E đang tập cài ko biết bác nào cài rồi cho em xin cái hướng dẫn chi tiết với và các lưu ý khi cài. E tìm trên mạng ko thấy, thanks các bác!:X
Originally posted by duykid View PostE đang tập cài ko biết bác nào cài rồi cho em xin cái hướng dẫn chi tiết với và các lưu ý khi cài. E tìm trên mạng ko thấy, thanks các bác!:X
HP-UX 11i v3 Installation and Update Guide, February 2007 (Initial Release): http://docs.hp.com/en/5991-6460/5991-6460.pdf
HP-UX 11i v3 Installation and Update Guide, September 2008 (Update 3 Release): http://docs.hp.com/en/5992-4165/5992-4165.pdfNever Gone - Never Far
Em khởi động HP UNix nó boot xong đoạn
Code:I/O test 8119 I/O config 8204 processor test 1120 processor test 1120 processor INIT 1701 processor test 1120 processor test 1142 platform test 612A I/O config 8238 ***************************************** ************ EARLY BOOT VFP ************* End of early boot detected ***************************************** Firmware Version 42.19 Duplex Console IO Dependent Code (IODC) revision 1 ------------------------------------------------------------------------------ (c) Copyright 1995-2000, Hewlett-Packard Company, All rights reserved ------------------------------------------------------------------------------ Processor Speed State CoProcessor State Cache Size Number State Inst Data --------- -------- --------------------- ----------------- ------------ 0 550 MHz Active Functional 512 KB 1 MB Central Bus Speed (in MHz) : 133 Available Memory : 1048576 KB Good Memory Required : 30804 KB Primary boot path: 0/0/1/1.2 Alternate boot path: 0/0/2/0.2 Console path: 0/0/4/1.0 Keyboard path: 0/0/4/0.0 WARNING: The non-destructive test bit was set, so memory was not tested destructively. Information only, no action required. Processor is booting from first available device. To discontinue, press any key within 10 seconds.
nó ra cái này:
Code:Serial console port error has occurred. A single character may have been lost. Console port recovered. Boot terminated. ---- Main Menu --------------------------------------------------------------- Command Description ------- ----------- BOot [PRI|ALT|<path>] Boot from specified path PAth [PRI|ALT] [<path>] Display or modify a path SEArch [DIsplay|IPL] [<path>] Search for boot devices COnfiguration menu Displays or sets boot values INformation menu Displays hardware information SERvice menu Displays service commands DIsplay Redisplay the current menu HElp [<menu>|<command>] Display help for menu or command RESET Restart the system ---- Main Menu: Enter command or menu >
Lần 2 em reboot bằng tay và để nguyên cho nó chạy ko ấn gì thì cuối cùng nó ra đoạn này:
Code:Trying Alternate Boot Path -------------------------- ************* SYSTEM ALERT ************** SYSTEM NAME: uninitialized DATE: 05/12/2009 TIME: 20:37:55 ALERT LEVEL: 6 = Boot possible, pending failure - action required REASON FOR ALERT SOURCE: 8 = I/O SOURCE DETAIL: 6 = disk SOURCE ID: 0 PROBLEM DETAIL: 0 = no problem detail LEDs: RUN ATTENTION FAULT REMOTE POWER FLASH FLASH ON ON ON LED State: Boot Failed. Running non-OS code. Non-critical error detected. Check Chassis and Console Logs for error messages. 0x0000006086002370 00000000 00000000 - type 0 = Data Field Unused 0x5800086086002370 00006D04 0C142537 - type 11 = Timestamp 05/12/2009 20:37:55 A: ack read of this entry - X: Disable all future alert messages Anything else skip redisplay the log entry ->Choice:
Ko biết đây là lỗi gì, do cổng console hay do fần cứng(HDD).
Tiện e hỏi phát thứ 2 :d
Trong HP UX thì khi hệ thống vừa khổi động thì ấn những bàn phím nào để bỏ chế độ boot hdd để ta chọn boot từ cdrom giống SUN là CTR+BReak.?? Gà mờ nên hỏi các bác :D
