcapp feature access-code
    stcapp supplementary-services
    port 0/0/0
    fallback-dn 301
    port 0/0/1
    fallback-dn 302
    port 0/0/2
    fallback-dn 303
    port 0/0/3
    fallback-dn 304
    multilink bundle-name authenticated
    trunk group ALL_FXO
    max-retry 5
    voice-class cause-code 1
    hunt-scheme longest-idle
    voice call send-alert
    voice rtp send-recv
    voice service voip
    dtmf-interworking rtp-nte
    allow-connections h323 to h323
    allow-connections h323 to sip
    allow-connections sip to h323
    allow-connections sip to sip
    supplementary-service h450.12
    no supplementary-service sip moved-temporarily
    no supplementary-service sip refer
    sip
    registrar server expires max 3600 min 3600
    outbound-proxy ipv4:67.205.74.164:5060
    no update-callerid
    voice class codec 1
    codec preference 1 g711ulaw
    codec preference 2 g729r8
    voice class cause-code 1
    no-circuit
    voice register global
    mode cme
    source-address 10.1.1.1 port 5060
    max-dn 10
    max-pool 10
    voice register dn 1
    number 150
    no-reg
    voice register pool 1
    id mac 0003.FF00.4000
    number 1 dn 1
    dtmf-relay rtp-nte
    voice-class codec 1
    username name password pass1
    no vad
    voice source-group CCA_SIP_SOURCE_GROUP
    access-list 2
    translation-profile incoming SIP_Incoming
    voice translation-rule 6
    rule 1 /8776587270/ /101/
    voice translation-rule 7
    rule 1 /5143168496/ /101/
    voice translation-rule 410
    rule 1 /^9\(.*\)/ /\1/
    rule 15 /^...$/ /5143168496/
    voice translation-rule 411
    rule 1 /^9\(.*\)/ /ABCD9\1/
    voice translation-rule 412
    rule 1 /^ABCD\(.*\)/ /\1/
    voice translation-rule 1111
    rule 15 /.*/ /5143168496/
    voice translation-rule 1112
    rule 1 /^9/ //
    voice translation-rule 2002
    rule 1 /^6/ //
    voice translation-rule 2222
    voice translation-profile CALLER_ID_TRANSLATION_PROFILE
    translate calling 1111
    voice translation-profile CallBlocking
    translate called 2222
    voice translation-profile Incoming_Called_7
    translate called 7
    voice translation-profile OUTGOING_TRANSLATION_PROFILE
    translate called 1112
    voice translation-profile PSTN_CallForwarding
    translate redirect-target 410
    translate redirect-called 410
    voice translation-profile PSTN_Outgoing
    voice translation-profile SIP_Incoming
    translate called 411
    voice translation-profile SIP_Passthrough
    translate called 412
    voice translation-profile TollFree877_Called_6
    translate called 6
    voice translation-profile XFER_TO_VM_PROFILE
    translate redirect-called 2002
    voice-card 0
    license udi pid UC520W-8U-4FXO-K9 sn FHK134975CT
    archive
    log config
    logging enable
    logging size 600
    hidekeys
    username admin secret 5 XXXX
    process-max-time 50
    ip tftp source-interface Loopback0
    class-map match-all _class_Voice0
    match ip dscp ef
    class-map match-all _class_Voice1
    match ip dscp cs3
    class-map match-any sdm_p2p_kazaa
    match protocol fasttrack
    match protocol kazaa2
    class-map match-any sdm_p2p_edonkey
    match protocol edonkey
    class-map match-any sdm_p2p_gnutella
    match protocol gnutella
    class-map match-any sdm_p2p_bittorrent
    match protocol bittorrent
    policy-map Voice
    class _class_Voice0
    set cos 6
    class _class_Voice1
    set cos 3
    policy-map sdmappfwp2p_SDM_HIGH
    class sdm_p2p_gnutella
    drop
    class sdm_p2p_bittorrent
    drop
    class sdm_p2p_edonkey
    drop
    class sdm_p2p_kazaa
    drop
    bridge irb
    interface Loopback0
    description $FW_INSIDE$
    ip address 10.1.10.2 255.255.255.252
    ip access-group 101 in
    ip nat inside
    ip virtual-reassembly
    interface FastEthernet0/0
    description $FW_OUTSIDE$
    ip address dhcp client-id FastEthernet0/0
    ip access-group 104 in
    ip nat outside
