  • Port dùng cho VoIP
    Có bác nào biết VoIP được dùng những ports nào không?
    Có thể tìm tài liệu ở đâu?
    Voice uses UDP ports, Data for VoIP uses TCP ports
    TCP 1720 is H.225
    UDP 16383-32767 is RTP voice packets (RFC 1889)
    The UDP port for VoIP is 16384 to 16384+4N, where N is the number of voice calls
    that the router can support. The full range of UDP ports is 16384 to 32768
    TCP 11000-11999 is H.245
    VoIP Call Control Protocols
    H.323 = TCP 1719-1720, 11000-11999
    Skinny = TCP 2000-2200
    ICCP = TCP 8001-8002
    CTI (TAPI/JTAPI) = TCP 2748
    MGCP = UDP 2427, TCP 2428
    SIP – RFC 2543,
      SIP: TCP: 5060
      SIP Trunk: TCP 5061
