CCNA Certification
  • CCNA Certification
    CCNA Certification
    The CCNA certification (Cisco Certified Network Associate) indicates a foundation in and apprentice knowledge of networking. CCNA certified professionals can install, configure, and operate LAN, WAN, and dial access services for small networks (100 nodes or fewer), including but not limited to use of these protocols: IP, IGRP, Serial, Frame Relay, IP RIP, VLANs, RIP, Ethernet, Access Lists.
    To obtain a Cisco Career Certification, you must read and accept the terms of the Cisco Career Certifications and Confidentiality Agreement. Failure to complete this step will prohibit processing of any Cisco Career Certification application.
    Cisco Certified Network Associate Exam (CCNA 640-607)*
    Exam Number: 640-607
    Associated Certifications: CCNA
    Duration: 90 minutes (55-65 questions)
    Available Languages: English, Japanese in Japan only
    Pearson VUE or Prometric
    Exam Description
    The Cisco Certified Network Associate exam (CCNA) is the only exam required to achieve a CCNA Routing and Switching certification.
    Exam Topics
    The following topics are general guidelines for the content likely to be included on the CCNA exam. However, other related topics may also appear on any specific delivery of the exam.
    Bridging/Switching
    Distinguish between cut-through and store-and-forward LAN switching
    Describe the operation of the Spanning Tree Protocol and its benefits
    Verify the operation of the Spanning Tree Protocol on the switch
    Describe the operation and benefits of VLANs
    Configure VLANs on a switch
    Configure VTP and trunking on switches
    Compare and contrast switches and bridges
    Identify anomolies in VLAN, trunking, and VTP operation
    Configure a switch for basic operations
    OSI Reference Model & Layered Communication
    Describe data link and network addresses and identify key differences between them
    Identify at least three reasons why the industry uses a layered model
    Define and explain the conversion steps of data encapsulation and de-encapsulation
    Describe connection-oriented network service and connectionless network service, and identify their key differences
    Describe the functions of each the seven layers of the OSI model and their corresponding applications
    Compare the OSI model with the TCP/IP stack
    Match networking devices to their OSI layer(s)
    Use the OSI model as a conceptual strategy to identify network problems
    Routed Protocols
    Describe the different classes of IP addresses including subnetting and private addresses
    Configure IP addresses
    Troubleshoot IP address schemes
    Develop an IP addressing scheme to meet requirements
    Identify the fundamental uses of various TCP/IP application layer protocols
    Convert between decimal, hexadecimal, and binary
    Define flow control and describe the three basic methods used in networking
    Explain the functions of the TCP/IP network and transport layer protocols
    Routing Protocols
    Configure a router for inter-VLAN communication
    Verify IP routing with show and debug commands
    Compare and contrast the key operations that distinguish distance-vector, link-state, and hybrid protocols
    Identify exterior and interior routing protocols
    Configure static and default routes on a router
    Enable RIP and IGRP on a router
    Identify routing metrics used by IGRP and RIP
    WAN Protocols
    Explain key Frame Relay terms and features
    Configure Frame Relay LMIs, maps, and subinterfaces
    Identify ISDN protocols, function groups, reference points, and channels
    Differentiate between the following WAN services: LAPB, Frame Relay, ISDN/LAPD, HDLC, PPP, and DDR
    Identify PPP operations to encapsulate WAN data on Cisco routers
    Use show commands to display network operational parameters so that anomalies are detected
    Configure ISDN BRI and legacy dial-on-demand routing (DDR)
    Configure a serial connection with PPP encapsulation
    Network Management
    Monitor and verify selected access list operations on the router
    Configure authentification types (CHAP/PAP) on PPP links
    Manage configuration files from the privilege EXEC mode
    Manage IOS images and device configuration files
    Load Cisco IOS software from: Flash memory, a TFTP server, or ROM
    Perform backup, upgrade, and loading of Cisco IOS software and configuration files
    Configure access lists to meet specified operational requirements
    Use CDP to identify a network topology
    Use ICMP to verify network connectivity and locate network problems
    LAN Technologies
    Determine the appropriate uses for full- and half-duplex Ethernet operation.
    Describe the causes and effects of network congestion in Ethernet networks
    Describe the benefits of network segmentation with various networking devices
    Identify the cause(s) of LAN connectivity problem
    Describe the function, operation, and primary components on a LAN
    Cisco Basics, IOS & Network Basics
    Describe router elements (RAM, ROM, Flash, NVRAM, config register)
    Configure router passwords, identification, and banner
    Use the context-sensitive help facility
    Use the command history and editing features
    Perform the initial router configuration (including using the setup mode).
    Use show commands to display basic network operational parameters
    Describe router start-up sequence
    Establish connectivity from a host to the appropriate network device to perform configuration tasks
    In accordance with open standards, interconnect network devices
    Differentiate between routed and routing protocols
    Recommended Training
    The following courses are the recommended training for this exam.
    CCNA Basics (CCNAB)
    Interconnecting Cisco Network Devices (ICND)