    ip inspect SDM_HIGH out
    load-interval 30
    duplex auto
    speed auto
    service-policy input sdmappfwp2p_SDM_HIGH
    service-policy output sdmappfwp2p_SDM_HIGH
    interface Integrated-Service-Engine0/0
    description cue is initialized with default IMAP group
    ip unnumbered Loopback0
    ip nat inside
    service-module ip address 10.1.10.1 255.255.255.252
    service-module ip default-gateway 10.1.10.2
    interface FastEthernet0/1/0
    switchport voice vlan 100
    macro description cisco-phone | cisco-phone
    spanning-tree portfast
    interface FastEthernet0/1/1
    interface FastEthernet0/1/2
    interface FastEthernet0/1/3
    interface FastEthernet0/1/4
    interface FastEthernet0/1/5
    interface FastEthernet0/1/6
    interface FastEthernet0/1/7
    switchport trunk native vlan 100
    switchport mode trunk
    macro description cisco-switch | cisco-switch
    interface FastEthernet0/1/8
    interface Dot11Radio0/5/0
    encryption vlan 1 key 1 size 128bit 0 2EB97E5F85647D0EE2E3B324FE transmit-key
    encryption vlan 1 mode wep mandatory
    ssid cisco-data
    ssid cisco-voice
    speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
    station-role root
    service-policy output Voice
    interface Dot11Radio0/5/0.1
    encapsulation dot1Q 1 native
    bridge-group 1
    bridge-group 1 subscriber-loop-control
    bridge-group 1 spanning-disabled
    bridge-group 1 block-unknown-source
    no bridge-group 1 source-learning
    no bridge-group 1 unicast-flooding
    interface Dot11Radio0/5/0.100
    encapsulation dot1Q 100
    bridge-group 100
    bridge-group 100 subscriber-loop-control
    bridge-group 100 spanning-disabled
    bridge-group 100 block-unknown-source
    no bridge-group 100 source-learning
    no bridge-group 100 unicast-flooding
    interface Vlan1
    bridge-group 1
    interface Vlan100
    bridge-group 100
    interface BVI1
    ip address 192.168.0.75 255.255.255.0
    ip access-group 102 in
    ip nat inside
    interface BVI100
    ip access-group 103 in
    ip nat inside
    ip forward-protocol nd
    ip http server
    ip http authentication local
    ip http secure-server
    ip http path flash:/gui
    ip dns server
    ip nat inside source list 1 interface FastEthernet0/0 overload
    ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
    access-list 1 remark SDM_ACL Category=2
    access-list 1 permit 192.168.0.0 0.0.0.255
    access-list 1 permit 10.1.1.0 0.0.0.255
    access-list 1 permit 10.1.10.0 0.0.0.3
    access-list 2 remark CCA_SIP_SOURCE_GROUP_ACL
    access-list 2 remark SDM_ACL Category=1
    access-list 2 permit 192.168.0.75
    access-list 2 permit 67.205.74.164
    access-list 2 permit 192.168.0.0 0.0.0.255
    access-list 2 permit 10.1.1.0 0.0.0.255
    access-list 2 permit 10.1.10.0 0.0.0.3
    access-list 2 deny any
    access-list 100 remark auto generated by SDM firewall configuration
    access-list 100 remark SDM_ACL Category=1
    access-list 100 deny ip 192.168.10.0 0.0.0.255 any
    access-list 100 deny ip host 255.255.255.255 any
    access-list 100 deny ip 127.0.0.0 0.255.255.255 any
    access-list 100 permit ip any any
    access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_7##
    access-list 101 remark SDM_ACL Category=1
    access-list 101 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any
    access-list 101 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
    access-list 101 deny ip 10.1.1.0 0.0.0.255 any
    access-list 101 deny ip 192.168.0.0 0.0.0.255 any
    access-list 101 deny ip host 255.255.255.255 any
    access-list 101 deny ip 127.0.0.0 0.255.255.255 any
    access-list 101 permit ip any any
    access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_5##
    access-list 102 remark SDM_ACL Category=1
    access-list 102 deny ip 10.1.10.0 0.0.0.3 any
    access-list 102 deny ip 10.1.1.0 0.0.0.255 any
    access-list 102 deny ip host 255.255.255.255 any
