  • [HELP ME] MRTG - mong nhận được support.
    Chào các Anh VnPro!
    Em đang mắc vấn đề này, mà chưa biết fix thế nào:
    Đang có 1 con APC AP9319 cần monitor temperature & humidity. Em cấu hình mrtg chạy trên Windows, đã cấu hình thành công.
    Đã tìm được OID:
    # Created by
    # cfgmaker public@192.168.1.25 --global "WorkDir: c:\www\mrtg" --output mrtg.cfg
    ### Global Config Options
    # for UNIX
    # WorkDir: /home/http/mrtg
    # or for NT
    # WorkDir: c:\mrtgdata
    ### Global Defaults
    # to get bits instead of bytes and graphs growing to the right
    # Options[_]: growright, bits
    EnableIPv6: no
    # System: APC
    # Description: APC Environmental Monitoring Unit (MB:v3.6.9 PF:v2.6.4 PN:apc_hw02_aos_264.bin AF1:v2.6.7 AN1:apc_hw02_ems_267.bin MN:AP9319 HR:3 SN: ZA0551019239 MD:12/15/2005)
    # Contact: NOC-HN
    # Location: VND-HN
    ### Interface 1 >> Descr: 'lance' | Name: '' | Ip: '192.168.1.25' | Eth: '00-c0-b7-7a-da-ff' ###
    Target[192.168.1.25_1]: 1.3.6.1.4.1.318.1.1.10.3.13.1.1.3&1.3.6.1.4.1.318. 1.1.10.3.13.1.1.6 :public@192.168.1.25:
    Title[192.168.1.25_1]:Temperature and Humidity Minitoring By TienPT
    PageTop[192.168.1.25_1]:<H1>Temperature and Humidity Tang 1</H1>
    MaxBytes[192.168.1.25_1]:100
    ShortLegend[apc]:&nbsp
    YLegend[192.168.1.25_1]:Temp/Humidity
    LegendI[192.168.1.25_1]:Temperature(°C)
    LegendO[192.168.1.25_1]:Humidity(%RH)
    Legend1[192.168.1.25_1]:Temperature of sensor
    Legend2[192.168.1.25_1]:Humidity of sensor
    Options[192.168.1.25_1]:nopercent,gauge
    Nhưng nó vẫn không hiển thị ra web ~~
    Em command: perl mrtg mrtg.cfg, nó toàn báo lỗi:
    C:\mrtg-2.16.4\bin>perl mrtg mrtg.cfg
    SNMP Error:
    Received SNMP response with error code
    error status: noSuchName
    index 1 (OID: 1.3.6.1.4.1.318.1.1.10.3.13.1.1.3)
    SNMPv1_Session (remote host: "192.168.1.25" [192.168.1.25].161)
    community: "public"
    request ID: 1705650137
    PDU bufsize: 8000 bytes
    timeout: 2s
    retries: 5
    backoff: 1)
    at C:/mrtg-2.16.4/bin\..\lib\mrtg2/SNMP_util.pm line 492
    SNMPGET Problem for 1.3.6.1.4.1.318.1.1.10.3.13.1.1.3 1.3.6.1.4.1.318.1.1.10.3.1
    3.1.1.6 sysUptime sysName on public@192.168.1.25::::::v4only
    at mrtg line 2242
    2010-08-29 17:54:23: ERROR: Target[192.168.1.25_1][_IN_] ' $target->[0]{$mode} '
    did not eval into defined data
    2010-08-29 17:54:23: ERROR: Target[192.168.1.25_1][_OUT_] ' $target->[0]{$mode}
    ' did not eval into defined data
    Giờ em đang mắc, chưa rõ làm tiếp theo thế nào để fix nó. Các bác nào làm rồi, support em với nhé ~~
    Rất mong nhận được support!
    Địa chỉ 192.168.1.25 là địa chỉ của máy WIndows (NMS), còn địa chỉ IP của UPS APC là bao nhiêu?
      NMS: 192.168.1.28
      APC (Agent): 192.168.1.25 Community: public Access: Read
      Cho em hỏi về OID nhé. Trong trường hợp này, temparature & Hudimity được hiểu là interface phải không anh?