    access-list 102 deny ip 127.0.0.0 0.255.255.255 any
    access-list 102 permit ip any any
    access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_7##
    access-list 103 remark SDM_ACL Category=1
    access-list 103 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
    access-list 103 permit udp 10.1.10.0 0.0.0.3 any eq 2000
    access-list 103 deny ip 10.1.10.0 0.0.0.3 any
    access-list 103 deny ip 192.168.0.0 0.0.0.255 any
    access-list 103 deny ip host 255.255.255.255 any
    access-list 103 deny ip 127.0.0.0 0.255.255.255 any
    access-list 103 permit ip any any
    access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_20##
    access-list 104 remark SDM_ACL Category=1
    access-list 104 deny ip 10.1.10.0 0.0.0.3 any
    access-list 104 deny ip 10.1.1.0 0.0.0.255 any
    access-list 104 deny ip 192.168.0.0 0.0.0.255 any
    access-list 104 permit udp any eq bootps any eq bootpc
    access-list 104 permit udp host 192.168.0.50 eq domain any
    access-list 104 permit udp host 24.200.241.37 eq domain any
    access-list 104 permit icmp any any echo-reply
    access-list 104 permit icmp any any time-exceeded
    access-list 104 permit icmp any any unreachable
    access-list 104 permit udp host 192.168.0.75 eq 5060 any
    access-list 104 permit udp host 192.168.0.75 any eq 5060
    access-list 104 permit udp host 67.205.74.164 eq 5060 any
    access-list 104 permit udp host 67.205.74.164 any eq 5060
    access-list 104 permit udp any any range 16384 32767
    access-list 104 deny ip 10.0.0.0 0.255.255.255 any
    access-list 104 deny ip 172.16.0.0 0.15.255.255 any
    access-list 104 deny ip 192.168.0.0 0.0.255.255 any
    access-list 104 deny ip 127.0.0.0 0.255.255.255 any
    access-list 104 deny ip host 255.255.255.255 any
    access-list 104 deny ip any any log
    access-list 104 permit tcp any any established
    snmp-server community public RO
    tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
    tftp-server flash:/phones/5x5/spa5x5-7-4-3.bin alias spa5x5-7-4-3.bin
    tftp-server flash:/phones/7942_7962/apps42.8-5-3TH1-6.sbn alias apps42.8-5-3TH1-6.sbn
    tftp-server flash:/phones/7942_7962/cnu42.8-5-3TH1-6.sbn alias cnu42.8-5-3TH1-6.sbn
    tftp-server flash:/phones/7942_7962/cvm42sccp.8-5-3TH1-6.sbn alias cvm42sccp.8-5-3TH1-6.sbn
    tftp-server flash:/phones/7942_7962/dsp42.8-5-3TH1-6.sbn alias dsp42.8-5-3TH1-6.sbn
    tftp-server flash:/phones/7942_7962/jar42sccp.8-5-3TH1-6.sbn alias jar42sccp.8-5-3TH1-6.sbn
    tftp-server flash:/phones/7942_7962/SCCP42.8-5-3S.loads alias SCCP42.8-5-3S.loads
    tftp-server flash:/phones/7942_7962/term42.default.loads alias term42.default.loads
    tftp-server flash:/phones/7942_7962/term62.default.loads alias term62.default.loads
    tftp-server flash:/phones/7970_7971/apps70.8-5-3TH1-6.sbn alias apps70.8-5-3TH1-6.sbn
    tftp-server flash:/phones/7970_7971/cnu70.8-5-3TH1-6.sbn alias cnu70.8-5-3TH1-6.sbn
    tftp-server flash:/phones/7970_7971/cvm70sccp.8-5-3TH1-6.sbn alias cvm70sccp.8-5-3TH1-6.sbn
    tftp-server flash:/phones/7970_7971/dsp70.8-5-3TH1-6.sbn alias dsp70.8-5-3TH1-6.sbn
    tftp-server flash:/phones/7970_7971/jar70sccp.8-5-3TH1-6.sbn alias jar70sccp.8-5-3TH1-6.sbn
    tftp-server flash:/phones/7970_7971/SCCP70.8-5-3S.loads alias SCCP70.8-5-3S.loads
    tftp-server flash:/phones/7970_7971/term70.default.loads alias term70.default.loads
    tftp-server flash:/phones/7970_7971/term71.default.loads alias term71.default.loads
    tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
    tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
    tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
    tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
    tftp-server flash:/ringtones/RingList.xml alias RingList.xml
    tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
    tftp-server flash:/ringtones/Bass.raw alias Bass.raw
    tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