      1.3.6.1.4.1.318.1.1.10.3: đây là OID gốc.
      3.1.1.3: interface
      - Hiểu như thế đúng không Anh?
      Theo Anh, giờ em cần làm gì để có thể monitor được đúng temparature & Hudimityạ?
      Chưa xong em này, thì em không ngủ ngon được :(
        Mình chưa làm con thiết bị monitor này nhưng có một số cách để "mò" như sau :
        + Hãy dùng GetNextRequest trên OID gốc thay vì GetRequest, có thể nó có nhiều sub-OID dưới OID gốc để trả về giá trị.
        + Nên Walk 1 lần hết bảng MIB của nó, có thể tìm ra nhiều cái hay.
        + Thiết bị thường bán kèm theo phần mềm giám sát, bạn dùng phần mềm của hãng để giám sát duy nhất thông số temp, humid, rồi capture gói tin xem nó get OID nào. Sau đó mới đưa đúng OID đó vào MRTG.
        Nếu không được nữa thì contact hãng để support. Có nhiều thiết bị hãng ghi là có thể giám sát đầy đủ các thành phần qua SNMP nhưng thực tế nó không support đủ tất cả.
        Diệp Thanh Nguyên - Viettel Networks
        Certificates : Chứng chỉ A Vi tính 1995 (DOS, NC, Vietres, Foxpro, Quattro) :))
          Many Thanks Anh NguyenDiep :)
          Lúc đầu tìm hiểu về SNMP, em cũng ngải cứu document: SNMP của Anh. DOc đó rất bổ ích ^^
          Về APC này, em đã dùng Getif 2.2 để đọc OID. Em đã thấy MIB của nó, nhưng đã vào từng OID & đọc description của nó, mà không thấy có nói đến temperature & humidity. Anh có từ khóa OID nào có thể content 2 cái đó không ạ?
          APC AP9319 không có tool đi kèm để monitor anh ạ. Vào web của APC (trong LAN: 192.168.1.26) thì nó vẫn trả về giá trị temperature & humidity. Nhưng capture trên web? em chưa làm lần nào.
          Để em ngải cứu tiếp xem sao.
          Thanks your outline!
            Vậy là bạn chưa có đuợc mô tả OID cho temp & humid rồi, bạn phải có OID thì mới monitor đuợc.
            Con APC này cho phép quản trị qua web vậy là nó kết nối vào web server phía trong, web server mới lấy thông tin đưa ra client chứ không phải quét snmp để lấy thông tin. Bạn sẽ không capture đuợc.
            Chắc là bạn cũng chưa có file MIB của nó. Nếu có thể contact hãng đuợc thì nên contact cho nhanh để xin file MIB, sau đó đọc trong file MIB nếu thấy OID temp & humid thì mới thực hiện buớc tiếp theo là quét MRTG
              Mình vừa xem qua template của CATI cho APC thì thấy có 2 OID là .1.3.6.1.4.1.318.1.1.2.1.1.0 và .1.3.6.1.4.1.318.1.1.2.1.2.0. Đây chính là cái bạn TienPT cần :)
                1.3.6.1.4.1.318.1.1.2.1.1.0 for temperature
                and
                1.3.6.1.4.1.318.1.1.2.1.2.0 for Humidity.
                Giữa mrtg và Cacti thì mình vẫn thích Cacti hơn, có bạn nào đã làm qua mrtg và cacti alert by sms to it ?
                CAMAPTRANG
                http://www.asterisk.vn
                  @: Many Thanks Bác NguyenDiep :)
                  Cái em ngải cứu, giờ sếp cho thành seminar rồi. Cuối tuần này report. Hôm qua nghỉ 2/ 9 :). Giờ e bắt đầu working em này. Xong mrtg sẽ là cacti.
                  Rất cảm ơn các Bác đã chia sẻ, support em!
                  Thread này sẽ còn up dài dài :D
                    Kinh thế, làm Seminar cho cái MRTG hay APC ?
                    CAMAPTRANG
                      Cho cái SNMP :D
                      Giờ đang đọc guide cacti của Bác đây :)