    tftp-server flash:/ringtones/Chime.raw alias Chime.raw
    tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
    tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
    tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
    tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
    tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
    tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
    tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
    tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
    tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
    tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
    tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
    tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
    tftp-server flash:/ringtones/Pop.raw alias Pop.raw
    tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
    tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
    tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
    tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
    tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
    tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
    tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
    tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
    tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
    tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
    tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
    tftp-server flash:/Desktops/CampusNight.png
    tftp-server flash:/Desktops/TN-CampusNight.png
    tftp-server flash:/Desktops/CiscoFountain.png
    tftp-server flash:/Desktops/TN-CiscoFountain.png
    tftp-server flash:/Desktops/CiscoLogo.png
    tftp-server flash:/Desktops/TN-CiscoLogo.png
    tftp-server flash:/Desktops/Fountain.png
    tftp-server flash:/Desktops/TN-Fountain.png
    tftp-server flash:/Desktops/MorroRock.png
    tftp-server flash:/Desktops/TN-MorroRock.png
    tftp-server flash:/Desktops/NantucketFlowers.png
    tftp-server flash:/Desktops/TN-NantucketFlowers.png
    tftp-server flash:Desktops/320x212x16/List.xml
    tftp-server flash:Desktops/320x212x12/List.xml
    tftp-server flash:Desktops/320x216x16/List.xml
    tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
    tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
    tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
    tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
    tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
    tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
    tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
    tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
    tftp-server flash:/its/united_states_7960-tones.xml alias United_States/g3-tones.xml
    tftp-server flash:/7921-dictionary.xml alias English_United_States/7921-dictionary.xml
    tftp-server flash:/7921-font.dat alias English_United_States/7921-font.dat
    tftp-server flash:/7921-kate.utf-8.xml alias English_United_States/7921-kate.utf-8.xml
    tftp-server flash:/7921-kate.xml alias English_United_States/7921-kate.xml
    tftp-server flash:/be-sccp.jar alias English_United_States/be-sccp.jar
    tftp-server flash:/gp-sccp.jar alias English_United_States/gp-sccp.jar
    tftp-server flash:/ipc-sccp.jar alias English_United_States/ipc-sccp.jar
    tftp-server flash:/mk-sccp.jar alias English_United_States/mk-sccp.jar
    tftp-server flash:/tc-sccp.jar alias English_United_States/tc-sccp.jar
    tftp-server flash:/td-sccp.jar alias English_United_States/td-sccp.jar
    radius-server local
    nas 192.168.0.75 key 0 XXXXXXXX
    user dave.laramee nthash 0 XXXX
    radius-server attribute 32 include-in-access-req format %h
    radius-server host 192.168.0.75 auth-port 1812 acct-port 1813 key enrt4628
    control-plane
    bridge 1 route ip
    bridge 100 route ip
    call threshold interface FastEthernet0/0 int-calls low 10 high 10
    voice-port 0/0/0
    timeouts ringing infinity
    voice-port 0/0/1
    voice-port 0/0/2
    voice-port 0/0/3
    voice-port 0/1/0
    trunk-group ALL_FXO 64
    connection plar 201
    caller-id enable
    voice-port 0/1/1
    connection plar 202
    caller-id enable
    voice-port 0/1/2
    connection plar 203
    caller-id enable
    voice-port 0/1/3
    connection plar 204
    caller-id enable
    voice-port 0/4/0
    auto-cut-through
    signal immediate
    input gain auto-control -15
    description Music On Hold Port
    sccp local Loopback0
    sccp ccm 10.1.1.1 identifier 1 version 3.1
    sccp
    sccp ccm group 1
    associate ccm 1 priority 1
    dial-peer cor custom
    name internal
    name local
    name local-plus
    name international
    name national
    name national-plus
    name emergency
    name toll-free
    dial-peer cor list call-internal
    member internal
    dial-peer cor list call-local
    member local
    dial-peer cor list call-local-plus
    member local-plus
    dial-peer cor list call-national
    member national
    dial-peer cor list call-national-plus
    member national-plus
    dial-peer cor list call-international
    member international
    dial-peer cor list call-emergency
    member emergency
    dial-peer cor list call-toll-free
    member toll-free
    dial-peer cor list user-internal
    member internal
    member emergency
    dial-peer cor list user-local
    member internal
    member local
    member emergency
    member toll-free
    dial-peer cor list user-local-plus
    member internal
    member local
    member local-plus
    member emergency
    member toll-free
    dial-peer cor list user-national
    member internal
    member local
    member local-plus
    member national
    member emergency
    member toll-free
    dial-peer cor list user-national-plus
    member internal
    member local
    member local-plus
    member national
    member emergency
    member toll-free
    dial-peer cor list user-international
    member internal
    member local
    member local-plus
    member national
    member emergency
    member toll-free
    dial-peer voice 1 pots
    service stcapp
    port 0/0/0
    dial-peer voice 2 pots
    service stcapp
    port 0/0/1
    dial-peer voice 3 pots
    service stcapp
    port 0/0/2
    dial-peer voice 4 pots
    service stcapp
    port 0/0/3
    dial-peer voice 5 pots
    description ** MOH Port **
    destination-pattern ABC
    port 0/4/0
    no sip-register
    dial-peer voice 50 pots
    description ** incoming dial peer **
    incoming called-number .%
    port 0/1/0
    dial-peer voice 51 pots
    port 0/1/1
    dial-peer voice 52 pots
    port 0/1/2
    dial-peer voice 53 pots
    port 0/1/3
    dial-peer voice 2000 voip
    description ** cue voicemail pilot number **
    translation-profile outgoing XFER_TO_VM_PROFILE
    destination-pattern 800
    b2bua
    session protocol sipv2
    session target ipv4:10.1.10.1
    voice-class sip outbound-proxy ipv4:10.1.10.1
    dtmf-relay sip-notify
    codec g711ulaw
    no vad
    dial-peer voice 54 pots
    description ** FXO pots dial-peer **
    destination-pattern A0
    port 0/1/0
    no sip-register
    dial-peer voice 55 pots
    destination-pattern A1
    port 0/1/1
    no sip-register
    dial-peer voice 56 pots
    destination-pattern A2
    port 0/1/2
    no sip-register
    dial-peer voice 57 pots
    destination-pattern A3
    port 0/1/3
    no sip-register
    dial-peer voice 1000 voip
    permission term
    description ** Incoming call from SIP trunk (Generic SIP Trunk Provider) **
    session target sip-server
    voice-class codec 1
    voice-class sip dtmf-relay force rtp-nte
    dtmf-relay rtp-nte
    ip qos dscp cs5 media
    ip qos dscp cs4 signaling
    no vad
    dial-peer voice 1001 voip
    corlist outgoing call-local
    description ** star code to SIP trunk (Generic SIP Trunk Provider) **
    destination-pattern *..
    voice-class codec 1
    dtmf-relay rtp-nte
    no vad
    dial-peer voice 1003 voip
    description ** Passthrough Inbound Calls from CUE **
    translation-profile incoming SIP_Passthrough
    b2bua
    incoming called-number ABCDT
    codec g711ulaw
    no vad
    dial-peer voice 1005 voip
    description ** Passthrough Inbound MWI from CUE **
    b2bua
    incoming called-number A80T
    codec g711ulaw
    no vad
    dial-peer voice 58 pots
    trunkgroup ALL_FXO
    corlist outgoing call-national
    description **CCA*North-American*Local 10**
    translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
    preference 5
    destination-pattern 9[2-9].........
    forward-digits all
    no sip-register
    dial-peer voice 1023 voip
    translation-profile outgoing PSTN_Outgoing
    preference 1
    destination-pattern [2-9].........
    voice-class codec 1
    dtmf-relay rtp-nte
    no vad
    dial-peer voice 59 pots
    trunkgroup ALL_FXO
    corlist outgoing call-national-plus
    description **CCA*North-American*Long-Distance**
    preference 5
    destination-pattern 91[2-9].........
    forward-digits all
    no sip-register
    dial-peer voice 1020 voip
    preference 1
    destination-pattern 1[2-9].........
    voice-class codec 1
    dtmf-relay rtp-nte
    no vad
    dial-peer voice 3002 voip
    description TollFree877
    translation-profile incoming TollFree877_Called_6
    incoming called-number 8776587270
    voice-class codec 1
    dtmf-relay rtp-nte
    no vad
    dial-peer voice 3003 voip
    description Incoming
    translation-profile incoming Incoming_Called_7
    incoming called-number 5143168496
    voice-class codec 1
    dtmf-relay rtp-nte
    no vad
    no dial-peer outbound status-check pots
    sip-ua
    credentials username --- password 7 --- realm 67.x.x.x
    authentication username
    password 7 ---
    calling-info pstn-to-sip from name set ENERNET
    no remote-party-id
    retry invite 2
    retry register 10
    timers connect 100
    registrar ipv4:67.205.74.164:5060 expires 3600
    sip-server ipv4:67.205.74.164:5060
    host-registrar
    telephony-service
    video
    fxo hook-flash
    max-ephones 14
    max-dn 56
    ip source-address 10.1.1.1 port 2000
    auto assign 10 to 19
    auto assign 5 to 8 type anl
    calling-number initiator
    service phone videoCapability 1
    service phone ehookenable 1
    service dnis overlay
    service dnis dir-lookup
    timeouts interdigit 5
    system message UC520
    url services http://10.1.10.1/voiceview/common/login.do
    url authentication http://10.1.10.1/voiceview/authentic...uthenticate.do
    cnf-file location flash:
    load 7942 SCCP42.8-5-3S
    load 7962 SCCP42.8-5-3S
    load 7970 SCCP70.8-5-3S
    load 7971 SCCP70.8-5-3S
    load 521G-524G cp524g-8-1-17
    load 501G spa5x5-7-4-3
    load 502G spa5x5-7-4-3
    load 504G spa5x5-7-4-3
    load 508G spa5x5-7-4-3
    load 509G spa5x5-7-4-3
    time-zone 12
    voicemail 800
    max-conferences 8 gain -6
    call-forward pattern .T
    call-forward system redirecting-expanded
    moh flash:/media/music-on-hold_10db.au
    multicast moh 239.10.16.16 port 2000
    web admin system name cisco secret 5 $1$LueE$BYPOgzzgSJk4ep/WZBDMN0
    dn-webedit
    time-webedit
    transfer-system full-consult dss
    transfer-pattern 9.T
    transfer-pattern .T
    transfer-pattern 6... blind
    secondary-dialtone 9
    fac standard
    create cnf-files version-stamp 7960 Jul 25 2010 15:07:38
    ephone-template 15
    url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
    softkeys idle Redial Newcall Cfwdall Pickup Gpickup Dnd Login
    softkeys seized Cfwdall Endcall Redial Pickup Gpickup Callback
    softkeys connected Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
    button-layout 7931 2
    ephone-template 16
    ephone-dn 5 dual-line
    number 301 no-reg primary
    label 301
    description PhoneA Analog
    name PhoneA Analog
    call-forward busy 800
    call-forward noan 800 timeout 10
    ephone-dn 6 dual-line
    number 302 no-reg primary
    label 302
    description PhoneB Analog
    name PhoneB Analog
    ephone-dn 7 dual-line
    number 303 no-reg primary
    label 303
    description PhoneC Analog
    name PhoneC Analog
    ephone-dn 8 dual-line
    number 304 no-reg primary
    label 304
    description PhoneD Analog
    name PhoneD Analog
    ephone-dn 9
    number BCD no-reg primary
    description MoH
    moh out-call ABC
    ephone-dn 10
    number 101
    label Incoming
    name Incoming
    call-forward noan 800 timeout 15
    no huntstop
    ephone-dn 11
    number 101
    label Incoming
    name Incoming
    no huntstop
    ephone-dn 12
    number 101
    label Incoming
    name Incoming
    no huntstop
    ephone-dn 13
    number 104
    label Bedroom
    description Bedroom
    name Bedroom
    ephone-dn 14
    number 103
    label Living Room
    description Living Room
    name Living Room
    ephone-dn 15
    number 102
    label Dave Laramee
    description Dave Laramee
    name Dave Laramee
    ephone-dn 54
    number 6... no-reg primary
    description ***CCA XFER TO VM EXTENSION***
    call-forward all 800
    ephone-dn 55
    number A801... no-reg primary
    mwi off
    ephone-dn 56
    number A800... no-reg primary
    mwi on
    ephone 1
    device-security-mode none
    mac-address 6CCC.0C06.0000
    ephone-template 16
    max-calls-per-button 2
    username "u301"
    type anl
    button 1:5
    ephone 2
    mac-address 6CCC.0C06.0001
    ephone-template 16
    username "u302"
    type anl
    button 1:6
    ephone 3
    mac-address 6CCC.0C06.0002
    ephone-template 16
    username "u303"
    type anl
    button 1:7
    ephone 4
    mac-address 6CCC.0C06.0003
    ephone-template 16
    username "u304"
    type anl
    button 1:8
    ephone 5
    nte-end-digit-delay 200
    video
    mac-address 0026.9943.5543
    ephone-template 16
    username "admin" password 0000
    type 7962
    button 1o10,11,12 2x1 3x1 4:15
    button 5w13 6w14
    ephone 6
    video
    mac-address FCFB.FBCA.C2DD
    ephone-template 16
    username "admin2" password 0000
    type 7962
    button 1:14 2o10,11,12 3x2 4x2
    ephone 7
    mac-address FCFB.FBCA.C4A5
    type 7962
    button 1:13 2o10,11,12 3x2 4x2
    ephone 8
    mac-address E0CB.4E7B.0A40
    type CIPC
    ephone 9
    mac-address 0005.9A3C.7800
    type CIPC
    alias exec cca_voice_mode PBX
    banner login ^CCisco Configuration Assistant. Version: 2.2. Mon Jun 07 13:38:37 EDT 2010^C
    no modem enable
    line aux 0
    line 2
    no activation-character
    no exec
    transport preferred none
    transport input all
    line vty 5 100
    ntp master
